Question about Dishwashers
Asko d3232 stuck on pot cycle. making noise in drain
4 Suggested Answers
  • 534 Answers
SOURCE: I have an ASKO D3251 that is not draining. We
You will need to remove the bottom panel of the unit below the door that exposess the motor and the electrical along with water hook up. Now you will nee to manually go through the cylces (or let the machine cycle) to rinse. Once in the rinse cycle you should have heard the selinoid activate to drain the water. This selinoid click and pulls an arm down when in drain mode if you are looking under the unit you will either hear it or see this activate. If not then the selinoid is out, if you hear it activat then you need to look at the back of the motor to see if the motor itself is turning. You should be able to see the fins on the back of the motor turn once it goes into drain cycle. If you do not see the motor fins turning (you have to look through the vent slots located on the back of the motor) you acan take a small slotted head screwdriver and with the power off, you can insert this screwdriver into the vent holes in the back of the motor to spin (or move) the motor fins. If they do not move freely then the motor itself is froze up in that case a new one is needed. If the spin then try your drain cycle again since you may have unfroze the drain motor.
Good luck hope this helped
Dave
Posted on Feb 02, 2010
SOURCE: ASKO D3251 flashing error message; drain gurgling, power off
You most likely have a leaking bottom spray arm. The water is in the pan under your unit. It requires dealer service. If you are still in your 3-year warranty, good; otherwise be prepared to put out hundreds of dollars. I'm going though this now for a second time on my $1600 D3251. Asko did grant a one-time extension on my warranty since it expired a month ago. In 6 months when it breaks again, I'll buy a Bosch. I also had this same problem on a previous Asko. I can't get more than 3 years out of these units, so this is my last Asko. When it breaks again, I'll go with Bosch. Good Luck.
Posted on Jul 16, 2010
  • 10865 Answers
SOURCE: we have Asko d3251 dishwasher.
Hello Imaries. THat grinding noise is the dishwasher's transmission going bad. This is an expensive part and an even more expensive service call. If you are under warranty, call and get an estimate. Sometimes, even when the warranty covers the part it is still wiser to replace rather than repair. The best news is that the new dishwashers are the best ever made. Quieter, less electricity used, less water used, and THE cleanest dishes ever. Joe
Thanks for choosing Fixya!
Posted on Nov 17, 2010
My previously quiet Asko dishwasher now makes a lot of noise during draining cycles
Hello Beverly;
My name is Peter. I am a retired field service appliance technician.
You did not provide a model number so I have to advise in general terms.
It sounds like your drain pump is struggling.
Clean your drain and/or drain filter. Wear gloves you may have broken glass or something sharp in your drain.
You garbage disposal line may be plugged.
Or you drain pump may be going bad (But, I do not really think so).
Dec 22, 2014 | Asko Dishwashers
We lost power for 2 days and when the power returned our Asko D5253 dishwasher began making noises as if it is trying to drain. It was not on when the power went out. We tried turning it on and off
Yes, it is stuck in "drain mode" just let it complete the cycle and it will turn off. It may sound like it is on for a long time, but just be patient.
Best regards,
Bill
Oct 24, 2014 | Asko Dishwashers
Asko WCAM1812 makes noise when draining
I recently had this same problem. There is a spinning wheel inside the pump that has likely detached from the motor. Upon removing the back of the unit, you will see a water pump on the bottom left of the unit. There are three screws attaching the pump to the rest of the assembly, remove the screws and detach the motor, out should pop out a red spinning wheel. I Gorilla glued mine back on, and it sounds better than before the grinding noise.
Feb 13, 2013 | Asko WCAM1812 Front Load Washer / Dryer
Machine suddenly started making a strange grinding noise while in the spin cycle. The water drained, but the noise is not normal. Is there an issue with the pump?
Welcome to FixYa.
Based on your description, " strange grinding noise while in the spin cycle. The water drained, but the noise is not normal. Is there an issue with the pump?" it could very well be just a clogged pump insert/filter.
It's not very difficult to check on the 8005 Asko though, you'll first need to remove the panel beneath the door...it should just pull forward and off.
**Unplug the washer before servicing the unit though...safety first** You may also need to have a wet-dry shop vacuum or plenty of towels as there will be quite a bit of water present.
Carefully remove the filter from the pump by turning it ( slowly to allow water out gradual )...the issue with these Asko pump inserts/filters is they can get so clogged up they are stuck and difficult to remove...
i.e.
these can become clogged with items such as coins, hair-pins etc. that can actually damage the part, thus causing a "grinding noise" or the like.
Once the filter is removed check the pump thoroughly as well as the hoses to rule out any other possible blockage.
Unfortunately once they are clogged to an extreme degree removing the filter by normal means becomes difficult or impossible without breaking it as I alluded to.
The image I attached above is an example of a pump I had to remove and disassemble to clean it out so the filter could be removed/unscrewed, hence the need for the "worm-gear" clamps had to be used to replace the original "one-time" clamps.
If you indeed break this part during your attempts to remove it, a replacement is available, Asko original part # 88 010 69 and available at on-line retailer "repairclinic.com" for about $25-$30USD.
i.e.
Let me know how you make out or if you require further assistance. Ultimately the drain pump itself could be faulty, or it could be the main motor brushes causing the noise...that can be ruled out or confirmed by running a spin cycle with the drain pump disconnected, but I'd certainly check for obstructions first.
Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
Jan 30, 2011 | Asko 8005 Front Load Washing Machine
I have an ASKO D3250 and it has recently started making a loud noise from the pump area. It starts as soon as the cycle begins and doesn't stop even if you open the door. It seems to stop about 90 seconds...
All power and sounds should stop when any dishwasher door is opened.
Your door switch may be stuck causing it to continue.
The 90 second sound at the beginning of the cycle is the water pump extracting any residual water before taking on clean water for the wash cycle.
Any excessive noise from the drain pump could be debris in the pump. e.g. broken glass.
You can remove the pump and check it for blockage or any foreign object.
Aug 14, 2010 | Asko 24 in. D3250 Built-in Dishwasher
Water draining makes loud noises
if water isn't draining properly the cycle will stop thereon check the drain pipe
Oct 12, 2009 | Washing Machines
Can't get my Asko D3232 to start
Try flipping the breaker off and on. If that does work it maybe the control panel.
Sep 25, 2017 | Asko TouchProof D3232XL Stainless Steel...
Mar 17, 2009 | Asko D3251HDSS Stainless Steel Built-in...
ASKO 1605
Hi Guys
My dishwasher this morning has desided to not work correctly.
Its a ASKO 1302 about 20 years old. It has been a very good machine.
Over the last couple of weeks during the washing cycle, the dishwasher has been making a loader noise than usual.
1. Today, the dishwasher timer, travels all the way through its cycle, but very little washing take place.
2. Soap power is still there, plates not clean!!!!
3. Water is hot
4. At the end of the cycle, there is no water in the dishwasher.
5. I'm thinking the problem could be the pump needs replacing.
What do you think?
Greg
Sep 05, 2008 | Asko 1375 Dishwasher
Asko 1375
May be the drainpump that has something stuck into it. Check that:)
Nov 23, 2007 | Asko 1375 Dishwasher
Dishwashers Logo
41 people viewed this question
Top Dishwashers Experts
