Copier malfunction minolta ep3050 copier malfunction detected error code c0070
  • 1,326 Answers
Have you just added a new toner? If so try this first.... Turn the power off and carefully remove the toner bottle you just put in.. Close the front door and turn the power back on and let the copier warm up to ready. Make one or two copies and open the front door and reinstall the toner bottle again... That should take care of the problem.... If it dose not work you probly have more of a major problem with the hopper unit..
Posted on Jun 19, 2009
  • 3 more comments
  • Chris Coughlin
    Chris Coughlin Jun 19, 2009
  • Chris Coughlin
  • Chris Coughlin
  • Chris Coughlin
  • Chris Coughlin
Minolta Di250 copier malfunction C0070; please help me my boss wont buy a new and i need it to make my application; please help me
Re: Error Code c0070
If the machine is throwing the C0070 code without the bottle being inserted than likely the worm gear of the little drive motor of the toner bottle holder is damaged.
If C0070 is only coming up with the bottle inserted, than the bottle may be wrong or damaged from previous attempts.
To reach the toner bottle holder ("hopper") mechanism you have to remove the rear cover.
Apr 02, 2014 | Minolta Office Equipment & Supplies
What's your problem?Minolta EP3050 CSPRO Copier printed copies, then display read ''malfunction detected'' code C0070
Main hopper toner replenishing motor M8 failure to turn.The output from toner bottle home position sensor does not go high within 5 seconds after M8 motor has been energized.Verify the conectors,sensor and motor.Open the front door,turn the toner bottle 1/4 turn clockwise manually with the bottle holder closed.Under the above condition does the toner bottle turn when the front door inter lock switch is turned on?NO - change the toner replenishing M8 motor.Does the toner bottle stop at home position after turning?NO- change PC35 toner bottle home position sensor.Recomanded use vacuum cleaner.
Aug 14, 2012 | Konica Minolta Copier Toner EP6001 CS Pro...
Malfunction code C0070
mam/sir Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner bottle correctly. If THE KUNB on the side of the bottle is damage put a new one in that KUNB is what the toner motor uses to turn the bottle if it damage you get a code. If that does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 09, 2012 | Minolta EP4000/5000 CS/PRO Copier
Minolta ep3050 copier malfunction detected error code c0071
Sir/mam Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to go everywhere. Then close the front cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner correctly. If THE KUNB on the side of the bottle is damage put a new one in that KUNB is what the toner motor uses to turn the bottle if it damage you get a code. If that does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad
Feb 07, 2012 | Minolta Office Equipment & Supplies
Error code c0070
Power off the machine and gentlly take out the toner bottle. Then with the bottle out turn on the machine let the machine go thur its normal routine when the indicator comes on for toner install toner bottle. If the code comes back you have a problem with the Toner Bottle motor, gear, or Main Board.
Apr 17, 2010 | Konica Minolta DiALTA Di183F Copier
Minolta Copier
The malfunction code is for a Polygon Motor malfunction. The motor that shoots the laser beam across the drum
Jun 15, 2009 | Konica Minolta Office Equipment & Supplies
Code C0070 durning the working time
Have you replaced the toner lately? I beleiv it is a toner motor fail to turn, check the toner bottle, remove it and reinstall the bottle.
Close up the machine and try it again.
Hope this works for you.
Ed
Apr 26, 2009 | Minolta EP1030/1030F CS/PRO Copier
Error code C0070
This could be a easy fix for you. Did you just add a new toner? If so, try this..... Remove the new toner bottle CAREFULLY, mahe sure the hole in the bottle is in the upward position. Once you have removed the bottle, Close the front door and turn the copier OFF then back On. Let the copier come to ready and reinstall the toner agian as it is displayed on the front cover or box. Then close the front door and try to make a copy. It should work for you... If not you most likely have a problem with the toner motor or the home position sensor for the toner bottle. You may have to call a service rep. to handle that problem. Good Luck...
Jan 24, 2009 | Office Equipment & Supplies
Copier not working
Is the copier a Minolta? If so what model there are different ways to rest code.
Feb 09, 2008 | Konica Minolta DiALTA Di200 Copier
Ep2080 minolta cspro
Ep2080 minolta cspro error code comes up with c0500
Dec 06, 2007 | Minolta EP4000/5000 CS/PRO Copier
194 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
