Question about Bosch Nexxt 300 Series WFMC2201UC
What does error 3 mean on Gorenje washing machine
I have just moved into an Apartment with a Gorenje wi 62112 Washing machine, I have no manual Can anyone tell me what the numbers on the Dial mean What should I choose for a general wash.
Gorenje has some documentation for their washers here: http://www.gorenje.com/simplicity/en/washing_machines/simple_manual_for_washing . The numbers indicate the water temperature (in Celsius) for a given cycle. The common choices are a cottons load in hot water (60 degrees). This is great for towels and other whites. The mixed load is for permanent press that can be in warm water (40 degrees). Then there is a cold water cycle for delicates (30 degrees). However, you should check the fabric care label before choosing the cycle.
I hope this helps.
Apr 20, 2016 | General Washing Machines
How do reset for washing machine
I do not see a way to do a reset on this unit. This is the manual and shows what things you can try. Manuals Gorenje UK
Sep 30, 2014 | Gorenje W7543LR Red 600 mm Washer Front...
Washing machines
/manuals/_washing_machines/gorenje.html
you can get the item you need here good luck
Jan 12, 2014 | Washing Machines
Gorenje wa72145bk erro f2
it your door lock that faulty
Jul 01, 2012 | Washing Machines
Need Gorenje WA 64153 service manual
Look behind the control panel or inside the cabinet taped to the wall.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2009 | Washing Machines
Gorenje washing machine on display shows F31. what does it mean?
it means"The connection to the tacho generator is open or short-circuited". that means the motor is not turning. 99% it is the brushes (20 eu) and it wil work again.
marko
Jul 12, 2009 | Washing Machines
I need schematic diagram for gorenje wa 50050 washing machine
I find a schematic diagram on internet address www.masine.sigma-com.
Thank you for trying!
Jun 29, 2009 | Washing Machines
No manual for Gorenje front loading washer.
Here is a link to the Gorenje website, you can download the manuals from there which explain all the symbols. This link is for the WA50140 machine which I have, just click on the 'manuals' tab
http://www.gorenje.co.uk/laundry/washing_machines?c=161105
Jan 27, 2009 | Washing Machines
Bosch Nexxt 300 Series WFMC2201UC Logo
48 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
