Question about Casio G-Shock G2600 watch
Hands show different time than digital - Casio G-Shock G2600 watch
I have a disallignement of 10 minutes between the digital and the analogical time. The digital time is perfect how can I allign the analogical one?
You have to know that analog time "follows" digital time.Any hour/minutes correction on the display has direct effect on time/minutes hands.Some times, mostly after battery replacement,hands might have declination.That is why there is a function so called "Hands home position adjustment".Using this function you can align both hands to 12/00 position.If there is any declination (I think is your case) you can correct.Try to enable this function by pressing for 4-5 sec the upper left button(A) until "HAND SET" appears.If hands are not aligned exactly to 12/00 position, you must correct by pressing the lower right button (D) for forward movement or the upper right button (B) for backward movement.In fact, minutes hand is aligned,hour hand follows.When both hands are set to 12/00 (home position) press button A again.Time Mode returns to the display.Normally hands will now show exactly according to digital (display) time.I hope this will help.
May 23, 2015 | Casio WVA105HDA Wave Ceptor watch
The watch shows time in digital plus has hands on it like a regular watch the digital shows one time and the hands show another
Hi jessestaton,
All you would have to do is change the time from either the digital mode or the anolog hands , you can choose one which is incorrect and try to change it.
Now to change the analog clock's settings , you would have a button which you can manually rotate and set the time, this is how you would be able to recognise that it's for the anolog time modification.
If you need to change the digital time , all you have to do is find out buttons that are present on the watch , and then try to change the time.
Note:- If you find a circled knob , remember that could only be for anolog time change as digital time is never changed using such knobs or screws , but have seperate button for that function.
In case you have any queries, feel free to get back.
Hope this helps ..:)
Jun 12, 2011 | Watches
How do i match the digi time with the hand time?
Some Renato anidigis are world timers tracking second times and time zones. On my Vulcan World timer for example, pressing the crown allows you to select and set a second city and time zone for the digital display while the analog dial continues to show the primary local time you entered when you did the initial setup. If you want both displays to show the same time, simply set the same city for both displays. To set the secondary digital display on mine, after pressing the crown, CITY would blink, and I would choose the same city and time zone again rather than let the indicator rest on a different one at random.
Mar 20, 2011 | Renato T-Rex Ana-Digi Watch for Men
Casio Wave Ceptor 3353. Digital time is correct. Hands are about 15 minutes fast ahead . Cannot correct.
I have the casio 3353. When I read hte manual to do different things, it always startes the instruction by saying "in timekeeping mode". In the instuction booklet at page 8 it shows a picture of the watch face in timekeeping mode and in the picture the face shows the day and date. My face is showing the digital time here. How do I show the day and date,or the timekeeping mode?
Sep 09, 2010 | Casio DW9051B-1V Wrist Watch
My red hour hand doesn't stay the same time difference . Sometimes it's two hours behind BST and sometimes six!
mcdevito75 here, Sounds like your watch is showing a different time zone, refer to your owners manual or vist a locl jeweler for adjustment on timeing, setting your watch. Your watch may be set up to show different world time zones, if so, you may have hit a button and now your watch is showing time in a different time zone as an example London / New York.
Jun 29, 2010 | Rolex Explorer II 16570 Wrist Watch
Cannot get the digital settings and the analog hands to match.
mcdevito75 here, Most likely the digital part of your watch is for thetime in your time zone while the analog (hands) time is for a different time zone, (Lodon / New York) visit a small watch repair shop in your area for details.
Jun 26, 2010 | Watches
Hands do not show same time as digital display. the hands are two hours and several seconds behind the digital display. the digital display is correct. when I press the A and B buttons simultaneously...
I have a Casio which had a similar problem and had to resort to reading he instructions to align the times!
I presume that instructions for your watch are not to hand but you can get instructions from the Citizen web site.
Go to "citizen.com" and on the upper right there is a menu. Click on "technical support" and then on "setting instructions"
Fill in the information required from the back of your watch and then click on "get setting instructions"
Mar 20, 2010 | Citizen Eco-Drive JR3080-51L Wrist Watch
Analog hands show 2hour 15minute ahead of the digital time. Can swap time zones fine, but the time difference remains. Cannot synchronize as per manual because cannot get eco-bat -1 set point. How to...
I have read the instructions and theyare as clear as mud!
If you haven't already tried it, try foll0wing the "local time" setting instructions, with reference to the s#last section "If necessary perform setting..............." This should either alter the hands or the digital display, so that you can get them to agree.
If you still cannot set your watch, then you might find it useful to go to Tissot.com and click on "contact us" and send them an email explaining your problem.
Mar 14, 2010 | Tissot T Touch Navigator 3000 T96.1.488.42...
Synchronizing digital time with analogue time
hi...
press the T button until the crystal is activated.
press the middle of the glass until the time format appears (24hb Cm appears)
hold the T button for 5secs (SYNCHro appears)
move the hands until they are at 12 o'clock. ( + button moves the minute hand. - button moves the hour hand)
press the T button to set.
digital and analogue time are synchronised
pol
Jun 19, 2008 | Tissot T-Touch T33759851
Casio G-Shock G2600 watch Logo
32 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
