Question about Xante Accel-a-Writer Laser Printer
Toner refill kits
Are all toners the same? Can I use toner from a refill kit for another Xante printer?
  • 24 Answers
No, they are different. I would recommend either of these two sites for Xante toner refill kits as they have done a great job for me:
www.lasertekservices.com
www.tonerrefillstore.com
Posted on Apr 30, 2010
"No" and "No"
Posted on Jun 19, 2009
Which one refill kit I need on this page?
HP Easy Refill Kit for (HP) Color Inkjet Cartridges Printer
Jul 10, 2012 | HP Easy Refill Kit for (HP) Color Inkjet...
I have a universal color inkjet refill kit need to know to apply to my laserjet 4000 toner cartridge C4127X
Short answer: you cannot use any INKJET refill kit for a Laser Printer!
Laser Printers use TONER (e.g. powder) and not INK.
Hope it helps!
Sep 18, 2011 | HP LaserJet 4000n Printer
I refilled toner of my Lexmark E120 (since it said it was out of toner) and it worked fine untill few days ago when I got status report: Missing or defective catridge. Could this mean it's out of...
Replace the chip, is a chip cartridge problem.
if not work try this:
31 Defective toner cartridge or missing cartridge
1. Verify that the toner cartridge and PC kit are correctly installed.
2.Wait 10-20 seconds for the printer to verify the units.
3. Replace the toner cartridge or PC kit if necessary.
Aug 01, 2011 | Lexmark E120 Laser Printer
Hp laserjet 1100 toner catridge refill?
Hi follow these steps..
1.Purchase a refill kit for your model of printer. It is important to purchase a refill kit designed for your specific model, since generic refill kits do not work well with HP printers. There are a number of places to buy these kits, but you must make sure you get the right kit for your printer model
2.Take the toner out of the printer and clean it carefully. Over time toner cartridges will accumulate paper dust, dried toner and other debris, and all of this must be cleaned away before the cartridge is refilled.
3.Flip the cover out of the way to expose the developer roller, then use a soft clean cloth to clean the roller. It is important to clean this roller before refilling the cartridge.
4.Make a small hole in the toner cartridge, using the instructions provided in the refill kit. It is important to follow the refill kit instructions carefully, since the toner refill process will vary from model to model.
5.Place the replacement toner in the hopper, then carefully pour it into the HP cartridge. Be careful not to spill any of the toner, and if you do spill the toner be sure to clean it up promptly. Reseal the hole you made after the cartridge has been refilled.
6.Sit the refilled HP cartridge on a clean flat surface and let it remain there for 20-30 minutes. Pick up the cartridge and make sure no toner has leaked out. If you do see any leaks you will need to reseal the hole you made again.
7.Pick up the cartridge and make sure no toner has leaked out. If you do see any leaks you will need to reseal the hole you made again.
Good Luck & cheers:-)
Jun 30, 2010 | HP LaserJet 1100 Printer
How to refil konica minolta toner
Shop for the appropriate refill kit. When purchasing a refill kit, double-check to be sure that the toner in the kit is compatible with the toner required for your model of Konica Minolta printer.
  • Step 2 Empty the old printer cartridge. Be sure to completely empty the printer cartridge that you plan to refill. A compressed air can is ideal for this purpose and can be purchased online or at most office supply stores.
  • Step 3 Remove the plug. The cartridge plug may be covered by a colored end plate, depending upon the model of your Konica Minolta printer. Simply unscrew the end plate, and then remove the plug. If using a screwdriver to remove the plug, be careful not to puncture the plug, as this will cause the toner to leak out of the cartridge and into your printer.
  • Step 4 Refill the printer cartridge. Shaking the powder in the refill toner bottle before attempting to pour it into the cartridge will cause it to pour much more easily. Do not squeeze the bottle, but allow the toner to simply pour out. Replug the cartridge, and gently shake or rock it back and forth two or three times to evenly distribute the toner powder inside the cartridge.
  • Step 5 Check for leaks. Before returning the cartridge to the printer, check the outside of the cartridge for any powder particles that may have spilled or leaked during the refill process. Wipe the particles off the cartridge, and gently shake it once more to check again for leaks. If no powder particles appear, then it should be safe to return the cartridge to the printer.
  • Step 6 Return the cartridge to the printer. Once you have refilled the printer cartridge and have checked for leaks, you may now return it to the printer. Go to your printer properties/settings and select the option to indicate that a new printer cartridge has been installed. Print a sample page to check print quality
  • Please post your feedback and Vote if the problem resolved as per your satisfaction.
    May 22, 2010 | Konica Minolta PagePro 1350W Laser Printer
    ML-2510 Laser Printer : persistent blinking red light
    Dear
    This problem you will be noticed when toner is 90% empty.
    Does the printer is functioning or No. If yes the problem is 90% toner is finished.[10% toner remaining alert]
    If printer is not functioning Please change the toner from Genuine dealer. Else your printer fails due to non genuine and refilled toner.
    Nov 11, 2009 | Office Equipment & Supplies
    Brother Toner Refills
    Yeah you can refill your cartridge. It is really easy and consists of removing the plug on the side of the cartridge, dumping out any old toner and dumping in the new toner. Its very easy. I have purchased refill kits from both of these sites in the past and its worked great:
    They also have great customer service. I hope this helps!
    Nov 08, 2009 | Brother DCP-7040 Laser Printer
    Best place to purchase toner refill kits
    I would not recommend filling toner yourself, the toner is very fine and you might accidently inhale some of this toner powder.
    Depending upon the cartridge it may not be able to disassembled to install the toner, it may need an opening created and then sealed later.
    You can purchase recharged toner cartridges on the Internet at reasonable prices.
    Sep 20, 2009 | Konica Minolta magicolor 2300DL Laser...
    Reset drums for c5500
    I have the same problems many of you have with the Toner and drum error on my C5500N. I have not had much luck with Okidata support. I have had success replacing the chips in the toner cartridges. The replacement chips can be obtained from www.printerdoctor.com. They sell toner refill kits for the printer as well as chips for the toner cartridge and replacement fuses and rebuild kits for the drums.
    Oct 06, 2008 | OKI C5500n Printer
    Xante Accel-a-Writer Laser Printer Logo
    195 people viewed this question
    Top Xante Office Equipment & Supplies Experts
    Marvin
    Marvin
    Jose Pino
    Dudeman321
    Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
