Question about RCA TruFlat 27F520T 27" TV
Visio l41hdtv10a turns off and on much slower tuner rarely clicks on
How do I add the HD channels picked up my HD antenna to the master channel list on my Visio TV?
Hello, with the set on, press the menu button, move the cursor down till the "Tuner" section is hi-lighted, click on it. Then the first selection is "Tuner Mode" click on it, the choose "Antenna" click on it. Then move to the "Auto Channel Scan" and click on it, and let it set all your channels. when done, just exit menu and change channels as desired. you can go to page 39 in your manual for these instructions: Tuner Mode
Select Cable or Antenna depending
upon which equipment you have
attached to the DTV / TV Input.
Auto Channel Search
Automatically search for TV channels
that are available in your area. Be
sure to first select the correct tuner
mode above. The TV will search for
analog and digital channels. When the
search is done, press EXIT to begin
watching your programs. thanks, Terry
Oct 09, 2012 | Vizio M220NV 22 in. LCD TV
Microsoft visio product key
Microsoft Office Project Professional 2007
BHFYK-9RTKR-RV3J6-X669J-XQ3Q8
DOWNLOAD Microsoft Office Visio Professional for Free @ http://bit.ly/dd4w0u , Click on this Link to Visit Download Page and Start Downloading this Software 100% Works.
Microsoft Office Visio Professional 2007
hope it helps
May 09, 2012 | Microsoft Office Visio Professional 2007...
Why do the lower channels not work on my Visio tv?
Might be a truner trouble. Check all the voltages at the terminals of the tuner to your tV.
May 08, 2012 | Televison & Video
My rca hd52w58 on autoscan will only find 4hannels MY Visio fines 38 suspect digital tuner any suggeationas?
Could be a tuner but a simple way to find out is DIRECT ENTER with the remote (numbers) a channel and hit enter---if it goes to missing channel you can manually in the menu with the remote ADD each missing channel one at a time--tedious but will rule the tuner out.
Almost every set made is able to add or delete channels one at a time.
Apr 15, 2012 | RCA HD52W59 HDTV Projection Television
I get error 114 when trying to open a Visio file with Visio 2000. The helpline number 0800 834859 is defunct.
Either upgrade to the latest version of Visio, or have whoever created the drawing resave the file in the Visio 5.0 format.
To save a Visio 2000 drawing in the Visio 5.0 format:
  1. Open the Visio 2000 drawing.
  2. On the File menu, click Save As.
  3. In the Save as Type box, click Visio 5 Drawing (*.vsd), and then click Save.
May 11, 2011 | Microsoft Visio 2000 Standard for PC
My Visio 50" Plasma Model#
Have you removed the back and looked for Bad Capaciotrs on the power supply board?
Capaciotrs will be vented or puffed up on Top. 1000uf 16v,2200uf 10v 3300uf 10v etc....
Feb 17, 2011 | Vizio P50HDTV10A 50 in. Plasma HDTV
I recently bought a Korg Pitchblack Tuner. It tunes correctly, (maybe a little slower than my Boss) but it will not power other pedals with the daisy chain. I am using a standard Boss wall wart which...
The tuner uses around 500 ma which may be nearly all your wall wart can put out... DO NOT overload the power adapter by daisy chaining other pedal power loads on it.
Feb 08, 2011 | Korg pitchblack + Tuner
Visio file association
- in windows explorer right click over the file and choose Open with... and then browse for and choose the viewer program
Apr 03, 2009 | Visio Technical 4.5 Full Version for PC
Convert CAD (DWG) to Visio Drawings
You can import graphics files of different formats to start a new Visio drawing by using the Open command on the File menu.
The following graphics file formats are supported:
  • AutoCAD Drawing File Format (.dwg, .dxf)
  • Compressed Enhanced Metafile (.emz)
  • Enhanced Metafile (.emf)
  • Graphics Interchange Format (.gif)
  • JPEG File Interchange Format (.jpg)
  • Portable Network Graphics (.png)
  • Scalable Vector Graphics Drawing (.svg, .svgz)
  • Tag Image File Format (.tif, .tiff)
  • Windows Bitmap (.bmp, .dib)
  • Windows Metafile (.wmf)
Note File formats may vary slightly between language versions. You may not get exactly the same results if you import files created in different language versions.
  1. On the File menu, click Open.
  2. In the Files of type box, click the file format of the file you want to import.
If you don't see the file format listed, Visio doesn't have a file filter for that format. Try saving the document in a format Visio can open.
Dec 28, 2007 | Computers & Internet
RCA TruFlat  27F520T 27" TV Logo
14 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
