Question about Canon imageCLASS MF4150 All-In-One Laser Printer
Canon ir 2022 displays load correct paper in tray despite tray containing the right a4 size paper. sensor position is in A4 and default size is also A4. what is the problem
SOURCE: CANON MF4140 'LOAD CORRECT PAPER CASSETTE : LTR'
I had same thing happen after a fresh Windows install. It was hard to figure out since it had been working fine until then, but luckily it is simple to fix. Open the Start Menu > Settings > Printers and Faxes folder. Then right-click on the Canon MF4100 Series printer and choose Printing Preferences. In there, change the Paper Size to Letter (instead of A4). You may also have to do this in the Print setup for whatever program you're using to print.
Posted on Nov 14, 2008
I had the same cr@p of the problem yesterday. The problem was not in the paper. You have to do 2 simple things, from which one will solve the problem.
first, download the latest drivers and install them.
And the more important thing, the problem occurred due to incorrect paper format. Solution is very simple. Open MS word or something similar, file->print.. and before you print open Properties menu. There for the Output Size will be selected "Match Page Size". you don't want that (i don't know why it doesn't work), but the solution is manually select A4, or whatever your page size is.
Posted on Dec 27, 2008
canontech
  • 1219 Answers
SOURCE: in A4 and LGL the paper is fully loaded but it
first of all: when you put in paper cass. does the paper cass. produce abnormal sound like kling kling but without klang- if so the gear that rise paper is broken.( do not tray to remove and replace the gear without copy repair experience) this gear is in paper pick up unit, under the countless of clutches, spring, gears, solenoids,...
second: can you see if there is any sensor hanging, remove both cass. and try to compare!
If the machine copys normal from second cass. it is allmost 100% pick up unit.-call service
Posted on Jan 13, 2010
canontech
  • 1219 Answers
SOURCE: Canon IR 3300 model - Paper Load Liver problem in second tray
The tuck tuck sound is sound of paper pick up claw in pick up mechanism of second paper drower.The case is that the pick up clow is worn out and may be broken, so you need to replace it.To replace it you must remove complete pick up unit from the right side of copier, if you are not service technician do not do it by yourself it could be complicated if you do not know exact schedulle of parts and what does it doing.
Posted on Mar 02, 2010
  • 4090 Answers
SOURCE: Canon Pixma MP500 Reset PAGE SIZE to A4
Set up the parameters you want A4 Paper orientation etc then go to profiles in printing prefences and ADD to profile.. delete any others that preced this set of parameters
Please tae my help++++Thanks for using FIXYA
Posted on May 09, 2010
I have canon iR2022 someone help me for setting A4 paper.when i m printing its taking A3 by itself.
You must adjust your paper size in casset .in canon 2022 look to your machin casset left . You see how to adjust
Nov 08, 2016 | Canon iR 2022 Printer
Ir 2420 canon printer displays load correct paper LTR plain
check sliding plastic paper size device in bottom of paper tray is not on LTR if it is meant to be A4
Mar 24, 2016 | Canon Office Equipment & Supplies
Canon ir 2420 every thing are good but printer display : load correct paper A4 Plaint copy.
Dear
If you have done all the things, there might be problem with hardware. If the display shows after the paper taken from tray, then replace the paper size detection switch inside the tray.
Thanks.
Jan 20, 2015 | Canon Office Equipment & Supplies
Ir2022 system error e007 vido
Error Code, Sub Code, Code Explanation E007 0000 Fixing film sensor failure
The fixing film sensor is faulty. Before you change the fixing film, then download and install the newest driver for this printer. If that doesn't work, then check if the paper size is correct. It might be on A4, but you have to check if the dimensions are correct.
This might help with the dimensions
Welcome to A4PaperSize org
Jul 06, 2014 | Canon iR 2022 Printer
Load mp feader a4
Please determine what size you are trying to print (A4, Letter, Legal, etc.). The printer is requesting A4 sized paper in the maunal paper feeder becuase either you selected manual feed or the setting for the default try (usually tray 1) is not set to the correct paper size. In your case, make sure the green slide adjustment on tray 1 is set to A4.
Mar 22, 2014 | Lexmark T632 Laser Printer
My canon ir 2018 is asking me to load correct paper in the tray even when the paper size is correct and all the settings are correct. It would print one copy then ask to load paper, i pull out the tray and...
Check the proper orientation of the paper. For example, if you are loading A4 size. In your tray you can find 2 A4 size. Select A4R in you want to position your paper Landscape or A4 if portrait.
To verify also the correct paper size, put your paper on the platen glass. Markings on the two sides of the platen glass shows the correct paper size.
Sep 16, 2010 | Canon imageRUNNER 2000 Copier
Message Display on LCD of machine it,s load paper LTR
It means that you under printer properties/preferences - custom paper size have ltr size as your default, change it in desired size, eg. A4.
Then turn off and on the copier.
Or check the sensor position on your drawer. blue rail with triangle that must be on A4 or A3 depends on paper that you have in drawer.
Feb 10, 2010 | Canon iR 2022 Printer
Canon ir 2016 digital copier
Are you living in the USA? The size A4 is the Europe size of paper to our letter size... You can try to take the paper tray out and look inside, for any paper jammed in the back of the paper tray area.
Mar 19, 2009 | Canon Office Equipment & Supplies
How do i set paper sizes on my canon ir2016i printer
Open the paper drawer
Remove the paper
There is a blue paper size plate,that keep the paper in the correct posision,Push it to the front and downwarts.The paper plate should come loose from the tray.Put it back in the openning for the A4.The openning for the A4 papersize is mark inside the paper tray.
Now set the blue papersize dail to A4 paper .
Then you are ready to copy with A4 paper.
Feb 19, 2009 | Canon iR 2016i Black and White Copier
Changing Paper Size
If the blue guide in the back of the tray (called the length plate adjuster) is broken or dislodged, the machine may not recognize what size paper is installed. When the guide is moved, three arms on the right side of the paper tray change configuration. Those arms push against sensors in the machine to tell the printer what size paper is in the tray. You can temporarily resolve this by taping the guide in the A4 position, however you should consider replacing the tray or replacing the guide soon to avoid tape getting into the printer.
Hope this helps!
Mar 20, 2008 | HP LaserJet 4050 Printer
Canon imageCLASS  MF4150 All-In-One Laser Printer Logo
46 people viewed this question
old marine
old marine
