Question about Car Audio & Video
Brocken Audiophase CA-813 stereo plate
The radio itself works but the plate is damaged does anyone know where I can get this fixed somewhere near my home in brooklyn NY usa or a place I can buy for $10-$15 dollars
  • Marvin
    Marvin May 11, 2010
    at a radio repair shop
  • 20 Answers
If your talking about the face of the radio then you'll have to take it to a car audio place and get them to send it away, if you want a new one then you'll have to spend afew more bucks , a new one ( I heard) is about $100
Posted on Jun 23, 2009
I have a cd/radio player from a 200 dodge van, and I want to put it in my 1998 Ram truck ?
If the radios do not have the same connections on them, you can buy a wiring harness from a car stereo dealer in your area. If you are lucky, the radios will have the same connectors, and the one radio will just plug into the other vehicle and work fine. cd-radio-player-from-200-dodge-van-want-21syibu3fgwpdxocjnkpw0ib-3-0.jpg cd-radio-player-from-200-dodge-van-want-21syibu3fgwpdxocjnkpw0ib-3-1.jpg cd-radio-player-from-200-dodge-van-want-21syibu3fgwpdxocjnkpw0ib-3-2.jpg
Dec 09, 2014 | Dodge Cars & Trucks
Radio or speakers don't work
Betting that you've got a wiring issue on the back of the radio. Pull the stereo & check your connections. Somewhere the speaker wires came loose.
Nov 08, 2013 | 2002 Nissan Xterra
CAN YOU HELP ME?
Check the internal radio fuse or replace radio. If it is the internal fuse INSIDE the stereo itself, you will need to check the ground wires from the radio. Electrical problems are almost always caused by a bad or corroded ground wire somewhere.
Feb 16, 2012 | 1991 Lexus LS 400
What's your problem?have a problem with security code. The stereo cannot work without the access code. Can anyone help me please? Is there a universal security code? Thank you muamar m. pontino
No there's no universal security code. First, check your car user guide and your radio user guide if you have one, see if the code has been written down in the back somewhere.
or
There are usually plenty of Auto electronic engineers / fitters who provide this service. Have a look in the phone book for one near you.
They can also be cleared on line:- http://www.radio-code.co.uk/
or :- http://www.sws-solutions.co.uk/radio_coverage.php
Finally, you could google "Car Radio Codes" see if there's a site you prefer.
Jan 30, 2012 | Car Audio & Video
Anyone help I need the radio code for peugeot 206 51 plate serial code for stereo CL0410269200, thanks
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio
Jul 05, 2011 | Interface Adapter For Stereos
Radio was working great today, then bam it quit. Checked the fuse found it blew(10amp) replaced it. Tried to power up the radio NOTHING... Checked ground wiring,it's fine, checked two other fuses fine....
If you already have your dash apart, have you looked for a fuse directly on the radio itself? There should be one somewhere near the power wiring on the back of it. If this is blown, you will be getting power to the wiring, but not to the radio. Replacing this fuse should help you out.
If this is not the problem, use a voltmeter to check the wiring where it goes into your stereo. If there is no power here, then the power overload that blew your 10amp fuse is probably related to a short circuit somewhere in the wiring between the fuse and the stereo. To repair this, you will likely have to run a few new power wires (you should replace both the positive and negative to make sure you have fully bypassed the problem) from the fuse to the stereo. If you have checked these wires with a voltmeter and they have power at the back of the stereo, but the stereo itself is not still not working, then the problem is with the stereo itself.
If you find that the wiring to the stereo all has power ... the fuses are all good (which you have already stated) ... the fuse on the stereo itself is in good shape ... then there might be a short within the workings of the stereo itself. If you are not experienced with repairing electronics this could be out of your ability to fix -- you can bring it to a shop or buy a replacement. If you are experienced with repairing electronics, open up the stereo and start checking the wiring (starting from the closest point to the power input and moving towards the stereo's face. This could be a long and arduous process ... so if you are not experienced with it ... I recommend taking it to a professional or just replacing it (your hair is probably worth more than the $100 you would spend on a decent replacement stereo ... and if you are like me, you would be ripping out your hair after checking the first few hundred possible connections within the stereo itself).
Hopefully it is just the fuse on the back of the stereo itself, and you can have that fixed in short order. Good luck!
Jun 07, 2011 | Car Audio & Video
It say's intrrupt
Do you have a radio removal tool set that you can use or borrow? I so double check that the antenna hasn't come out of the unit and that it is not chaffed and grounding out on the body somewhere. Is there any noise at all when switched to radio or does the unit become inactive.
May 08, 2009 | Alpine CDA-7892 CD Player
Install Aftermarket Stereo in 1998 Mercury Sable
You need to buy a radio from Best Buy or somewhere. Installing on a Sable is not easy because your radio face plate is in the front but the tuner itself is located in the trunk and you need to run wires from the dash to the trunk. You need to buy a radio and $80 parts kit, but I promise it is not an easy install unless you are familiar with car audio and running wires through cars.
Dec 01, 2008 | Car Audio & Video
Stereo removal 06 cobalt
you must remove all the plastic face plates around the radio then remove the radio itself.be cautious as you could damage the clips that hold the plates in place.
May 14, 2008 | 2006 Chevrolet Cobalt
Users Manual for a Adiophase CA-813 Automobile Radio/CD Player
i have an audiophase dm9804 cd player. i can't change tracks. help!
Dec 27, 2007 | Audiophase MDP-1 Personal MiniDisc Player
Car Audio & Video Logo
91 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
