both 18v nicd batteries have the yellow and green light on and do not go off while trying to charge. had one in for an hour and the lights never went off.
Its likely the batteries will take at least several hours to fully charge, if not more. NiCad batteries are slow charging and usually need 4-6 hours for a full charge. Keep them on longer or even overnight but make sure you remove them in the morning. You will probably find the light turns green after 4-6 hours of charging. If lights stay yellow and green after 12 hours of charging, it may indicate a fault in the battery itself where it will not accept a charge.
The Yellow and Green light both come on and stay on when I put in a battery to charge !!! This is a...
(More)
The Yellow and Green light both come on and stay on when I put in a battery to charge !!! This is a Ryobi 18v battery charger model #1423701.....
One of the front power jacks will not work. The motor side works great. The orthe side the gear on...
(More)
One of the front power jacks will not work. The motor side works great. The orthe side the gear on the shaft from the motor turns and it also turns the gear that raises and lowers the jack but the jack does not move. Are thys a pin that has been sheared and can it be fixed?
