Question about Samsung PCL541R 54" Rear Projection Television
Menu, Channel, Volume buttons are not working
My TV will turn on and off but the menu button that controls the brightness,contrast, language, time settings is disabled along with the ability to change channels or change the current volume....I see from the other postings that a fuse could be the issue...do you think that could also be the issue for me? And if so, how do you go about getting in the TV to check the fuses?
  • 50 Answers
Can you access through the back of the unit? If so make sure unit is unplugged, before going in. Then you should be able to look at the boards.
Posted on Feb 14, 2008
How to unlock buttons?
Not sure if this is exactly the same as yours your model hard to find I had 2 similar monitors at previous employer and they both operated the same way Taking a Look 1. Power Switch Pressing this button turns the display system power on or off. 2. Menu/Select ? Pressing this button pops up the OSD menus on the screen, and used to select ("Up" direction) the OSD control options on the screen. ? This button is used to select ("Down" direction) the OSD control options on 3. Select the screen. 4. + This button is used to increase the value of the selected OSD control option. 5. 0 This button is used to decrease the value of the selected OSD control option. Quick Adjustment Function When the OSD Menu is not active, the following functions are available for the quick adjustment. Pressing ? button once pops up the OSD Function Main Menu . Pressing ? button once pops up the small Brightness icon. Use +or 0button to adjust the Brightness level. Pressing + button once pops up the small Volume icon. Use +or 0 button to adjust the Volume level.
Apr 17, 2016 | Princeton Digital VL173 Monitor
Adjust brightness
it is likely to be an onscreen menu. look for a set-up, or menu button, the channel and volume buttons are often used to navigate thru the set-up options
Oct 21, 2013 | Emerson Televison & Video
Dx-ldvd22-10a does not power up what part do you think broke
It sounds like your TV is in Shop Mode.
Shop mode is a set of picture parameters that have been optimized for a store showroom or display floor. Shop mode does not allow you saveicon1.png any picture settings such as brightness or contrast.
To get the TVicon1.png out of Shop Mode press and hold the Menu button on the front panel for three seconds, the picture will blank momentarily then reappear with "Dynamic Mode" shown on the screen. At this point the picture parameters can be changed and saved.
If this method doesn't work for your TV there is an alternate method that might.
From the buttons on the front of the TV (not the remote):
1) Press the Volume + (increase volume) button
2) Whilst the volume button is pressed, press and keep pressed the menu button
3) Let go of the volume button and keep the menu button pressed for 5 seconds
4) After this time the screen should go blank and "Dynamic" will appear at the bottom of the screen.
from
http://www.fixya.com/support/t399140-samsung_le46f8_picture_setting
Jul 27, 2013 | Televison & Video
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
How do we adjust color without a remote ?
Hello
If your TV has a "Menu" button on its front panel, press it once to get into its menu option. Surf thorogh and come to the picture control window. There you can see the adjustments. Will be Brightness, Contrast, Colour, Sharpness, Tint etc. Select the option you want to adjust, advance or decrese its parameter by volume Up/Down buttons. If there is no 'Menu' button on its front panel, it will be impossible to adjust these parametes withoug a remote control. OK.
Jul 24, 2011 | Televison & Video
Just bought one of these used and need to adjust the color brightness contrast etc. I assume I do this thru the "menu" option. I don't have the original remote with the unit and I can't get any universal...
Try website like Remotes.com to buy the original remote it ur best bet.Tries the manual control on the tv.Push the Menu button use the channel + - and the volume + - on the manual buttons to adjust colors,contrast,brightness.
Jul 04, 2010 | GE 13TVR62 Combo
RCA TV picture bigger than screen
if the tv width is ok try entering to service menu (do not use remote control) as follow:
1) turn the set on.
2) press the menu button and hold it down while pressing the power button.
3) while holding down the menu button release the power button and press
the volume + button.
4) The screen will display a one line menu, on the left the parameter P00,
and on the right the value of the parameter V00
5) release buttons.
6) using the volume + button change the right parameter until 76
7) using the channel down button change the left parameter until 06 (vertical size)
8) whith the volume + or volume - adjust the screen size.
9) when your tv is OK back to parameter 00 using the channel up button.
10) press menu button.
and trouble solved.
Mar 05, 2010 | RCA F32650 32" TV
Tv is stuck on aux
Push the "menu"button on the front of the unit. That will get you into the menus to adjust any setting, like caption, language (but that one is tricky if yours happenend to be set to a language you couldn't understand :P), brightness settings and the such are there too. The one you are looking for is "input", change THAT setting. with either volume up/down +/-, or channel up/down (+) (-). In the menu, change the "input" selection to cable or whatever you are trying to watch on the tv.
Hope this helped some, if so, please rate, thank you!
Channel setup
V-Chip Setup
Caption
ect.
Using the Volume + and - along with the Channel up (+) and down(- ) key's, will give you all the adjustments you may need without a remote control.key's, will give you all the adjustments you may need without a remote control.
Feb 02, 2010 | Durabrand DWT1905 TV
Locating the contrast and brightness controlls
You press Menu.. Then Volume Up... then Channel Up or Down to go through Contrast, brightness, tint.. then Volume up or down to change the setting. Then menu again to escape.
Apr 17, 2008 | Durabrand BH1304D 13" TV
Sylvania SST4272
I had the same problem with a Sylvania SRT2227S. I kept trying to fix it using the remote but after reading your posting I pressed the Volume (down) button, which cycled through the same menus you mentioned. Then I pressed the Power button on the TV and that fixed it.
The problem started for me when pressed PIP, CC, and Guide buttons on a Philips universal remote control. My TV does not support these functions and it seems to put it in this "service mode". Now I can fix it by pressing Volume (down) or Menu then the Power button on the TV (do not use the remote as it is useless when the TV is in this mode). I hope this works for you too.
Nov 25, 2007 | Sylvania 6419TC 19" TV
Samsung PCL541R 54" Rear Projection Television Logo
44 people viewed this question
Jerry Greenberg
Jerry Greenberg
