Question about WowCoolStuff Body Rider Fan Bike BRF700
HOW TO FIX COMPUTER MONITOR?
The computer won't register numbers. Does not need new batteries - shows all zeros all the time.
Camera only works when charger is plugged into it, the battery is showing 3.4 volts of charge, is the camera at fault and can it be fixed cheaply?
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 24, 2012 | Pentax Optio Cameras
Computer just shuts off when i unplug even though shows full battery
POWER SUPPLY & BATTERY PROBLEM
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Jul 07, 2012 | Sony VAIO VPCF134FX/B F Series Notebook
Computer shuts off when battery reduces to 92%
Jun 22, 2012 | Fujitsu Siemens Computers & Internet
Help with mobile phone
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
May 19, 2012 | Sony Ericsson Xperia Arc S
Sony vaio vgn-nr285E battery won't hold a charge
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 03, 2011 | Sony VAIO VGN-NR285E/T Laptop
Agptek replacement battery not working
Nov 20, 2011 | Toshiba Satellite M115-S1061 Notebook
I have acer aspire 4741z, when I plug the battery charger, it says plugged in, not charging (6% available). how can I fix this problem? thanks a lot
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jul 07, 2011 | Acer Aspire 4730-4947 Notebook
Inspiron mini 10 Running on battery even when a/c is plugged in restart computer and plug in a/c again and charges up but then drains battery again
Jul 07, 2011 | Dell Inspiron Mini 10 Notebook
Ok i have a Ibm thinkpad and my charger is stuck on green battery but it wont charge at all. It was working earlier but i turned of the computer the wrong way by holding the power button since i was in a...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 18, 2011 | IBM ThinkPad T30 2366 Notebook
A320s battery has full charge , tested with volt meter. computer shows 6% battery
May 08, 2011 | Getac A320S PC Notebook
WowCoolStuff Body Rider Fan Bike BRF700 Logo
35 people viewed this question
Top WowCoolStuff Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a WowCoolStuff Exercise and Fitnes Expert? Answer questions, earn points and help others
