Question about Kenmore HE2 Plus Front Load Washer
Loose button in drum - Kenmore HE2 Plus Front Load Washer
    Top Expert:
  • Kenmore Master
  • 14,161 Answers
Posted on Jun 15, 2015
My bosch wsshingmachine is ver nis as if somthing is loose and baging in the machine
Make sure there are no loose buttons or zippers in the drum. You may need to call a repair business.
Oct 04, 2014 | Bosch Washing Machines
My dryer is making a sound as though there is loose change bouncing around in the drum. what could this be?
Zippers and metal buttons, like on jeans, will sound like that when tumbling against ss drum. Experienced the same with mine.
Sep 21, 2014 | Whirlpool Dryers
Admiral Heavy Duty Super Capacity Plus dryer does not start when button is pushed. The dryer buzzes when the start button is pushed, but the dryer will not start tumbling. The model number is ADE7005AYW...
Motor runs, but drum does not turn
1. Broken or slipping belt---replace
2. Loose pulley---tighten pulley on shaft
3. Drum jammed or bearing frozen---check for foreign object & clear it
Clean or replace bearing
Sep 21, 2011 | Dryers
I cleaned out my lint tray and after I put it back in, the dryer started making a grinding noise?
Check all exposed screws, and make sure they are tight. Loose cabinet screws may cause a squeak.
Check for foreign objects in the drum. (Coins, buttons and zippers will make a rattling sound as they roll around in the drum)
May be loose drum slides can cause a metal scraping noise as the drum rotates. For that you'll need to contact Crosley Service Center.
Good luck and have a nice day
Rating the solution is highly appreciated.
Jul 02, 2010 | Crosley CDE6000 Electric Dryer
Functional problem sc481 , what does it mean
DRUM CLEANING ERROR ON THE MAGENTA DRUM CHECK THE CHARGE ROLLER HASNT COME LOOSE OR IS JAMMED AGAINST THE DRUM UNIT YOU CAN TAKE THE DRUM OUT AND REMOVE THE FRONT FACE PLATE BY THE TWO SCREWS AND GENTLY REMOPVE THE DRUM BY PUSHING IT PAST THE FRONT HOUSING..BE CAREFULL IT MAY JAM BUT SHOULD BE OK.. CLEAN THE CHARGE ROLLER WITH A DAMP CLOTH AND THE FELT CLEANING ROLLER WITH A DRY DUST CLOTH REFIT AND CHECK.. TO CLEAR THE CODE PRESS YELLOW CLEAR THEN 107 THEN HOLD DOWN THE STOP BUTTON TILL SCREEN CHANGES.. TURN OFF AND BACK ON.. GOOD LUCK
Jun 28, 2010 | Gestetner DSc424 Color Copier
WM1832CW has stopped spinning. Tries to spin but
If the drum is loose it probably means that the bearings at the rear.....OR...The arms that connect the drum to the pulley shaft have broken.....Major job....Sorry.....Nomess
Apr 18, 2010 | LG WM-1832C Front Load Washer
I have a frigidare and everytime i put something in to dry the clothes get caught. the buttons or zipper . what to do
Does the drum have plastic bars spaced around the interior that may be loose? If so, the top must be removed to access the screws holding the bars to the drum. Are any of the bars damaged? If so, replace the entire set. Are any of the screws holding the drum to the center bearing loose? Tighten if so.
Jul 26, 2009 | Dryers
START SWITCH HUMS BUT THE DRUM DOES NOT ROTATE
Try turning the drum while holding down the start button the belt could be twisted
May 10, 2009 | General Electric DHDSR46EGWW Dryer
Kenmore has loose drum
drum lose need more on that drum should move side to side all around if its not draining something blocking the pump if drum is lose its the basket drive block busted
Feb 28, 2008 | Washing Machines
Change in drum/tub
Scamp, the only solution is to empty the pockets...there is no funtional or non functional part to catch the coins, buttons, toothpicks, bra wires etc...Catriver...
Oct 25, 2006 | Maytag MAH8700A Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
26 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
