Maytag eev99413 will drain and agitate but will not spin
watugot
  • 290 Answers
SOURCE: Maytag MAV6200AWW does not spin
Be sure to check inside basket very carefully to make sure no loose nails or screws or drill bits etc that were left in a pocket are sticking through a hole in the basket and locking it to tub. This is common. If that is not the problem,one of three things has happened. 1 The thrust bearing that releases the brake has worn out. This is the most common and easiest thing to repair. If you tilt the machine back so you can look under it you will see the pulley that turns the transmission. When the pulley turns one direction it works the agitator, turn it the other direction and you should see it push the brake up that is directly above it. The thrust bearing kit includes the pulley and all bearings and washers to release brake. If you are mechanichal and can follow the directions that come with it, it is a fairly simple repair. 2 The brake lining has come apart and "stacked" itself in the brake housing. Replacing the brake is not hard, but there is about 200lbs of spring force pushing against the brake and housing that must be released slowly. I would recommend you call a technician for this just because I don't want anyone to get hurt trying to follow my directions on this repair. 3 An item of clothing has found its way between the basket and tub and has the basket bound up. This would mean removing agitator and basket. It is not likely this has happened, but I have seen it before.
Posted on Oct 04, 2007
IFIXALL
  • 868 Answers
SOURCE: Maytag Performa washer dead.
Your door lid has a switch that makes these functions work.First open the lid and look at the right side of it.Does it have a arm on it?If it does follow the direction where it is going to hit and now listn closely while your lifting the door up & down at this contact  can you hear it click?If its not clicking  or the arm is broken  off the lid replace  the lid switch/or the broken lid switch arm.
Posted on May 23, 2008
SOURCE: Does not spin
Seems you need a lube job on the centrifical mechanical switch that fully engauges the spin cycle( part of the pully to shaft assembly)
Posted on Jul 08, 2008
  • 22 Answers
SOURCE: Maytag Atlantis Washing Machine does not ever drain or spin unless lift lid
your machine needs a new lid switch assembly!
Posted on Aug 22, 2008
honeymokey
  • 3113 Answers
SOURCE: Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
Posted on May 17, 2009
Maytag Performa PAV920AWW makes squeeling sound when agitating/spinning. Water does not drain completely during spin.
Sounds like brake is partially engaged. There is s kit that may fix that. Part # 12002213.
Sep 19, 2017 | Washing Machines
Maytag washer doesn't agitate
Google the model number. I had the same problem, Googled it, and found the actual turial on YouTube to fix it.
Dec 11, 2011 | Maytag MAV6200 Top Load Washer
Maytag will agitate instead of spin
http://allrepairmanuals.com/maytag-washer.htm?model_number=MAV7901AWW
Please download, the above, service manual, use the troubleshooting procedures, you should be able to locate and repair your problem.
May 05, 2010 | Maytag Neptune Washer
LAT9604AAE No agitation but drum spins and drains water
cold possibly be just the agaitor but odds are u need a transmisson not worth repair
May 20, 2009 | Maytag PAV2300 Top Load Washer
May 17, 2009 | Washing Machines
Wont drain,spin,or agitate
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
Dec 27, 2008 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
