Question about Neff 24 in. S5555X0GB Built-in Dishwasher
Spigot needed - Neff 24 in. S5555X0GB Built-in Dishwasher
Need replacement spigot for brita ultramax
You can order a 3/4" OEM Tomlinson Spigot from ebay for $4.98 Shipped! It is essentially the same identical part that Brita uses except for the handle - which I switched out and reinsert into the new replacement part. All is well and not a drop!
Aug 15, 2017 | Home
I misplaced directions on how to tighten the spigot. Need to know, please
Looking at close-ups of the picture, it has a standard type spigot assembly for a glass-walled beverage vessel. There's a spigot on the outside, with a threaded hollow shaft behind it, a soft compliant gasket between it and the glass, the glass, another gasket, and an internal screw. Looking closely at a picture, such as the one here (
Shangri La 320 oz Beverage Dispenser ), you can even see the hex-head on the internal nut. With the container (hopefully) empty, get a medium sized crescent wrench or slip joint pliers, reach in and grab the nut. With the other hand, hold the spigot and make sure it's square (spigot pointing down and not off to the side). Turn the nut until it's firm. Don't over-tighten it - both the pliers and the threads multiply the force on the wall. If it's really loose, tighten first by hand, then another half to 3/4 turn, at most, with the pliers. Add some water and check it doesn't leak, and you're good.
Good Luck!
Nov 06, 2015 | CIRCLEWARE Shangri La Beverage Dispenser
Outdoor Spigot Leak
You may exchange the washer in the spigot or just change the spigot which is simple.
May 17, 2013 | Plumbing
Is it better to have a stockpot with a spigot for making consomme?
If your stockpot has a spigot then you wont need to lift a heavy, hot pot! Its great because you can drain out all the liquid without breaking the raft, so the liquid wont get clouded.
May 01, 2013 | Home
Price Pfister kitchen faucet with two porcelain controllers, one goose neck spigot and sprayer, chrome. Put the unit in about nine years ago. Starting leaking from base where spigot attaches to base with...
Should have o-rings remove those and lowe's,hardware,home improvement,plumbing supply stores should have what you need.Be sure to use plumbers grease or Vaseline on new o-ring and inside spout to keep from tearing new o-rings.
Jun 01, 2011 | Plumbing
Need to replace my spigot on my 30 cup revere ware coffee maker because it leaks. Where can I get one to "pop" into that hole so I can pour the coffee out of the pot into the cups.
I have a Westbend 24 cup coffee urn with a leaky faucet. I tried finding areplacement spigot for it but so far no luck. My spigot has a screw in the top that allow for disassembly. It looks to me that if I could get a replacement rubber O-ring I could fix it myself. Does anyone know where I could get this?
Thanks
Kelvin
kelvinlov@gmail.com
Sep 16, 2010 | West Bend (59055) Stainless steel 60-Cup...
I am trying to wall mount my LG M197WDP - PZ 19'' TV but it has an ugly spigot that fixes to the free standing base. How can I remove this spigot? Thanks Dave
It's simple!
Step 1: Use a Phillips screwdriver to remove the screws holding the red plate off the bottom.
Step 2: Pop the red plate off (May need some persuasion! It should pop straight out, there is nothing else holding it in place, but be careful)
Step 3: Unscrew the four screws holding the spigot in place, and remove the spigot.
Step 4: Screw the 4 screws bach in place.
Step 5: Screw the red plate back into place.
Step 6: Enjoy!
Oct 22, 2009 | LG Televison & Video
How do you fix a leaking outdoor wall spigot? Even though the handle is turned tightly off there remains a drip. Spigot seems to be all one piece and attached into stucco wall. Is there a way to repair...
Sometimes, depending on the type of the spigot, you can unscrew the valve from inside the spigot. There would be a hex nut immediately under the part where the handle on the valve stem comes out. BE CAREFUL: Outside spigots rarely have independent shut-offs (ie, in order to work on it, you will have to shut off the main water supply). Once you start down this path, you need to be fairly certain there is a replacement available for your type of spigot. If you remove the valve, there is no assurance that you will be able to get the original back in without making the leak worse. Please have an emergency back-up plan in place.
Sep 16, 2009 | Plumbing
Leaking Around Spigot, Coffee Urn
I have a Farberware L1360 with the same problem . If there is water in the pot , in about an hour a nice little puddle forms . It is leaking right where the spigot attaches to the body of the pot. I can see a rubber washer squeezing out around this spot. Maybe It melted?
I think it needs some heat resistant washer to replace it. Farberware co. doesnt really exist anymore. you can barely get parts. If the spigot itself works, mine does. I can't see buying a new one if it just needs a washer. Does anyone know what type of washer would be a good replacement?
Jan 09, 2008 | Pasquini Livia 90 Espresso Machine
Neff 24 in. S5555X0GB Built-in Dishwasher Logo
12 people viewed this question
Top Neff Dishwashers Experts
Samohthda
Level 1 Expert
shaun taylor
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
