Question about Kitchen Appliances - Others
Crack tridmetrix 2014 - Kitchen Appliances - Others
2014 Nissan Altima starts up fine but when you put it in drive it shuts off. Put it on the scanner and it read codes p0102 and p0112
This sounds more like a leak in the air intake system rather then what those 2 codes specify. Make sure all the intake tubes are securely tightened and all vacuum lines are crack free. Also make sure the air resonator box is securely tightened.
I’m happy to assist further over the phone at https://www.6ya.com/expert/edward_7957cb69ff44a6fd
Oct 16, 2016 | 2014 Nissan Altima
I dropped my phone and the screen cracked a tiny bit underneath the silver part at the top of the phone the phone now has a black screen
Alcatel One Touch Fierce Teardown - iFixit
https://www.ifixit.com/Teardown/Alcatel+One+Touch.../23019
iFixitiFixit - Alcatel One Touch Fierce Teardown: Tearing down a water damaged Alcatel One Touch Fierce from Metro PCS. ... It seemed to have quite a bit of adhesive. ... I have NO experience replacing a cell phone screen and this teardown ... I opened thephone and the little silver piece on the power button cable fell off.
What is covered by mobile phone warranty? ' Geek Squadwww.geeksquad.co.uk/.../What_is_covered_by_mobile_pho...Geek SquadOct 22, 2014 - A warranty is a manufacturer's guarantee to repair your phone or ...Alcatel, 12 Months, 6 Months .... "Does rooting my Android phone void the warranty?".... been dropped with enough force to break the small piece of glass!7 Practical Things You Should Do After Cracking Your ...www.makeuseof.com/.../7-practical-things-you-should-do-after-cracking...Jul 30, 2014 - Or, well, maybe you just accidentally cracked your phone's screen in a normal .... Id like to think that it protects my phone that little bit more.
Dec 16, 2015 | Alcatel One Touch Idol 2 Mini
2014 ford fusion engine wont crank after wreck
Ford fusion won't start - YouTube
? 2:01
www.youtube.com/watch?v=H0BhHWT2cyY
Sep 16, 2014 - Uploaded by mlmunoz21
Ford fusion won't start ... Published on Sep 16, 2014 .... 2004-2008 F150 Died Out No Crank Theft Light ...
Ford Fusion won't start - YouTube
? 0:32
www.youtube.com/watch?v=lmH7R6Ebmyc
Jan 9, 2015 - Uploaded by Nicholas A.
Any ideas why it won't start? 2007 ford Fusion awd 6 cylinder. ... And P1260 2007 Ford Fusion - Theft ...
Nov 02, 2015 | 2014 Ford Fusion
2014 Zuma. Why is it running at half speed with check engine light on?
Hi, Steed and the usual suspects are:
1. Severely drained or faulty battery.
2. Faulty regulator/rectifier or high output coil.
3. Faulty power valve, solenoid or installation.
4. Clogged air filter or exhaust.
5. Cracked or incorrect float level.
6. Float needle is not seating.
7. Faulty reed valve.
For more information about your question please visit the website below. Good luck and have a nice day.
DOWNLOAD 2014 Zuma
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Aug 25, 2015 | Yamaha Motorcycles
Car had been sputtering and stalling while stopped in "drive". Mechanic mentioned to change the thermostat so I did it myself. The problem still exists and now the blower for the heat and A/c doesn't
  • Doug Warne Your kia here is what i would do to help diagnosisMar 19, 2014
  • Doug Warne First of all i would do these steps"
    Mar 19, 2014
  • Doug Warne how does it run when cold how does it run when hot
    Mar 19, 2014
  • Doug Warne i would look for Vacuum Leaks
    Mar 19, 2014
  • Doug Warne i would remove the spark plugs check engine compression hope to see about 180 psi on each cylinder
    Mar 19, 2014
  • Doug Warne i would exam each spark plugs to see if fowled with Gasoline or carbon keep spark plug with each cylinder because low compression will cause this
    Mar 19, 2014
  • Doug Warne low compression i would exam cooling systemicon1.pngfor airbubles or coolant in engine oil
    Mar 19, 2014
  • Doug Warne if oil looks milky white in color its coolant do not operate vehicle
    Mar 19, 2014
  • Doug Warne change head gasket get head kit with valve cover and take head to machine shop to have shaved straight and checked for cracks Replace head with Remanufactured if warrpiage to great or stress cracks
    Mar 19, 2014
  • Doug Warne check air filter and breather to insure the intake is getting air before you do compression test
    Mar 19, 2014
  • Doug Warne if engine dies when hot lets look at the fuel pump pressure
    Mar 19, 2014
  • Doug Warne lets take and look at the fuel cap where you put your fuel in make sure the vent is open which allow outside air pressure becuase you can have a 100 billion gallon second pump but if there is no air coming into take the pump will pump 0
    Mar 19, 2014
  • Doug Warne Check your OBD 2 codes First this will give you ideas of what happening ie bad oxgen sensor telling me look for vacuum leak or poor spark ignition or poor engine compression, possible injector leaking
    Mar 19, 2014
  • Doug Warne poor compression tell me the engine maybe out of timing and or valves or worn or burnt exspecially when engine is hot and it dies
    Mar 19, 2014
  • Doug Warne a cylinder leak down test would be revealing for valves or piston rings
    Mar 19, 2014
  • Doug Warne if engine has good Intake of Air and gas mixture and then good compression of air and gas mixture and good spark from the Ignition and good flowing exhaust the engine will operated smoothly
    Mar 19, 2014
  • Doug Warne if engine looses power or stalls when hot take a look at the catyalitic converters to see if glowing red or hot one side and cooler on rear side also check the exahust pessure at tail pipe to see if cats are plugged if you have little exhaust pressure and no exhaust leaks
    Mar 19, 2014
  • Doug Warne i hope this helps and i always kiss the job.............
    Mar 19, 2014
  • Doug Warne Keep IT Simple Stupid
    Mar 19, 2014
    Mar 19, 2014
  • Doug Warne as far as the thermostat is the engine running hot..????
    Mar 19, 2014
  • Doug Warne CHECK FOR AIR BUBBLES IN COOLANT as piston compress air if it leaking pass the headgasket seal into the coolant jacket this will cause air bubbles and you may loose heat out of the heater core...i have seen this with cracked heads also so if this is the case have head checked at machine shop
    Mar 19, 2014
  • Doug Warne check the oil from the dip stick smell it see if you smell gasoline this is telling me thin oil, possible injector leaking gasoline
    Mar 19, 2014
  • Doug Warne Low engine Compression with satuerate oil the oil ring on the piston will have hard time to create seal to cylinder wall there fore low compression exspecially when engine is hot
    Mar 19, 2014
  • Doug Warne get a spray bottle fill with water and with engine runing spray water in coil packs and spark plugs wires to see if there cracked or frayed Electricty is lazy it will use the water as a ciricut and go to ground through the water this is telling me cracked coil pack or plug wires engine will began to miss and fumble while running
    Mar 19, 2014
  • Doug Warne these are some tricks i use to help diagnosis problems....hope this helps
    Mar 19, 2014
  • Doug Warne As far as the A/c Heater Blower i would first check the Fuse in the box with a test light, and i would check all the fuses remember you have a battery side and ignition side of the fuse box if the fuse is blow replace with manufacture Amp Fuse and if new fuse shorts then i would look at blower motor draw
    Mar 20, 2014
  • Doug Warne Check your battery Cold Crank Amps with a load test meter most parts store will do for free hoping you will buy a battery and if batter test not good if you choose to not to replace your alternator will be charging constentently and the trio diode board in your regulator located inside the alternator in most applications these days will short then this will cause a battery high amp draw so your battery wont start in the am when your late for work..
    Mar 20, 2014
  • Doug Warne If your battery is loosing charge overnight or anytime you can simply take your negaitive Cable from your batter and put a test light from the negiative cable then touch your neg. terminal and if test light illuminates you have a draw and bad draw so take amp meter and test to see the draw in amps if high amp draw i would first look at the regulator and remove the 12volt singe wire and see if draw disappear if draw is no longer then 99 percent your regulator has shorted
Mar 19, 2014 | 2001 Kia Sportage
Kitchen Appliances - Others Logo
278 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
