Question about Sta Rite Sta - Rite Mod Media 450 Sq Ft Cartridge Filter and 1.5 Hp Pump System
Need owners manual or at least a diagram for StaRite pool filter
Just bought a house with a StaRite System 3 Filter model S7MD90. It is a DE filter installed by the previous owner who was allegedly a pool contractor. Sadly, he lost the home to foreclosure.
I desire to understand the purpose of the two orifices at the BOTTOM of the pump (both of which have Jandys on them) and I thought an owners manual might be the ticket.
Anyone know where I might find one or at least a schematic?
TIA
  • 83 Answers
If you follow this link, it will take you to an Owner's Manual online for the S7MD filters. The filters are the same, just the size of the filtration material is the difference in Model Numbers. Have not heard of the S7MD90 before.
http://www.pentairpool.com/pdfs/System3SMDOM.pdf
This manual is for the filter only. If have the model number for your pump, you can see if it is online at:
http://www.pentairpool.com/techinfo/datasheets2.php?d=2
Posted on Jul 07, 2009
  • 93 Answers
TRY POOLCENTER.COM PARTS
Posted on Jun 19, 2009
Pool plumbing diagram
You may experience a little pressure loss, but if the catridge fliter housing has a 1 1/2 input you should be fine.
Jul 17, 2014 | Pentair Clean and Clear Cartridge Filter...
We are the owners of a pool, we just bought the house. The multiport valve is old enough you can't read what is on top of it. We don't know where to turn it for the different shcematics. Never...
you can purchase a new label for the valve. Notice that on the valve and on the label there is a small notch...this is to align the label to the valve functions. Caution: Depending on the Hayward model the label could be a dual purpose one..ie. D.E. filter or Sand filter so be careful which notch you align.
Jul 21, 2011 | Hayward SAND FILTER, PRO SERIES
I'm replacing the diaphagm on my ce40filter. Does it need gasket cement
No, you should not have to use cement to install the diaphragm gasket on these particular pool filters. Here is a copy of the owners manual for this model. It has a diagram of construction in case you need it to figure out how to get the replacement part on the filter.
May 08, 2011 | Hayward EC-40 DE Pool Filter with pump
Pentair Quad DE system was installed without multiport valve
This is a DE (Diatomaceous earth) IT doesn't have sand and doesn't backwash. You use the bump handle (with pump off and valves closed and vent open and drain dirty water/earth out) Here is a link to the manual for your filter If isn't the exact model they are all on their web site: http://www.haywardnet.com/products/Manuals/pdfs/manual9.pdf
Jul 20, 2010 | Hayward EC-40 DE Pool Filter with pump
I bought a used Hayward Perflex Extended Cycle DE Filter Model#EC45 I have to keep backwashing it, it flows heavily back in the return but it only flows good for a little while. What do I need to do? It...
Here is a link to the hayward manual. Be sure to follow the pre-coating insturctions carefully.
Use only the swimming pool grades of
diatomite, such as:
CELATOM . . . . . . . . . . . Eagle-Picher Industries, Inc.
AQUA-CEL . . . . . . . . . . Johns-Manville Products Corporation
DICALITE 4200 . . . . . . . Grefco, Inc.
WITCO . . . . . . . . . . . . . Witco Corporation
The EC-50 filter uses a 5 lb. (2.3 kgs.) charge of diatomite (D.E.)
Here is a link to the hayward manual for a EC-50 I think its almost the same as the EC-45
http://www.haywardnet.com/products/manuals/pdfs/manual10.pdf
Jul 01, 2010 | Hayward EC-40 DE Pool Filter with pump
I bought a house this winter that had a pool and i have no idea how to set up the filter we tried to get the previous owners to show us when we bought the house but they were not very cooperative
Here is a copy of the users manual for these pool filters. It has a detailed drawing of how the filter should be assembled and set up. Hope this helps!
http://www.backyardcitypools.com/images/bwp/carefree-manual.pdf
Jun 05, 2010 | Waterway Clear Water 22" Sand Filter...
Water and de backflo into motor from filter
Try checking the users manual. I don't have an exact answer for you, unfortunately, but the users manual for these pool filters is comprehensive and has diagrams. Hopefully, you can find your answer there.
http://www.backyardcitypools.com/images/hayward/perflex-system-manual.pdf
Jun 02, 2010 | Hayward EC-40 DE Pool Filter with pump
We have aEC-65 hayward pool filter with a 1HP motor why does the pump slow down run at higher pressure ?
I believe that this particular model is a DE pool filter. Is that correct? If you are operating with a media other than DE, let me know. Assuming that you ARE using DE:
1. You DE could be coated to the maximum with pool dirt algae, etc. To correc this problem, you need to bump the filter.
2. You could have an overcharge of DE. To remedy,
Bump-Drain-Recharge.
3. Restriction in return line caused by small
eyeball fitting. To correct, change to a larger sized fitting.
4. You could have a partial closed valve on a return line. You will just need to open the valve.
5. Make sure that your pump strainer basket and pool skimmer basket are not clogged.
6. Make sure that your pump impeller valves are not clogged.
May 25, 2010 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
Pool pump inflow/outflow handles and their position?
GO TO YOUR LOCAL POOL STORE AND SEE IF THEY HAVE A SIMILAR UNIT . IF THE FLOW IS NOT GOOD YOU MAY NEED A NEW DIFFUSER $20... .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 23, 2010 | Sta Rite 1 HP StaRite Pump 15" inout...
Sta Rite Sta - Rite Mod Media 450 Sq Ft Cartridge Filter and 1.5 Hp Pump System Logo
251 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
