Question about Maytag MSD2732GR Side by Side Refrigerator
How do you get the doors on a side by side model to swing shut?
The doors on my side by side MAYTAG Model #MSD264RHEW do not swing shut on their own. I need advice on how to make them swing shut on their own. Thanks Dave
    President:
  • 1,136 Answers
Hi, There are adjustments on each side in the front corners. Turn the bolt clockwise and the front of the refrigerator should raise up. This will cause the doors to shut on there own.
If there is resistance when the door is swinging, check the hinges and see if the nylon washers/closers are warn.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jun 18, 2009
Maytag side by side door slamming shut
what's the model number and what's happening with it,do you mean the fridge is on top and freezer on bottom?open the fridge door,look up on right hand side up near ceiling and send the model number and the first two numbers of the serial number
Jun 18, 2012 | Maytag Refrigerators
I have a Magic Chef refrigerator Model GT17A7V, Serial 11993269QS. It does have wheels, but we needed to adjust the wheels in order to make it easier to roll. Problem: The refrig & freezer doors now...
Unfortunately, when you adjusted the wheels to be able to roll it easier, you thru off the tilt required for your doors to swing the way they should.
You are going to have to adjust them again, to have a front (high) to back (low) tilt. If you have a right hinged model it should be adjusted very slightly higher than the left.
Aug 15, 2011 | Maytag Refrigerators
I have a GE Profile "Artica" side-by-side refrigerator model PSC23MGNA - BB. Recently the refrigerator door has begun swinging all the way open ... 180 degrees ... and banging into the...
if you look down at the bottom of the freezer door you'll see a door stop,two 5/16 inch screws hold it in place,the stop on the fridge door must of broke.you can switch it from the freezer to the fridge door for now until you get a new one.part number is WR02X13425 and it's around 5 dollars.give your parts store the model number and they will take care of you,or go here,pick any topic here,put your model number in,to the right of the model it will as model or part number,pick model and click on it and your machine will come up,click on fresh food door,your part is numer 12 and you can order it from sears if you want.let me know how you make out
Feb 02, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Side by side door not shutting properly
There are magnets inside the seal this is what keeps it closed. Either the seal is damaged or the magnets are worn out. They do wear out but usually not for at least 10 years depending on the usage.You can go to www.appliancehelponline.com for a diagraam or illustration of your specific model. The parts also come with installation instructions.
Mar 31, 2010 | Kenmore 57029 Side by Side Refrigerator
Maytag refrigerator bottom pull-out drawer has frost inside. Kept running all night long. One year ago we had to replace the ''board'' and now it's happened again. (Unit only three years old then. Dealer...
frost is a sign that warm air is coming in from somewhere,the most common issue w/ bottom freezers is the door can appear to be shut,when its actually not.always shut door from the middle of the door,not sides. if a bottom freezer is preffered-i suggest a swinging door vs. the sliding drawer....
Mar 10, 2010 | Refrigerators
Can you change the door direction on a Maytag
Unfortunately, you can only change front loading dryer door directions on some models. Washing machines do not allow this. If the units are stacked i may be easier to switch loads, otherwise the dryer door may be able to have the door swing direction changed but without the Dryer model # I couldn't say for sure.
Dec 29, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag side by side (Model MSD264RHEW) buttons pushed in...
The part number you need is 67003817 . This is the control board with the buttons .
Aug 13, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Maytag dryer model mdg5500aww
OPEN THE DOOR AND REMOVE THE TWO SCREWS IN THE MIDDLE OF EACH HINGE. LOOK AT THE OPPOSITE SIDE OF THE OPENING AND REMOVE TWO SCREWS FROM THAT SIDE ALSO. PULL FRONT TOWARD YOU FROM THE TOP. IT IS HINGED AT THE BOTTOM. ONCE THE TOP IS FREE, LIFT THE FRONT OFF THE HINGES. THERE IS A CLIP HOLDING THE TOP TO THE CABINET AT THE FRONT CORNERS. REMOVE THE SCREWS HOLDING THE CLIPS IN PLACE AND SWING THE CLIPS TO THE LEFT AND RIGHT TO REMOVE THEM. THE TOP SHOULD SWING UP AND TO THE BACK AT THIS TIME. IT IS HINGED AT THE BACK.
Mar 24, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag MSD2732GR Side by Side Refrigerator Logo
153 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
