Question about Whirlpool ADG7800/2 597 mm Silver Built-In Dishwasher 13 Place Settings, A Energy Rating
Whirlpool ADG7800 flashing 3 times
Start Indicator light is flashing three times. this fault is not listed in user manual. what is the fault please?
3 Suggested Answers
SOURCE: My Whirlpool DU1145XTP won't turn on. Clean light
Check the themistor in the control panel. Radio Shack sells these for about $1.30 each. I replaced the one in my dishwasher three years ago and have had no issues since.
Posted on Jan 25, 2011
ercupa190
  • 12223 Answers
SOURCE: Whirlpool dishwasher du1055xtvqo lights flashing
please see this causes and use the common sense. God bless you
Power Supply
The main power supply is the first thing to check. Also remove the toe kick and the cover on the power box and check the connections. Also check for 120 volt at the power box.
Hi - Limit Fuse
This will fail if your dishwasher overheats and occassionally with power surges. This is easy to check, inexpensive and a quick fix. Just check the terminals for continuity ( remember always remove one wire) if you have none replace the hi limit fuse.
Door Switch
This is the second place to look. Again an inexpensive easy fix. The following video will walk you thru checking the door switch. The power comes into the main power box and usually runs to the door switch next before entering the main control module.
Main Control Module / Timer
The main control module or mechanical timer controls all the functions of the dishwasher. To check this you will need to find the 2 leads that supply the power to the control. They will be marked on the wiring diagram. They usually come from the hi - limit fuse or the door switch. When the door is latched you should have 120 volts entering the main control. If you do not the problem is not the control. If you do have power entering the control but none of the functions work properly or it does not respond at all you will need to replace the control module, this is easy to replace but not very inexpensive to purchase. Consider the age and overall condition when purchasing this part.
Motor
The motor may have failed. If the control illuminates on electronic versions the problem may be the motor. To check the motor refer to the tech sheet located behind the console cover on most models, this will sometimes have the ohm reading of the motor. Also check each lead to the metal housing of the motor to check for shorts in the motor. If you do not have the ohm reading specicifications, check for continuity if none replace the motor. Make sure the motor is recieving power.
Float Switch
If the float switch has failed or is stuck the dishwasher control may not respond. The float switch is easy to check and replace. We have video and tutorials that cover several style
Posted on Sep 20, 2012
Hi, Our Sony Bravia TV model number KDF E50A11E is not working. There is a red blinking light flashes three times and then goes green and then red blinking again after about 3 seconds. Is this a bulb...
On that particular model I believe there is both a lamp indicator light and then the power indicator light. If it is lamp related the lamp indicator light (LED that looks like a sun in a cup...) would be on.
If the power indicator light is flashing red to green, that is a self diagnostic code, and you will have to contact an authorized Sony repair fascility for them to translate the problem. The error codes are not listed in the user manual, since most are not user serviceable.
Mar 01, 2011 | Sony (XL-2400) Projector Lamp for...
Power indicator /red/ and warning led/red/ are lighting after ea 15 sec. a lamp never start and fans goes in OFF mode. I checked power supply lines S5V,S-5V,S16V on the Main Board . I checked unit lamp...
If power indicator light red and warning indicator red flashing than according to user manual :-
The projector has been cooled down enough and the temperature returns to normal. When turning ON the projector the WARNING indicator stops flashing. CHECK AND CLEAN THE AIR FILTER.
Experience:- 1. if the temperature is very low than temperature sensor maybe misbehave.
2. If anyone fan not working
so please you check fans.
(If lamp or lamp ballast unit faulty than after a time period the lamp indicator light ON not a warning indicator. I experience many times if any fan in projector are broken or jamed the temperature light if present otherwise warning light ON or flashing)
Jan 20, 2011 | Sanyo PLV-Z4 Multimedia Projectors
W1213, pre-wash and main wash lights flash with the 3 lines --- fault code. I tried entering the service mode as I read online I should push and hold start, then turn on the machine, wait for the dot and...
You are in the service mode now. The buzzer LED displays a flashing rhythm of 2 flashes while the ROM ID is show in the display(this is what you are seeing), press the buzz button to advance to the fault register level. Here is the manual to the tech manual http://laundry.manualsonline.com/mdownloads/89c212d9-4843-4409-b17c-b3439c9b0d05.pdf
Dec 31, 2010 | Miele Touchtronic W1213 Front Load Washer
I lost my codes
USING THE RMC10 REMOTE WITH AN UNLISTED DEVICE.
MANUAL CODE SEARCH:
If your product does not respond after you have tried all the codes for your brand, or if
your brand is not listed, try searching for your code by following these steps:
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold the CODE SEARCH button until the red indicator stays on, then
release the CODE SEARCH button.
3. Press and quickly release the desired mode button (TV, VCR, etc.). The red Indicator
blinks off once.
4. Face the remote control directly to the device you want to control (TV, VCR etc).
5. Press the ON/OFF button repeatedly (up to 300 times) until the device to be
controlled changes channel. The red indicator blinks off with each button press.
6. Press and release ENTER to install the code.
Most users will store VCR codes under the VCR button, Cable codes under CABLE,
etc. If (for example) you want to store a VCR code under CABLE, first follow the
procedure for Direct Code Entry (previous page) and press CABLE in step 2 of Direct
Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the
steps above for Code Search (or Brand Search, below). Note: If the device does not
have a CHANNEL UP button, use PLAY (VCR only) or POWER instead. Code Search
starts from the currently stored three digit number under that mode.
AUTO CODE SEARCH:
your brand is not listed, try searching for your code by following these steps.
2 Press and hold the CODE SEARCH button until the red indicator stays on, then
3. Press and quickly release the desired mode button (TV, VCR, etc.). The red indicator
blinks off once.
5. Press the ON/OFF button down till the Red Indicator Light stays on.
6. The red led indicator will keep on flashing till your device (TV, VCR etc) turns off.
7. Press and release enter to Install the code.
CODE RETRIEVAL:
1. Manually turn on the device (TV, VCR etc) to be controlled.
2. Press and hold the CODE SEARCH button until the red Indicator stays on, then
release the CODE SEARCH.
3. Press the device control (TV, VCR etc) you want to control.
4. Press the CODE SEARCH button again and the red indicator should blink once.
5. Follow the sequence of (0-9)and press once for each number button until the
Indicator flashes one time.
6. Repeat the procedure 5 till 3 correct codes are confirmed.
7. If the red indicator light flashes, than you have entered an incorrect number, and
please follow the sequence (0-9).
also here is your manual. For your remote.
http://www.sentryindustries.com/pdf/instructions/RMC10_Instructions.pdf
please rate me, or recommend me it will be most helpful in letting me and other know how im doing.
Oct 03, 2009 | Sentry SE-RMC10 Remote Control
Dishwasher adp 4601 when switched on the pump activates.and after 2 mins start lamp bliks and pump goes off
The number of flashes indicates the fault. Reset machine by holding down the start button for 3 secs, then start a new cycle. If fault reoccurs, the number of flashes indicates fault eg 3 flashes, stop, 3 flashes stop, indicates F3 fault.
Faults listed below- advice on repair depends on which fault your machine is indicating, but may give you an idea of what to look for
1flash=NTC (temperature sensor) break- NTC outside normal range.
2flash=water leakage-float switch in base activated.
3flash=heating fault(check element.NTC,control board).
4flash=drain error-blockage in pump or drain system,or faulty water indicator switch.
6flash=water inlet fault-check inlet valve, check inlet hose not kinked
7flash=flow meter failure (flow meter measures water intake volume-large plastic weir located on left hand side of machine-reomve side panel to access)
These a most common faults, but further advice on repair requires counting flashes when fault occurs.
Aug 09, 2009 | Whirlpool Dishwashers
Start light flashing wont start cycle, what does it mean
count the number of flashes- this indicates fault ie will flash 4 times stop, flash 4 times stop. To clear fault, hold start button for 3 secs. Try running another fast cycle- if fault reoccurs count flashes: Number of flashes:1=NTC fault, 2=Flood switch activated, 3=Heating fault, 4=drain fault, 6=water inlet fault, 7=flow meter fault, 8=water level fault
Aug 06, 2009 | Whirlpool Dishwashers
Flashing airbag light
yes, go here for more help. There is a file on how to download codes and clear system.
The number of flashes is giving you a lamp fault code, LFC. What is it giving you?
http://autos.groups.yahoo.com/group/villagerquest/
Diagnostic Test Modes Without Scan Tool
Two mode options are available under the diagnostic test modes:
  • user mode.
  • diagnosis mode.
The ignition switch is used to alternate from one mode to another.
Diagnosis Mode
The diagnosis mode will display any fault present in the system. The SRS will not enter diagnosis mode if no malfunction is detected.
User Mode to Diagnosis Mode
NOTE: The SRS will not enter diagnosis mode if no fault is detected in user mode.
  1. Ignition switch to ON.
  1. After the air bag warning indicator lights for seven seconds, set ignition switch to OFF within one second.
  1. Wait more than three seconds.
  1. Repeat steps 1 through 3 three times.
Diagnosis Mode to User Mode — After Repair
  1. Ignition switch to OFF for at least one second.
Diagnosis Mode to User Mode — During Diagnosis
NOTE: If switch from Diagnosis Mode to User Mode is required while diagnosing a fault, carry out the following procedure.
Clearing Lamp Fault Codes
NOTE: Lamp fault codes must be cleared from memory before proving out the system.
NOTE: When a new RCM is installed, the air bag warning indicator will operate in user mode. Switching to diagnosis mode is not required.
To clear lamp fault codes after a repair, carry out the procedure to switch from diagnosis mode to user mode. Once in the user mode, the lamp fault codes will be cleared from memory.
Lamp Fault Codes
If the air bag diagnostic monitor detects a current fault, the fault code will be displayed with a flashing sequence of the air bag indicator. The fault code consists of:
  • A start signal to indicate the beginning of a fault code.
  • A number of flashes indicating the particular code that has been set.
The start signal:
  • begins with two seconds off.
  • two seconds on.
  • off.
  • one second on.
  • two seconds off.
Following the start signal, if any current fault is detected, the fault code will be displayed. The fault code:
  • is a series of half second flashes of the air bag indicator.
  • is followed by the start signal.
The start signal and the code for any current fault will repeat until the ignition is switched off or the air bag diagnostic monitor is switched to the user mode.
Inspection and Verification
  1. Verify the customer concern by checking the air bag indicator in the instrument cluster. Refer to Prove Out in this section.
  1. Visually inspect for obvious signs of mechanical and electrical damage using the following chart.
Visual Inspection Chart Mechanical Electrical
  • Damaged air bag diagnostic monitor bracket
  • Open fuse
  • Damaged wiring harness
  • Loose or corroded connectors
  • Circuitry open or shorted
  • Damaged shorting bars
  1. If the concern is not visually evident, enter the system Diagnosis Mode.
  1. If no DTCs are displayed in the Diagnosis Mode, proceed to the Symptom Chart in this section.
  1. If DTCs are retrieved, proceed to the Air Bag Diagnostic Monitor Fault Code Table in this section.
Air Bag Diagnostic Monitor Fault Code Table Code Component/Fault Description 0 Normal Operation/No Fault Detected 1 Front Passenger Safety Belt Pretensioner 2 Driver Air Bag Module Circuit Is Faulted 3 Front Driver Safety Belt Pretensioner 7 Air Bag Diagnostic Monitor Fault 8 Passenger Air Bag Module Circuit Fault 9 Low Battery Voltage
Mar 24, 2009 | 2001 Mercury Villager
Whirlpool quiet partner I won't run just keeps blinking
is the cean light blinking 7 times and then repaeating?? If so this is a water heating fault and means that the computer sensed that the water temp didnt rise just 3deg in the last main wash cycle. If its not blinking 7times then repeat, it sounds like the user interface (membrane switches) have failed. Let me know more and i can help.
Apr 19, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Spin
Electrical module fault
The “Spin Speed” indicator and the “Start
Delay”
option are flashing and an audible tone
sounds. The display shows “F4” to “F16”.
Switch off the appliance. Select a programme
and press the “Start/Pause” button once
again.
The programme will continue.
If the fault re-occurs, contact After Sales
Service (see “After-Sales Service”).
the user man can be found here
http://www.whirlpool.co.uk/app.cnt/whr/en_GB/pageid/pgsrvifuhome001
Jan 15, 2008 | Whirlpool AWM8163 Front Load Washer
3 beeps mean what
If the only thing that happens is three rapid beeps when you select a feature from the console this is usually a symptom of a defective door switch.  The door switch must be closed to complete the circuit from the timer to the heating circuit and drive motor.  If the switch is bad, or the wiring is broken, the dryer will not run.
Oct 17, 2007 | Kenmore 62062 Electric Dryer
Whirlpool ADG7800/2 597 mm Silver Built-In Dishwasher 13 Place Settings, A Energy Rating Logo
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
