Question about Canon PIXMA iP90 Mobile Printer
What does canon ip90 support code 69 mean? - Canon PIXMA iP90 Mobile Printer
2 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: What does service code 5100 mean on the Canon iP90
Hi there you can try.
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off.
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indicator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. Otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 25, 2010
Error 69
Do you mean error 99? An error 69 is not listed in the manual. Error 99 mainly occurs with non-canon lenses, and indicates a communication problem between body and lens. Which still does mean nothing more than: it could be anything... Try cleaning the contacts. Or mounting another lens.
Mar 27, 2014 | Canon Cameras
I have PIXMA iP90 printer but having problem of not printing blank test,I mean if i change the text colour to blue or any different colout it prints but not with black ink
This seems to be a comon problem with canon printers the black head is either dirty or needs to be replaced. canon should look into this
to clean heads use rubbing alcohol, cotton swab
put some rubbing alcohol on the cotton swab and gently rub the black portion of the head until it is clean
Mar 06, 2011 | Canon PIXMA iP90 Mobile Printer
I have one printer canon Pixma IP90. Please advise me to solved : "Canon PIXMA iP90 Service error 5100". Thanks so much !
Hello thanks for using FixYa
Error 5100 means that the cartridge can not be detected by the printer. Actually the printer is not actually loading the cartridge and showing you the error 5100.
To solve these follow the following steps. I hope it works
  • Turn off printer
  • Remove both the cartridges from the printer
  • Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  • Return the cartridges
  • Turn on the printer.
Error will be removed
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jan 29, 2011 | Canon PIXMA iP90 Mobile Printer
Canon pixma ip90 printer is not printing blue colours. i've tried cleaning but it doesn't work.
If the blue ink cartridge is not empty, then it means that either the pront head or the ink cartridge is clogged. Here are some information about ink cartridge cleaning, and here you can find some information about print head cleaning.
Nov 24, 2010 | Canon PIXMA iP90 Mobile Printer
What does service code 5100 mean on the Canon iP90 inkjet printer? When I try to print anything this is the message I get
Dec 23, 2009 | Canon PIXMA iP90 InkJet Printer
Would not print, oraqnge light blinks 5 times then one green flash. Open the door to ink and the head does not move to center as it used to.
This is a waste ink code and needs to be reset. follow instructions below.
Canon pixma iP90 released almost at the same time with canon Pixma iP 1880. Canon iP90 is printer with single function. Cartidges which used in canon Pixma iP90 is BCI-15BK, BCI-115C dan BCI-16C. Resetting procedure canon iP90 almost the same as manual reset canon iP1880. You can use combination of button in the printer to reset the printer.
  • Before resetting printer canon iP90, start with printer power off .
  • Green LED indocator will blinking and then stopped blinking.
  • Press power button and the printer power will off. otherwise off, depress again power button.
Please rate my help++++Thanks for using FIXYA
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Nov 24, 2009 | Canon PIXMA iP90 Mobile Printer
CANNON IP 90 PRINTER PROB: ink try full. how do i clean it? i saw instructions on resetting codes. it will not print at all...HELP...Thank You!
How to Reset The Canon Pixma iP90 PrinterHere is the reset procedure for the Canon iP90 printer, which uses the BCI-15BK, BCI-115C and BCI-16C cartridges.
Just follow these step by step instructions, to reset the Canon Pixma iP90 printer
  1. Turn printer OFF.
  2. Press the RESUME button together with the POWER on button.
  3. While pressing POWER on button, RELEASE the RESUME button.
  4. Press RESUME button TWICE then release both buttons.
  5. The green LED indicator will start blinking, then stop.
  6. Wait until the Power LED lights are green, then press the RESUME button 4 times.
  7. Now press POWER button OFF.
  8. Turn printer ON again, your Canon iP90 printer should now respond normally.
  9. If you need to unclog your print head click on next line
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
Tinteiros Magic Inkjet Flush Kits (Ebay)
Sep 12, 2009 | Canon PIXMA iP90 Mobile Printer
IP90 Canon Printer shows error code 5100: How do I fix it?
This means there is something jamming the mechanism. You should take it to a repair specialist or do your best to check for blockages yourself. It can be the tinest little thing. Check everywhere!
Sep 01, 2009 | Canon PIXMA iP90 Mobile Printer
Canon PIXMA iP90 Mobile Printer Logo
21 people viewed this question
old marine
old marine
