Question about Archos 80 Titanium HD 8" Android 4.1 Tablet, Dual Core 1.6GHz, 1GB RAM, 8GB Memory
Can,t save to sd card only internal archos 80
  • Archos Master
  • 5,631 Answers
Presume you should have a driver installed in the computer
Posted on Jan 08, 2015
How do I set my LG L164VL to save to SD card instead of Internal Memory Phone runs on Nougat 7.0
How to turn external SD card into internal storage
1. Go to device "Settings", then select "Storage".
2. Select your "SD Card", then tap the "three-dot menu" (top-right), now select "Settings" from in there.
3. Now select "Format as internal", and then "Erase & Format".
4. Your SD Card will now be formatted as internal storage.
5. Reboot your phone.
Dec 28, 2017 | LG Cell Phones
My straight talk phone H866C says low internal memory. Do I need to up grade my sd card?
An internal memory is different than your sd card. You can try moving some apps that you have saved on your phones internal memory to the sd card or just leave it as is and start saving new apps/contacts to the sd card rather than the internal memory. You may need to delete some programs from the internal memory to free up room, but you can always redownload and save it to the sd card instead.
Apr 04, 2013 | Cell Phones
How do i get internal pictures off my panasonic Lumix DMC-LZ3
If you take the memory card out of the camera, you can view the internal pictures one by one, and delete them, or transfer them to you computer through the cable...they will show up as another drive in Computer, or My Computer, depending on which version of Windows you are running.
Good luck, and hope this helps.
May 03, 2011 | Cameras
I try to download apps to sd card on archos 101directly but by default it downloded to internal memory. Can any one help how can i download throw sd card thank you
First, you must be on android 2.2 or higher to do this. You can download the update here: http://www.archos.com/support/support_tech/updates.html?country=us&lang=en
Next, once you have the new firmware, you go to the applications menu in settings. Once there, select a program you would like to move to the sd card and in that menu press the move to sd card button.
Apr 22, 2011 | Archos 101 Internet Tablet 16GB 10.1"...
How do i save my photo's to the sd card? it automaticaly goes straight to the camera memory
The user manual here http://www.vtechkids.com/_f/_pw/_manual/80-077300%20Kidizoom%20Camera.pdf Have a look at section 5. Memory Manager this tells you how to change between Internal Memory and SD card memory, if installed
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 30, 2010 | Vtech Kidizoom Digital Camera
Kodak easyshare m360 says memory full after 3 photos i just bought the camera, what i shell do < shell i buy memory card or usb for it ?
You need to switch the camera over to saving pictures directly onto the SD card.
  • Menu
  • Cam settings
  • Chose AUTO or SD card option
  • Press OK to SD card
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If you experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Once you have set the settings to save onto the SD card directly you might like to transferre your existing pictures from the internal memory onto the SD card:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • Jan 18, 2010 | Kodak EasyShare One Digital Camera
    Just put a new memory card in the camera but the screen keeps showing internal memory is full
    How to switch the camera over to saving pictures directly onto the SD card.
      1. Menu
      2. Cam settings
      3. Chose AUTO or SD card option and Press OK
    If you still experience problems:
    The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 1 Gigabyte
      After you having successfully switched over to saving onto the SD card. I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
    Question :
    Follow these steps:
  • Jan 16, 2010 | Kodak EasyShare C643 Digital Camera
    Wont start recovery 102??
    Remove your memory card and restart your archos, when it asks if you want to repair blahblah... just keep pressing the cross till it loads as normal with the sd card 'out', this should work, to stop it happening in the future format your memory card 'sd' with your archos once it has started. Hope that helps!
    Sky DD
    Jul 09, 2009 | Archos 605 Wifi Portable Multimedia Player
    Does the archos 605 have a sd port
    No but what you can do is purchase a mini dock for it and then connect an SD card reader via USB.
    Jun 10, 2009 | Archos 605 WiFi Digital Media Player
    Problems Saving data to SD card
    The only other thing you havent mentioned is wether or not you have formated the card first.
    Apr 26, 2007 | Vivitar ViviCam 3715 Digital Camera
    Archos 80 Titanium HD 8" Android 4.1 Tablet, Dual Core 1.6GHz, 1GB RAM, 8GB Memory Logo
    65 people viewed this question
    Top Archos Computers & Internet Experts
    fordexpert
    Computer Links
    Are you an Archos Computer and Internet Expert? Answer questions, earn points and help others
