Question about Dewalt Dw318 Jig Saws
How do I change the angle on DW318 jig saw - Dewalt Dw318 Jig Saws
Can I change the depth of the cut. I see how the shoe cuts angles but can it make shallow cuts
I have used a spacer block on the shoe which makes the cut shallower.
Sep 27, 2014 | Saws
When I try to cut with my saw, the blade bends so that the cut is at an angle. Because of this angle cut, it is difficult to follow a line but even if I can follow the line, the angle cut through a 3/4...
This is a common issue with jig saws. There are sometimes larger blades, but all seem to distort to some degree. The only real solution is to go slow enough to allow the blade to return to it's normal shape...Essentially, is sounds like another tool would work better, but often you are scrolling with a jig saw and circular saw (for example) would not work.
The other workaround involves several cuts, so the final cut is removing much less material.
Nov 07, 2010 | Black & Decker Black decker Firestorm...
How to cut a 45 degree angle on wood using a jig saw
use a combination sliding square to mark ecxactly where you want to cut. Measure the distance from the jig-saw blade to the edge of the jig-saw bottom plate. Use this distance to mark another line parralel to the first line. Nail or screew a straight piece of wood on the second line. Put the jig-saw plate against the wood fence and cut your perfect line.
Mar 17, 2010 | Franke EuroPro Series GN1845SP Solid Wood...
What is the proper way to sharpen the chain
you can buy a simple kit for a few dollars, there is a jig that holds the chain and a roud file that will be guided through the jig at the proper angle to sharpen the chain
Oct 31, 2009 | Poulan Pro 18 Inch 400E Chain Saw
Task-force-4-amp-jig-saw
how do i change blade on task force jig saw. i am un able to pull it out after pressing button for it
Aug 04, 2009 | Saws
Jig Saws power
The more power the jigsaw has (measured in Voltage for cordless and Wattage for corded), the faster the cuts and the deeper they are - up to 70mm in timber or 8mm in steel.
Aug 27, 2008 | Dewalt DC7KITJA 18v. Xrp Super 7 - Kit...
Jig Saws Adjustable foot
An adjustable foot is the metal plate at the bottom of the saw which will pivot between 0 and 45 degrees. This will allow you to make angle cuts in the wood
Aug 27, 2008 | Porter Cable Cable 53530 Edge Guide for...
Dual-bevel Features
Dual-bevel capability allows angled cuts in either direction without flipping the workpiece
Aug 27, 2008 | Makita 4323K 3.7 Amp Jig Saw with Case
Dewalt Dw318 Jig Saws Logo
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
