Question about Juicers
Santos juicer Loads of pulp is coming out with the juice
    Problem Solver:
  • 7 Answers
Unfortunately, some juicers do let pulp through which is annoying. The only thing to do is use a strainer to get rid of it or a nut milk bag which really gives a nice smooth/silky juice. You should be able to get the bags on amazon/ebay or similar sites.
Posted on May 08, 2014
Couple of things to look at
1 check the grating blade. Maybe clogged therefore need cleaning or need replacing due to bluntness
2 motor may be slipping true to overload. Place fruit in a little at a time
hope this helps
sweetymommy
  • 4 Answers
SOURCE: wheatgrass juicing problems
Hi, I have an Omega juicer, and I've never had this happen. I recommend that you double check to see if you have the right parts attached. It comes with two inserts, one with a small metal screen on the bottom, the other has no screen, it is solid. The solid one is for crushing and proccessing food. The one with the screen is used for juicing. Make sure you have the correct one installed. If that is not the problem, I think perhaps the grass is too dry? Maybe there isn't enough moisture in it to extract much. I really can't say, though. Try juicing something else, like carrots, and see if you can get some juice there. If all else fails, contact Omega at their website. They have terrific customer service. I've tested it already with a warranty replacement.
Posted on Aug 06, 2007
  • 6 Answers
SOURCE: Juidelady jl500 juicer replacement parts
I also have a Juicelady, & need a part(s) HEre is a probable solution to your problem!
In the U.S.A. or Canada call 1-800-233-9054 to order the part. Or see if they have it in stock.They will ask for your address & phone number. Have your serial number ready-it should be on the bottom (or possibly the side) and you may need a magnifying glass to read it! It starts with the letters JL, and mine was JL500 (so look for that-but your may be a different model, I gave you mine so you have an idea of what to look for.)
Note: Anywhere else, or to check them out online:
The same warehouse is also at foxinternational.com if you'd rather see what they offer that way--but we got our call answered after waiting les than a minute. They even had the part we require but won't ship to Canada, so if your Canadian--call anyway, as it is a different part than we required,( the arms that brace the unit together.)
Hope this was helpful for you!
Posted on Oct 21, 2008
SOURCE: wet pulp
There are two almost identical cone-shaped parts, one with metal screening and one solid dark plastic (I'm going by the parts color appearance of my 8003 model). Be sure you're using the one with the screen, otherwise the juice has nowhere to go but out with the pulp.
Posted on Dec 23, 2008
  • 356 Answers
SOURCE: Breville Juicer not juicing properly
MY WIFE HAS ONE AND IT'S LIKE A LOOSE CANNON. IF IT IS LEAKING FEED IT
VERY SLOWLY.
Posted on Jun 30, 2009
  • 356 Answers
SOURCE: The reset button
IT'S THE RESET BUTTON AND THEY ARE
ADJUSTABLE. REMOVE 4 SCREWS UNDER
JUICER TO REMOVE BOTTOM. YOU CAN
GET AT THE RESET BUTTON HOUSING AND
ADJUST THE SMALL SCREW EITHER WAY.
YOU WILL HAVE TO FIGURE OUT WHICH
DIRECTION. CLOCKWISE OR COUNTER.
IT YOU GET IT WRONG IT WILL CUT OUT
MORE FREQUENTLY SO JUST GO THE
OTHER WAY.
Pulp is building up, not ejecting properly
When juicing with the champion juicer take it slow. You need to hold down the tamper for three to five seconds in-between reloading the chute. Otherwise it will begin to back up through the chute and the juicer will begin to heat up. Happy juicing! LivingaHealthyandHappyLife.com
Mar 07, 2012 | Champion G5NG853S 540 Watts Juicer
Can't find the manual and have forgotten how to take it apart to clean it
Most juicers have a retention rod or side snaps that hold the top of the juicer in place. By loosening these, it will allow you to get underneath the juicer cap top. Once you have done this, you will have to remove the juice/ pulp wheel blade. Your juicer should have come with a two pin tool that facilitates this. Use the tool to loosen the juice /pulp wheel blade. Once you have done this, you should be able to remove the outer juice capture rim with that has the spout on one end. I hope this helps. Good luck and happy juicing.
Jul 18, 2010 | Juicers
Too much pulp in juice
You need a new slicer with a finer mesh.
Dec 29, 2009 | Waring JEX450 850 Watts Juicer
Juicer works fine until slight pulp build up in
Unfortunately, since these juicers do not eject the pulp, they will tend to go out
of balance. Juice nothing softer than apples and try to feed it as evenly and as
slowly as possible.
Nov 27, 2009 | Acme 6001 Juice Extractor
Shuts itself off when juicing
FIRST DUMP THE FILTERS, THEY DECREASE YIELD AND MAY CAUSE MORE VIBRATION.
IF JUICER SHUTS DOWN PUSH RESET BUTTON ON BOTTOM. THIS TYPE OF JUICER DOES
NOT EJECT PULP AND REQUIRES SOME TIME TO MASTER. FEED THE STUFF SLOW AND
STEADY. WANT A GOOD JUICE? TRY 1 APPLE, 2 CARROTS, 2 CELERY AND A HALF LEMON.
IF YOU ARE REALLY BRAVE YOU CAN FINISH OFF BY SLOWLY POURING 6 OR 8 OUNCERS
OF WATER RIGHT DOWN THE CHUTE. THIS NOT ONLY DILUTES BUT LEECHES MORE JUICE
OUT OF THE PULP. JUICE SHOULD BE DILUTED AND DRANK SLOWLY.
Feb 27, 2009 | Acme 5001 Supreme Juicerator Juice...
Pulp galore!
are you exceeding the capacity of the juicer? you will get about 2 and 1/2 large glasses of juice before the pulp fills the spinning basket. Apple peels are very tough, apples and tomatoes need to be peeled before juicing. Use the filters, the juice comes out much clearer and the juicer is easier to clean up. I so a lot of carrots, carrots are super food.
Nov 21, 2008 | Acme 6001 Juice Extractor
Wet pulp
Jan 05, 2008 | Omega 8005 Juicer
DOES NOT ROTATE
What type of juicer is this any model number?
if motor turn on and shaft rotate it should work is that the case?
Oct 13, 2007 | Matfer SANTOS Juicer
Juicers Logo
60 people viewed this question
Top Juicers Experts
Tom Chichester
David Payne
David Payne
Are you a Juicer Expert? Answer questions, earn points and help others
