Question about Lexmark E332n Laser Printer
Orange light on E332n printer won't print
Printer is holding documents, but won't print. Orange light is on.
SOURCE: lexmark x2600 printer
Pull the tray out at the bottom of the printer. This is causing the printer to think it has a paper jam. It is simply the paper feed button.
Any other issues email me at derrickfoster3@gmail.com
Posted on Feb 25, 2009
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: the light first flashed orange causing printer to
    The light flashing orange or green could mean a couple of things. First could mean that the paper size that you are using is not the same that you have configured on the printer or the paper size that you have selected on your software is not the same as the one configured in the printer. Also it could be a message of the toner low. You can try resetting he printer to factory defaults. Turn Printer off and open the front cover. Then Press and hold the Button with the Triangle and the Cancel Button the one with the X and turn the printer back on. You will have to keep the buttons pressed until the exclamation light comes up solid then release the two buttons and close the cover. That should reset the printer to factory Defaults.
    Posted on Feb 25, 2010
    • 10406 Answers
    SOURCE: Printer will not print yellow or orange, but
    Yellow is one of the printer's "primary" colours.
    Orange is mix of "red" and "yellow".
    So, an empty "yellow" cartridge, or clogged ink-jets would cause your symptoms.
    Posted on Sep 17, 2010
    archaeology
    • 662 Answers
    SOURCE: I just purchased a Lexmark
    View/Print/Download Users Guide (74 pages):
    http://www.lexmark.com/publications/pdfs/2007/x2600/v12357467_en.pdf
    (For WinXP) to use the Lexmark printer diagnostic software:
    START > All Programs > Lexmark Service Center
    (for WinVista) - same procedure, but "START" button is an icon.
    View/Print/Download Setup Sheet (2 pages):
    http://www.lexmark.com/publications/pdfs/2007/2600/PN14V1071.pdf
    In case your USB port is disabled and your printer is connected to your system via the USB port:
    In Windows Vista
    a Click (WinVista START ICON) > Control Panel.
    b Click System and Maintenance > System.
    c Click Device Manager.
    In Windows XP
    a Click Start.
    b Click Control Panel > Performance and Maintenance >System.
    c From the Hardware tab, click Device Manager
    Anyway, these manuals fail to list the printer display error codes....
    My ideas:
    (a) the all-in-1 may be in FAX mode and there is no active FAX/modem
    and the LexMark Productivity Studio software isn't running - set it to Printer mode.
    (b) the All-in-1 is in COPY mode - set it to Printer Mode
    (c) the All-in-1 is in Scanner mode - set it to Printer mode.
    How are your printer and PC attached? USB cable? serial cable? wireless? ethernet?
    Posted on Jan 02, 2011
    Printtech
    • 1087 Answers
    SOURCE: orange light on lexmark E260D
    We would like to know more about the lights you're referring to. The lights are represented by Error, Jam, Load Paper, Toner Low, Ready and Continue (green button).
    Since the printer will print, for us to give the common light sequences, please provide us information which light is orange on the printer.
    For further assistance, please call Lexmark Technical Support.
    Posted on Jul 06, 2011
    Mp220 absorber full check printer 5b00
    1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the
    Power button. (DO NOT release the buttons. The LED lights in green to indicate that a function
    is selectable.)
    2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the
    Power button.)
    3) While holding the Power button, press the Resume/Cancel button 2 times, and then release
    both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed,
    the LED lights alternately in orange and green, starting with orange.)
    4) When the LED lights in green, press the Resume/Cancel button the specified number of time(s)
    according to the function listed in the table below. (Each time the Resume/Cancel button is
    pressed, the LED lights alternately in orange and green, starting with orange.)
    Times LED Function Remarks
    0 times Green Power off When the print head is not installed, the carriage
    returns and locks in the home position.
    1 time Orange Service test print See APPENDIX 1, SERVICE TEST PRINT.
    2 times Green EEPROM information print See APPENDIX 2, EEPROM INFORMATION
    PRINT.
    3 times Orange EEPROM initialization
    4 times Green Waste ink counter resetting
    5 times Orange Destination settings Proceed to the step 5), and follow the
    Destination settings procedures.
    6 times Green Print head deep cleaning
    7 times Green CD-R test print Not used in servicing.
    8 times Orange CD-R print position correction
    (horizontal)
    9 times Green CD-R print position correction
    (vertical)
    10 times
    or more
    Return to the menu selection
    Feb 05, 2014 | Canon PIXMA iP3300 InkJet Photo Printer
    An error occured we cannot print a document which the orange light was blink semoustanousely
    Damage canon printers, can be identified from the number of lights blinking in orange. So, you calculate, how many times the orange light is blinking. Example E2, E3, E4, E5, E8, E9, E13, E14, E15, etc.
    Problem
    For
    the error code E13 = The following ink may have run out black/color
    Solution
    Press and hold the Reset button about 10 second. E13 error on canon pixma, occurs twice. E13 for black cartridges, and E13 for the color cartridges
    Nov 25, 2011 | Canon Pixma iP2700 InkJet Photo Printer
    Canon IP 3000 - ink absorber full
    <Service mode operation procedures>
    is selectable.)
    Power button.)
    PRINT.
    Jul 02, 2010 | Canon PIXMA iP1300 Printer
    Hello there wondering if you can help me My power light on my Canon ip2000 keeps flashing green/orange and the print queue stops and nothing is happening. I've powered the printer on/off Also have...
    Usually means theres a paper jam or your out of paper or some problem is occurring. While that blinking orange is blinking press and hold it for about 5 seconds the printer should stop blinking orange and continue with the print. Also open up your printer to see if there are any documents that are in the print queue. Probably can delete those. Thats my guess as to whats wrong with the printer. Used to have one of those. Nice little printer remember 12 blacks for 12 bucks.
    Dec 16, 2009 | Canon PIXMA iP2000 InkJet Printer
    Both green and orange lights blinking. Printer
    Try deleting all ready to print documents, restarting the printer and then re-booting the computer. Somebody in there is confused.
    If that doesn't work, check your documentation on how to print a test page, if it will print then the problem is which the application otherwise re-install the printer.
    Oct 09, 2009 | Castelle LANpress Jr. MP (66298601-040)...
    The printer flashes orange light five times, and green once
    Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
    1. Start with printer OFF
    2. Hold down RESUME and then hold down POWER
    3. Release RESUME
    4. press RESUME twice, then release POWER
    5. let green light blink until printhead has finished moving.
    6. Select functions below with RESUME, execute with POWER
    0 presses - green light - Test Print (exit service for i960)
    1 press - orange light - EEPROM info print
    2 presses - green light - EEPROM initialise
    3 presses - orange light - reset waste ink counter.
    This also applies to the i550, i560, i950, i960
    Sep 07, 2009 | Canon BubbleJet i560 InkJet Printer
    Document is not printing
    Press the feed button. If that doesn't work, turn the printer off, wait a few seconds, and turn it back on again.
    Feb 03, 2009 | HP DeskJet 932c InkJet Printer
    Will not print. Orange exclamation mark/point on - not flashing
    You may follow Dell's preventive maintenance on the printer you have, the orange exclamation mark regulatly mean a hault on the printer's operation. The link will show you have to have it cleared and make the printer operational once again.
    Dell's preventive maintenance for printers.
    Jan 01, 2009 | Dell 1320c Laser Printer
    Canon i950 flashing orange green orange green
    Start with the printer OFF
    1. Hold down RESUME and then hold down POWER
    2. Release RESUME
    3. Press RESUME twice, then release POWER
    4. Let green light blink until printer is done futzing
    Select function with RESUME press POWER to execute:
    presses - light color - function
    Number of presses - light color - function
    0 presses - green - Test print (or exit service mode on i960)
    1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i950)
    2 presses - green - EEPROM initialize
    3 presses - orange - Reset waste ink counter
    Aug 22, 2008 | Canon i950 InkJet Photo Printer
    Printer ripair
    The BJC 3000 will flash two different colored lights in a pattern to signal several different errors. From the documentation I have the two colors are orange and green, could those be the colors you see? At any rate here is the code: Two orange flashes: Out of paper, paper jam, or paper feed error. If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing. Three orange flashes: Paper jam. If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing. Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink. Replace the empty BJ tank and press the Resume button to continue printing. Five orange flashes: BJ cartridge is not installed properly. Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely. Six orange flashes: BJ cartridge (printhead) is not installed. Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely. Seven orange flashes: BJ cartridge (printhead) is defective. Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge. Eight orange flashes: Waste ink absorber almost full. The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing. The POWER light flashes orange and green alternately: Service error. A service error means the printer requires the attention of a qualified technician. If you have any more questions let us know otherwise please don't forget to rate this post.
    Feb 20, 2007 | Canon BJC 3000 InkJet Printer
    Lexmark E332n Laser Printer Logo
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
