No fuel to filter on John Deere d130
SOURCE: Hello. My John Deere mower has started surging at
I have a john deere 420 rider. It would surge at a higher speed. It is a hydrostatic and there were 2 bolts on the transmission that were loose. now it runs beautifully smooth,
SOURCE: John Deere 445 Garden Tractor, starts immediately,
could be bad gas, but it sounds like a choke problem. did it sit over the winter with less than a half tank of gas in it. try putting some rubbing alcohol in the fuel or draining the tank and disconnecting the gas line so you can drain the gas out of the carb. also check the gap of the spark plug and make sure that is correct. when was the last time there was fresh oil put in. also check the air filter, it could be full of dirt.
Testimonial: "Thanks for the ideas. I will try your suggestions. Tractor used for snow blowing during the winter and gas did not stay in it long. Good ideas!"
SOURCE: John Deere will not start.
If you have gas running down to the carberator ( take the fuel line off and make sure there is gas running to it or there may be a screen or filter plugged by the tank or on the way to the carb) if there is gas there the problem lies in the carb itself. If you have some mechanical ability you should be all right as it is not rocket science. If you are comfortable with taking the carb apart the first thing i would check is the needle vavle. With the carb apart you will see a big brass looking thing this is the float, right above that is the neddle valve, that is the first place they seem to stick on me. Move the float up and down if the neddle above it doesn't move or sticks there is your problem. Spray it with carb cleaner and see if it moves freely. You may have to dismantle the carb to get it to work freely. If it won't buy a carb kit and install all the new gaskets needle valves and jets ( this is a very good ideal any how) Also make sure any little ports in the carb are open ( in the bottom of the carb there may be tiny little holes that are plugged) find a very small wire to clean them with and also make sure when you are done you can spray carb cleaner thru them. This is why they have a small straw on the can with it ( watch your eyes and wear safety glasses as you never know where it will spray out from) That stuff will dry your skin out fast so don't get it in your eyes and you may want to wear rubber gloves. Also be very careful when putting back together as there are little pieces that like to slide around and fall out or may get bent even worse you don't want them in your motor. Also try to count every screw you turn as these are jets and you will want to put them back to the place they were set at cause it's a pain to get them set right by adjusting them later. Do not force anything putting it back as you may bend the jets or float and you will have to take it apart again and replace them as well. Take your time and be patient and you will be just fine
Testimonial: "thanks...you gave me encouragement to give it a try. I took off the shroud, air cleaner box and couldn't take off the carb as there are no heads on the four bolts that hold it on. Looks like it was designed not to be removed? I took off an inspection plate on top of the carb and cleaned all of the channels and ports within with carb cleaner and compressed air...still no gas flowing thru carb...unless I force with compressed air. Any other thoughts? It is a twin cylinder OHV B/S. Thank you. "
SOURCE: John Deere 115 lawn tractor - won't start.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
SOURCE: John Deere ZTRAK 737 zero turn - runs rough - one plug
My idea would be to replace the coil to that plug
Jim Kite paris, il
