Question about Drills
Do you know belt sizes for a master craft drill press model #55-5916-2
5 Suggested Answers
al_kupchella
  • 843 Answers
SOURCE: I have an old Guardian Power floor model drill press and do not know how to change belt positions to change speed. help please.
See the picture below. The small red circle shows the locking screw on the right side of the drill. There is another locking screw on the left side of the drill. Loosen them both a half turn. The larger red oval is the handle to pull the motor closer to the spindle, thereby loosening the belt. Once loosened, it is easy to move the belt. Then use the handle to push the motor back, which tightens the belt. Keep pushing on that handle with your right hand while you tighten the locking screw on the left side of the drill with your left hand. Once you have that tight then tighten the right side locking screw.
Good luck! I hope this helps.
Posted on Jul 18, 2012
SOURCE: installing belts on a master craft lawn tractor 15.5hp model 13AD678G515
your question was put in the sewing machine catagory
if you put it in the lawn mower or lawn tractor catagory someone can help you
Posted on Aug 27, 2012
  • 15633 Answers
SOURCE: What is the Chuck Taper Size? MasterForce model # 240-0064 12" Drill press
Masterforce is no longer supplier of power tools, they are a cheaper line of Makita, and maybe craftsman.
Posted on Jan 08, 2016
  • 42623 Answers
SOURCE: i have master craft drill its chunkhead is not working i want to replace it. so where i can purchase
any tool shop or hardware shop sells chucks for drills
Posted on Jun 25, 2017
How do you change the speed on a value craft 12 speed drill press
Most drill press' have cover on the top when opened expose two different sized pulleys. Speed is adjusted by changing to different combinations. The speed is usually shown inside the lid on a chart with the different combinations of pulleys. Hope this helps.
Aug 23, 2017 | Speed Drills
Where can I get a rack retaining ring for a 12" master force drill press
you may not be able to master force looks like they are discontinued
cant find any parts supplier for them
may need an engineering shop to make one for you
Apr 30, 2016 | MasterForce 12" Drill Press
I have no belts on this drill press and can't seem to find the size or length of them
You don't give make and model, but a quick look shows these links. For length, pull string tight around the pulleys with slipknot. Use the pulley release lever to remove the string, cut it and pull it taught. Measure the length and subtract a half inch. With a make and model, it would be easy.
http://www.bing.com/search?q=drill+press+drive+belts&qs=n&form=QBRE&pq=drill+press+drive+belts&sc=0-16&sp=-1&sk=&cvid=26514024d4d84952af826318901d12f9
Sep 12, 2015 | Drills
How can I find manual for value craft drill press 5 speed MFG 89C?
find all the numbers on it and a picture,they arent worth that much,have a feeling they are value craft 8100,or this, http://powertool.manualsonline.com/manuals/mfg/harbor_freight_tools/38144.html?p=1
Jun 04, 2015 | Drills
Hi I have a peerless pedestal drill press model #1516f. I cannot find the replacement belt sizes for the 2 belts? Can anyone help? Cheers Jason
hi jason try going to a car fan belt specialist ,, one that stocks many sizes..take your old ones in to match them with.. as an example search on line as i don't know where you are i can not give more specific info on location.. as an example this web site http://www.totalrubber.com.au/
or try repco car spare parts
Rubber Hose PVC Hose Rubber Matting
i assume your belt is an "A" size
regards pete
Feb 26, 2015 | Drills
Where can I find the old model master craft batterys
If you do a local online search, you can probably find a battery store that will either provide you with a new one or rebuild your current one.
IMO, just watch the sales, you'll probably find a drill/battery/charger a lot cheaper than going the battery store route.
Jan 25, 2015 | Drills
GLENTANNER MODEL ZQ116 DRILL PRESS. how do Iknow what size belts are as they are old, cracked and frayed.
Your best bet is to take the old belt with you when you shop for a new one. The sales clerk should be able to match it up.
Nov 26, 2014 | Drills
Changing speeds on Powermatic Drill Press
Katie,
Refer to the picture below. Loosen the locknuts (the one on the right side of the drill is shown, there is another on the left side). Use the lever to move the motor toward you, thereby loosening the drive belt(s). Open the top cover to expose the belt(s) and sheaves (most people incorrectly call them pulleys). You might have one belt and two sheaves, or you have two belts and three sheaves. The drill will go fastest when the belt is on the biggest motor sheave and the smallest sheave on the drill spindle. Of course the opposite sizes apply for the slowest speeds. Make sure the belt uses a pair of sheaves that are at the same height as each other (the belt has to stay in one plane). Now tighten the belt(s) by pushing the lever pretty hard away from you, and while holding it with your right hand tighten the left side locknut with your left hand. Now tighten the right locknut. Close the cover. ----- OK, so now you know how to CHANGE speeds, what about drilling glass? This can be tricky. You must use a pretty slow speed (maybe the slowest, depending on the size of hole you are drilling. And you must keep the spot you are drilling flooded with water to keep the glass cool. And you must apply pretty gentle pressure. And the use of a drill bit intended for drilling glass helps a lot. And don't try the first hole in something expensive! Practice on something disposable first. Take your time. AND WEAR SAFETY GLASSES!
Jun 15, 2012 | Powermatic Drills
Hi, We have a C188FX Journeyman drill press but no manual. we don't know how to change the speed. Can you help? We would like to find a manual for future questions as well.
Open the top and move the belt to different wheels. There are different size wheels the belt rides on for multible speeds.
Jan 23, 2011 | Drills
Drill Presses Models
When shopping for a drill press, you'll have to choose between two basic models: 1. Bench-top drill presses mount directly to a workbench or on their own stands. Their compact size makes bench-top models good choices for small shops. 2. Floor-model drill presses usually have more powerful motors, more attachments/accessories and greater material handling capacities than bench-tops. The extra versatility makes floor models good choices for serious DIY and commercial shops.
Aug 27, 2008 | Dewalt Delta DP300L 12" Twinlaser...
Drills Logo
54 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
