Question about Xerox PHASER 6600 COLOR LASER PRINTER
How to set back to factory settings on xerox phaser 6600
SOURCE: fuji xerox document centre C250
Press machine log in button, enter 11111 confirm, this will take you to sys admin mode, from here you can navigate into sys settings to configure network,copy and fax defaults, and also auditron admin if this is the password mentioned, if the 11111 password has been changed hold the zero button for a few seconds then press start while still holding zero enter 6789 to get into diagnostics, and you can navigate through to the above settings caution be careful what you change in this mode.
Posted on Sep 04, 2008
  • 2072 Answers
SOURCE: Master Reset to Factory Settings - Xerox 432
Yes, you have to go into the service settings and reinitialize the memories. I have to look it up but I will send them to you tomorrow.
Posted on Dec 11, 2008
  • 5 Answers
SOURCE: how to set up printer to print double sided.
First look at your printer identification.
You can see it in either the display or on the startup or configuration pages.
It must have a "D" in the name for you to be able to do automatic duplexing. i.e. 8400DN or 8400DX . Then you can scroll to printer setup
and select defaults, and then turn on the duplex, or double sided printing.
If yours does not have a "D" i.e. 8400, 8400N then you would need a new sim card to enable the duplex option.
Posted on Nov 03, 2009
SOURCE: set factory default
Go to the menu, look in setting and scroll through until you see factory default setting. The functionality you're looking for should be in this area.
Posted on May 02, 2010
  • 57 Answers
SOURCE: reset xerox phaser to factory
Try performing an NVRAM reset, located in 'Troubleshooting', 'Service tools', 'NVRAM reset'. I would advise printing out a configuration page first 'Information', 'Information Pages', 'Configuration Page'.
Hope this helps.
Posted on Jan 19, 2011
How set factory default xerox 7800
Solution : Reset the Printer to the Factory Defaults (Reset NVRAM) WARNING: Only use the tool when directed to by Xerox Service. All user and system settings will be lost.
  1. Select [Printer] on the Touch Screen.
  2. Select the [Tools] tab.
  3. Select [Setup].
  4. Select [Service Tools].
  5. Select [Reset NVRAM]. A confirmation screen will be displayed.
  6. Select [Reset NVRAM] again.
Related Knowledge Bases:
Mar 05, 2014 | Xerox Printer Division Xerox Phaser...
Reset fuser on Xerox phaser 7760
You don't need to reset it it. It should automatically reset with no problem you can try to clear the NVRAM . Careful because you will lose all the information you have stored in it like any IP address or specific settings. What it will do is bring the printer to"factory default settings. You can do it in "service diagnostic mode. goodluck
Feb 19, 2014 | Xerox Corporation 7760/Dn - Xerox Phaser...
I have a Xerox Phaser 6360 that one day just stopped printing yellow, despite having plenty of ink. Xerox told me I needed a new imaging unit, so I replaced it, but it didn't help. I put the old one back...
Your machine uses solid ink wax blocks. So no calibration is necessary. Does the self test print look good. I suspected not.
Check out the Xerox.com website. It could be a problem as you machine is no longer sold.
Sorry.
Oct 16, 2013 | Xerox Phaser 6360 Laser Printer
Reset to factory settings xerox phaser 3250
Reset to factory settings xerox phaser 3250 - Fixya
www.fixya.com/.../t12176778-reset_factory_settings_xerox_phaser_325...
Mar 26, 2012 - A hardware module is used to reset Xerox Phaser 3100 which work as permanent solution. After that you can refill unlimited number of times without ...
Mar 26, 2012 | Xerox Office Equipment & Supplies
Reset xerox phaser to factory settings
Hope this helps.
Dec 15, 2010 | Xerox Phaser 6360 Laser Printer
Set factory default
May 02, 2010 | Xerox Phaser 6200N Laser Printer
Password Problem Phaser 6120
Unfortunetly, you will have to reset the printer. Using the control panel go to the default setting and scroll to reset to factory settings. Then select yes and that should take care of it. If not, then in the rear of the printer under the cover, upper left side you will find the memory button battery. Remove the battery, unplug the unit, and turn it on for about a minute. Turn it off and put it back together and you should be ok. Good luck.
Feb 19, 2009 | Xerox Phaser 6120/YN Laser Printer
Xerox PHASER 6600 COLOR LASER PRINTER Logo
1,096 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
