Question about Thermador SGS36GS Gas Cooktop
When I cook using the middle burner and any other burners Thermador SGS30GS Gas Cooktop it takes a long time to cook things on the other burners.. and diminishes the heat from the middle burner... can you tell me what can be done to fix this?
Bgillespie
  • 89 Answers
SOURCE: Thermador 30" gas cooktop SGCS304RB
Do you hear gas? If so, take a needle and put it through each one of the small holes where the gas comes out.... Also look for a little "white-dust" where the sparker makes the spark. (located probaly at back of burner). If there is a white dust build-up scrape it off with something (needle) and give her another go...
Posted on Jan 22, 2008
textonor
  • 130 Answers
SOURCE: Clogged burner on gas cooktop
lowly is it the left burners that won't lite? I only ask as depending on the model some of the Thermador cook tops had simmer control burners. This is a 3 part system on the burners. 1 a simmer control, 2 electric solenoid, 3 potentiors. When you turn on the burner the potentior tells the simmer control to send power to the gas solenoid. At the same time the unit will spark. If your unit has extra low on the left 2 burners then you have this system. The usual problem in the potentior. Hope this helps.
Posted on Aug 09, 2008
  • 338 Answers
SOURCE: old Thermador cooktop continues to spark even after turned off
sounds like you have a bad switch. maybe on the large burner.. some of those switches can be replaced without the whole harness.
Posted on Dec 22, 2008
SOURCE: Cleaning Thermador Cooktop?
To clean the stainless around the star burners try applying Easy-Off oven cleaner around the stars with a Q-tip (spray the cleaner onto the stainless surface first because it's very hard to control the spray output). The cleaner will make your stainless sparkle and the Q-tips allow you to get close enough while controlling the application. Scrub gently with the Q-tip and the stains will disappear within minutes. Wash thoroughly with a wet cloth. I've used this on my older model Thermador stainless cooktop for 5 years.
Posted on Jan 25, 2009
SOURCE: gas cooktop - burner won't ignite
if its the burner that hase the intermitent timer on it
i have the same problem & I troubleshooted it.
if u take the cover off thier is a part on it that the rest dont have. its a red thing that rotates & thier are little contacts in it. for some reason thier is something that messed up inside it.
i took both mine apart & switced the guts & one of the little "boards"
is not working properly.
so im shure that is your problem
Posted on Jul 25, 2009
My 6 burn cook top when it turn it on it keeps on "clicking
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Jun 16, 2011 | Thermador PC366BS Stainless Steel Gas...
We have a thermador 5 burner gas range top and the pilot light seems to have gone out. The burners don't go on but we smell gas. How do we re-light it?
Most gas range tops no longer have pilot lights but use an electronic ignition (sparker) to light the burner. Normally when you turn the burner on you should here a snapping or sparking sound, at which point the burner should ignite. Here is a link to the user manual for 36" - 5 burner Thermador rangetop...maybe this will help: http://dl.owneriq.net/a/ac64ae7b-1ed3-44a3-9235-e4dbd8fe4628.pdf
By the way, in the short term you could always use a match to light the burner. JUST BE VERY CAREFUL THE YOU HAVE THE MATCH LIT AND OVER THE DESIRED BURNER BEFORE YOU TURN KNOB TO START THE BURNER!!!!
Jan 15, 2010 | Thermador 37 in. SGSX365 Gas Cooktop
Clicking gas cook top
I accidentally bumped the thing where the gas comes out (I don't know what it's called - I'm a wife not a tekkie) and it started clicking when I turned it on. I turned off the gas and repositioned that gizmo and it stopped clicking.
Feb 19, 2009 | Thermador SGS36GS Gas Cooktop
Old Thermador cooktop continues to spark even after turned off
Dec 22, 2008 | Thermador PSC364GDZS Gas Cooktop
Aug 07, 2008 | Thermador SGS36GS Gas Cooktop
Burner won't light
Clean the gas nozzle w/small wire are located at the back of the gas cook top /shut off the gas clean small gas nozzle clog / w moisture /rust dust and any foreing material.
Dec 19, 2007 | Thermador SGS36GS Gas Cooktop
Thermador Gas Cooktop Won't Stop Clicking : SGC304RS
theres a part in the cooktop called a spark modual. replace it. when i goes bad the problem your having is what it causes
Nov 29, 2007 | Cooktops
Clicking noise on cooktop even when all burners ignite
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
Dec 01, 2006 | Viking 37 in. VGSU161 Gas Cooktop
Thermador SGS36GS Gas Cooktop Logo
64 people viewed this question
Top Thermador Cooktops Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
tom wright
tom wright
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
