Question about Frigidaire FGMV185K Microwave Oven
EVERYTHING WORKS CLOCK BUT IT WILL NOT HEAT ANYTHING
I moved my microwave with it plugged up, and it comes on, clock and everything works but it's not heating anything
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Aug 16, 2010 | GE Microwave Ovens
Doesn't heat anything
It sounds like the micro generator has died.
Yes, you should buy a new one as the cost of repair is likely to be high.
Jul 01, 2010 | Amana ACO1860 Microwave Oven
No Heat but everything else works
Magnetron and diode most likely. Need more info.
Nov 02, 2009 | GE XL1800 1100 Watts Microwave Oven
Everything on our microwave still works( Clock,lights, fan) except it will no longer heat anything you put in it
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Oct 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Everything else works but will not heat anything. Clock works,glass plate turns,exhaust fan runs, lights work, just no heat.
Im assuming you dont have testing equipment. The best solution is to replace the capacitor and HV diode. Good chance that is the problem. If no heat still, replace the magnatron, definately will work correctly.(Sorry, to much to explaine otherwise relating to measurement and values). Let me know if still notright).
Sep 27, 2009 | GE JVM1410 Microwave Oven
Microwave Smokes
the problem is in the magnetron try to replace it.
Jan 27, 2009 | GE JVM1660 Microwave Oven
Microwave oven does not heat anything. Clock, turntable, lights work. I turned the turntable off while the oven was cooking--heard a noise, now it doesn't heat anything.
Spacemaker XL 1400 worked for 7 years.Yesterday, no more heat. Also plastic door damaged.
will try Panasonic or something commercial
Jul 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Frigidaire FGMV185K Microwave Oven Logo
18 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
