I have a white Westinghouse model sk19H210s tv that will not power up. It is approximately a little over one year old. Can anyone tell me where i can get a replacement circuit board/power supply item number DMC-190M015? Or am I just sc**ed on this TV?
Comments:
Jun 18, 2009
- thanks, I have been searching for this info for several days. Seems to me WW should be doing a recall on this and fix this problem. sounds like it is cheaper and quicker to just buy a new non-ww tv
Hi, Only Shop Jimmy can help you to have power supply board for Westinghouse SK19H210S TV as currently its out of stock. Call Shop Jimmy on 952-881-6492 & 877-881-6492 to ask when they can arrange subject power board or check Wstinghouse Support for power board availability. Westinghouse call number is 1-800-701-0680 Thanks.
Popular Solutions for Westinghouse LTV-27W2 27 in.
I have this running thru a cable box and haven't
changed anything for a lllonnnggg time. It is...
(More)
changed anything for a lllonnnggg time. It is using the YPbPr2 ( three wire )
connection.
After watching a show the screen will go black. the blue light stays on.
After a while of powering the TV on and off, the screen will come back and
usually runs the rest of the time we watch it.
Any help is appreciated
my westinghouse LCD model LTV-27w2-b keeps cycling through on and off. Will be on for a few...
(More)
my westinghouse LCD model LTV-27w2-b keeps cycling through on and off. Will be on for a few seconds, then shuts off and comes back on in a few seconds. What might be causing this?
I have a 40" Sony Bravia KDL-40v5100 that is approx. 1 month old and is hooked up via HDMI to...
(More)
I have a 40" Sony Bravia KDL-40v5100 that is approx. 1 month old and is hooked up via HDMI to Comcast HD. Whenever I was changing channels there was a popping sound, so I called Comcast and a Tech came and changed the HD box, and the popping noise went away for a while, but now it has returned. The noise is not quite as pronounced, but it is still there. I am not sure what to do at this point, as it seems nobody seems to want to take ownership for the problem, Sony/Comcast. I wonder if this is happening with other makes of LCD's or if it is only Sony.
