Question about Motorola Mobility SLVR L7 Cellular Phone
Freezing and stopping
I turn my phone on; but it doesn't let me charge it without flashing on & off. HELP PLEASE!
    Brigadier General:
  • 7,752 Answers
The phone's firmware needs to be reflash take the phone to a mobile service center and have them correct it for you.
Posted on Feb 16, 2008
Battery ran out, I have charged it but only windows icon flashes and won't turn on?
is the battery showing fully charged ?. If it is remove the battery for a few minutes then replace it this will reset it without any data loss .
Oct 13, 2014 | Cell Phones
AT&T Impulse 4g says phone is charging when it is not plugged in. Will not charge when plugged in!
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jul 26, 2012 | Huawei Impulse 4G
Htc evo 4g shift won't charge or turn on and I
Have you attempted taking the battery out and while the battery is out holding down the power button for a few seconds? If this doesn't work,
First test your charger to ensure proper charging. Clean charging ports. Remove battery and clean brass contacts with alcohol and q-tip
Jan 12, 2012 | Lands Phones
I have a nokia 7610.when i turn it on, i can only see the white display.i even changed the display.
If changing the Display doesn't help and the phone functions without any issue, then the problem could be related to your phone Display IC. When the Display IC is bad, only the light will be displayed instead of the Pictures or graphics. To fix this issue, you'll need a mobile repair technician so that he/she could check the issue. Please understand that this isn't a task for non-technical guy, in case the handset if opened or repaired without proper knowledge or experience, it could bring permanent damage.
But if in case the phone doesn't work when the display is white eg. No calls can be received, or no messages could be received, then it could also be a problem with the phone software. The same problem could only be fixed by flashing or upgrading the phone software.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Sep 08, 2011 | Computers & Internet
My n73 turned off during the phone software update and it does not turn on. what i have to do.... please help me
First make sure that the battery is charged. Then take out the battery for 10 seconds and put it back again. Try to switch on the phone. If this doesn't work then the only way to restore the phone is to take it to a service centre and ask them to flash it.
Aug 21, 2011 | Nokia N73 Cellular Phone
My phone (Samsung i8000) doesn't charge when turn-on. even when connected with USB cable my computer doesn't recognize it. Please help.
Just follow this step.
* Your mobile charging socket as some problem.
* You just need to visit you are nearest Samsung service center.
* There they will fix you are problem in few minutes.
* After getting repaired check weather your mobile is charging correctly.
* Then your mobile will be just fine.
If you are satisfied with my answer then rate me.Thanks for your question.
Jun 24, 2011 | Cell Phones
When my Motorola H720 is plugged in, the red light is flashing quickly, what could be wrong with this? It does not seem to turn on either....problems?
Red light flashes when I try to charge it and nothing all other times. Doesn't turn on, doesn't work. I pretty sure the problem is that it is a piece of junk.
Mar 17, 2011 | Motorola Mobility H720 89382N Bluetooth...
Motorola Mobility SLVR L7 Cellular Phone Logo
16 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
