Question about Avanti D110 Electric Portable Dryer
I keep changing 20 amp fuse - Avanti D110 Electric Portable Dryer
What fuse do i take out to keep the horn from blowing on a 2000 dodge stratus
Simply Take Out 10 amp Fuses One at a Time Until Horn Stops, Repeat With 15-20-25 amp If Necessary But Most Likely 10-20 Amp Fuse
Jun 03, 2015 | 2000 Dodge Stratus
Why does fuse 15 keep blowing on citroen picasso 2007
change the fuse from 15 amp to 20 amp will cure your problem
Jun 06, 2014 | 2007 Citroen Xsara Kombi
I have a Kenmore Series 70 Dryer and it keeps blowing the main breaker on the electricity panel - the main fuse is 20 amps do i have a dryer or fuse issue ?
Your dryer needs at least a 30 amp breaker to operate correctly. Changing to a 30 amp breaker should solve your problem. Hope this helps
Sep 01, 2011 | Dryers
Changed alternator,battery and still won't keep battery charged
CHECK ALTERNATOR 175 AMP MEGA FUSE. AND CHECK ALTERNATOR 20 AMP INLINE FUSE.IF FUSES OKAY.REPLACE BATTERY CABLES AND CHECK ALTERNATOR BATTERY FEED WIRE AND VOLTAGE REGULATOR WIRES FOR DAMAGE.AND CHECK DRIVE TENSION.MAKE SURE DRIVE BELT NOT DAMAGE OR SLIPPING.
May 30, 2011 | 2003 Ford Expedition
My 2002 f350 diesel keeps blowing the fuel pump fuse every couple of miles. What is causing this? I changed the filter and it made it worse.
the problem could be the fuel pump fuses only blow when they are overloaded ie. if you have a 15 amp fuse & the fuel pump or whatever is drawing 20 amps the fuse will blow,if you are using the right amp fuse the fuel pump is drawing too much power & may be faulty or there is a problem with the wiring, a loose connection or the like.....hope this helps....cheers
Aug 14, 2010 | 1988 Ford F 350
Fuse keeps blowing out on my 1995 range rover lwb every time I reconnect the battery it is the fuse for the fuel cap relay
It does appear you have a short circuit. Pck up an automatic circuit breaker at a parts store. Thy come in the style of plug that your fuse comes in and the proper amp rating. Put it in place of the fuse. It wil start clicking like a turn sigbal and give you a chance to find the short without having to keep changing fuses. If your fuse is a 20 amp, get a 15 amp so it will cycle faster. When you find the short, the breaker will stop clicking. Good Luck
_Ned_
Oct 17, 2009 | 1995 Land Rover Range Rover
My Fuel Fuse Keeps poping
I'd try a 20 amp maybee even a 25
Sep 17, 2009 | 1999 Pontiac Sunfire
2009 e250 keeps blowing 10 amp parking fuse then
if it keeps blowing the fuse you have a short in the wiring
Sep 11, 2009 | 2009 Ford Econoline Cargo
Amp keeps blowing fuses (alpine mrdm1001
Hello prabh_dusanj,
First make sure that the amp is not operating into too low of an impedance. If the load is OK, it's most likely a short in the output transistors.
Hope this helps.
Sep 11, 2009 | Alpine MRD-M1001 Car Audio Amplifier
Avanti D110 Electric Portable Dryer Logo
54 people viewed this question
Top Avanti Dryers Experts
Tim Whalen
richie46
Are you an Avanti Dryer Expert? Answer questions, earn points and help others
