Question about Freezers
Imperial freezer alarm sound
2 Suggested Answers
kachbibi1
  • 979 Answers
SOURCE: Imperial commercial freezer. Temp alarm activated and some products are thawing. Compressor is running. ?? The door doesn't have that "vac" like sound when closing but door seems to be closed w
You could have a freon leak and needs to be looked at .
Posted on Mar 03, 2013
Imperial heavy duty freezer is not freezing. Exterior very warm
You need a refrigeration engineer. It sounds like it needs refrigerant gas. Worst case scenario is that the compressor has failed. Both low gas and a failed compressor generate heat.
Jun 12, 2016 | Freezers
Why is the temperature alarm light on, on my freezer Model# FFU21M8CW?
Good Afternoon Friend,
I understand that the temperature alarm light is on for your Frigidaire freezer, model# FFU21M8CW. This feature is designed to provide a warning of a possible malfunction. If the temperature of the food rises to a level unsafe for long-term storage, the buzzer will sound. The red light, if equipped, will also glow. The Temp Alarm feature operates on household electricity. If power fails, the alarm will not function. An ON/OFF switch allows you to deactivate the Temp Alarm when not wanted. Your freezer is shipped with the Temp Alarm in the OFF position. After your freezer has run approximately 4 hours, the red light, if equipped, will go off. Then you may activate the Temp Alarm without the alarm sounding. Press the ON switch to activate the Temp Alarm. To deactivate, press the OFF switch. If the alarm sounds, be sure freezer is properly leveled, and the door closes freely, and seals properly. If you suspect a technical malfunction, call an authorized servicer immediately. Hope this is helpful.
-Best Regards-
WP
Jun 24, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
The high temp light is on. What can I do to reset it? Everything seems frozen and fine in the frezzer
HIGH-TEMP ALARM SWITCH (SOME MODELS)
An audible
alarm will sound if the freezer temperature reaches
unsafe levels. The alarm operates on household electricity.If
the power
fails, the alarm will not perform.
An ON/OFF switch
allows the high temperature alarm to be
deactivated if desired. NOTE: You must open the
freezer door to
view the alarm switch. The
freezer is shipped with the switch in
the OFF position.
After the freezer has run longenough to
lower the temperature, you
may set the switch to the ON
position.
To activate the alarm, set the switch
to the ON position.
To deactivate the alarm, set the switch to the OFF position
i got this from the freezer manual from Kenmore hope this was helpful
Mar 28, 2010 | Kenmore Freezer 13.7 cu. ft. Upright...
Zanussi fridge freezer alarm keeps sounding
If the refrigerator and freezer are both working properly. Then the only problem would be the alarm, It's either the placement of the alarm thermometer or the alarm thermometer is stuck closed.
Mar 15, 2010 | Freezers
I just moved into a home with a kenmore chest freezer. This is a real dumb question, but which symbol means on. Should the circle be showing for "on" or should the line be showing for "on"?
Some freezer models feature a temperature
monitor that provides an audible
alarm. The temperature monitor alarm is
located near the temperature control
The alarm sounds if the temperature in
the freezer rises 10° F (12° C) or more
above normal for selected setting. Alarm
may sound if temperature control dial is
turned to a much colder setting or if a
large amount of unfrozen food is added at
one time. Alarm is controlled by a three
position switch
0 = OFF prevents alarm from sounding
when freezer is warm, such as during
initial start-up or defrosting.
• ✓ = TEST sounds alarm regardless of
temperature. Alarm system should be
tested at least once a month.
1 = ON is proper setting for normal
freezer use. Return switch to 1 after
defrosting.
Jul 07, 2009 | Kenmore Freezers
Temp Alarm going off, when freezer seems to be cooling fine.
You need to check the temp in the freezer to make sure it's down to around 10 degrees. The alarm will go off much above that.
Jul 02, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Temp alarm on freezer alarming.
that's the same problem i incurred, i replaced the thermostat and the fan. seems to be working fine.
Dec 03, 2008 | Kenmore Freezer 14.1 cu. ft. Upright...
Its keeps peeping
Hello twins49
Welcome to Fixya,
You said, your Frigidaire freezer 17 cu. ft. , it keeps buzzing or peeping
The alarm may be malfunctioning or it may be warning you of low temperature.
You can go to any hard ware store and buy a refrigerator thermometer and ask them if it can go into a freezer too!It can, But ask anyway!
If it is cold enough then it is a faulty alarm going off.
Your freezer may be equipped with an alarm.
Here is some information that may help you find it and turn it off if you wish
Temp Alarm (audible only or audible with warning light)
This feature is designed to provide a warning of possible malfunction. If the
sound. The red light will also glow on models so equipped. The Temp Alarm feature
operates on household electricity. If power fails, the alarm will not perform. An ON/
OFF switch allows you to deactivate the Temp Alarm when not wanted. The freezer
is shipped with Temp Alarm in the OFF position. After freezer has run approximately
immediately.
Let me no what you find.
Huuum
Please remember to leave a rating before you leave
Aug 26, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezers Logo
81 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
