Question about Refrigerators
Leisure hja6100 compressor
Just stopped
3 Suggested Answers
  • 30 Answers
SOURCE: I have an leisure HJA6100
how full is it? if the vents are blocked this will cause the freezer to not cool enough. what is the temp ? second the defrost timer or the element may not be working this will cause the evapator coils to get clogged with ice therefore hampering airflow. third the cold control it is a thermostat sensor that tells the compressor to start the cooling. how's the fridge ? The fridge should be aboult 40 degrees +or- 5 degrees and freezer around zero if working correctly. the defrost timer is located somewhere around the cold control. there should (if a mechanical timer) be a small hole about the size of the tip of your pinky just inside that hole is a small plastic nub. you should be able to turn it if you find it try a small phillips head screwdriver to turn try both ways. if you hear a sound like winding a clock and then what sounds like a clock running at anypoint you have found it. what this does is it shuts down the cooling and activates a small electric heat strip in the freezer to melt the ice that collects on the coil remember grandma's old freezer and all the ice? this system takes care of that for you but does break. if the timer starts the defrost cycle you might have to run it thru a couple of cycles to melt the ice. if it's any prob but too full of food you will want a trained tech to repair. but you can find out what the problem most likley is and not get taken to the cleaners when paying for repair
Posted on Aug 07, 2011
SOURCE: My Leisure HJA6100 icemaking unit is making a terrible noise, which stops when I open the freezer door. It's just a year old, what could be causing this noise?
Your evaporator fan motor would be the cause of your noise. Yes, it can be repaired, just need to replace the fan motor. The noise stops when you open the door because the fan motor turns off when the door is open.
Posted on Mar 14, 2013
My Leisure HJA6100 with ice maker and chilled water dispenser now tripe the main circuit breaker for that part of the house when switched on. The plug 13amp fuse does not blow but the consumer unit tripps/...
A breaker trips when the current draw exceeds specifications. This is usually a short or where a component has failed and drawing excess current. It is also a good thing as it prevents a fire! The likely culprit on a fridge is the compressor and that is not usually a DIY job. You can poke around looking for evidence of arcing or overheating but likely a service call.
Jan 08, 2015 | Refrigerators
I have a Leisure Gourmet Classic double oven. The hobs, the grill and the upper oven all work fine, but the lower oven suddenly stopped producing any gas. I turn the knob and the austomatic ignition s
Apparently there is a bad valve for that oven , recommend calling a gas service repairman . your gas provider should be able to recommend a good one to you .
Apr 19, 2017 | Leisure Kitchen Ranges
Where do i buy replacement parts for 10'x8' US Leisure shed
where can i buy roof panels for leisure storage shed
10 ft x 8 ft
Nov 24, 2013 | Us Leisure Storage Building. Stronghold 10...
Garden leisure spa
check to make sure you are getting 220 to it if not the check breacker
Sep 07, 2013 | Pool & Spa
Mar 13, 2013 | Refrigerators
I have an leisure HJA6100 Fridge Freezer. the freezer doesnt seem to be getting cold enough even set to max. the display shows an exclemation mark in a square. also the temp bar is not shown
Aug 07, 2011 | Refrigerators
Air conditioner runs for several minutes then
Take it back to the dealer and have them fix it, could be a compressor froze up or a fan froze up. If you disconnect the compressor and turn it on and it trips the breaker the fan is probably
bad. If you disconnect the Fan and turn it on and it trips the breaker
it is you compressor.
Jul 16, 2010 | Dometic Rooftop RV Air Conditioner
Refrigerators Logo
23 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
