Question about BH FITNESS Select Series T8 Sport Treadmill
Treadmill motor won't come on - BH FITNESS Select Series T8 Sport Treadmill
My fan won't work on my nordictrack 4400R treadmill. What should I do to get it working.
please test the voltage in the motor fan with DVOM. IF There are voltage , and the motor is NOT running , replace it.
However you must tight very well all the connectors. Test the fuse in the treadmill see the block diagrams attached for troubleshooting.
God bless you
Jan 09, 2013 | Exercise & Fitness
Mi fan won't work on my nordictrack 4400R treadmill
test the input voltage motor fan, If there are replace the fan motor.
However you must tight all connector, test the fuse+c.breaker.
See the diagrams attached for troubleshooting guide.
God bless you
The treadmill on my Roger Black Gold Treadmill won't move when the power is on. The board lights up and the incline etc works but the treadmill just won't move. Can anyone help me please?
please see the video and proceed according, LUBE the rollers bearing very IMPORTANT!
However , if the problem persist your must test a) main motor+belt
b) main control motor board see the block diagram attached.
God bless you
Jan 04, 2013 | Exercise & Fitness
My Reebok v6.80 treadmill turns and lights up but won't go.
1) LUBE the deck belt,you have a WORN deck belt, this happen because you didnot lube according with the schedule maintenance
29 LUBE the rollers bearing too
3) Test the drive belt motor, for worn or crack, or adjust if is possible
4) Test the input voltage motor, if there are the motor need repair
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Nov 28, 2012 | New Balance 1400 Treadmill
My treadmill won't run, but turns on
It sounds to me like during its move the drive belt came off off the motor that connects the motor to the walking surface. If the motor is not running at all after checking that I would look for a reset on the motor itself and check all connections. Not likely that the motor is fried but that would be the last in line for checking.
Aug 31, 2012 | Proform Exercise & Fitness
My treadmill life fitness 9100HR won't start
Have you checked the drive belt @ the motor, if it is OK then check the fuse, if it is ok then the brushes in the motor may be worn out
May 04, 2012 | Life Fitness T3 Treadmill with Advanced...
My treadmill nordatrac c2500 won't incline need a
Dear Sir:
There many possibilities: 1( False signal to due flexible cable loose *tight( 2( console display faulty 3(main motor board faulty 4(the pot attached to the elevation motor need adjustment 5( the gearing can sliping 6( Main motor damaged.
Try to RUN the software calibration for easy diagnose and trouble.
See my personal TIPS for HELP.
sincerely. God Bless you.
ernesto cuadra
managua, nicaragua. c.a
Mar 12, 2012 | Nordic Track Exercise & Fitness
My ultrafit treadmill won't run-the control panel
2_15_2012_4_45_37_pm.gifAdjust the reed switch as indicated by the diagram by 1/8- 1/4". Run the calibration software instruction under the Hood motor or see your user manual.
sincerely.
ernesto cuadra
managua, nicaragua. c.a.
Feb 13, 2012 | Exercise & Fitness
My treadmill is brand new and not coming on
Hi ispeaktobefr,
Please check the following:
1. Please make sure that the battery is fully charged, because it won't work if not.
2. If the motor turns slowly then your motor is ok, if not the motor is bad and would need to be replaced.
3. If the motor is ok then the motor controller ( the board with the metal ) is malfunctioning and would need to be replaced.
4. You may also check the fuse.
Hope it helps.
Thank you for using FixYa.
Jul 14, 2011 | Weslo Cadence 60 SE Treadmill
BH FITNESS Select Series T8 Sport Treadmill Logo
18 people viewed this question
Top Bh Fitness Exercise & Fitness Experts
Andrew Taylor
Andrew Taylor
Bill Boyd
Tom Chichester
Are you a Bh Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
