Question about Hotpoint 24 in. HDA3700G Built-in Dishwasher
CLEAN GUNK OUT OF BOTTOM OF DISHWASHER - Hotpoint 24 in. HDA3700G Built-in Dishwasher
Maytag 100 series - how do I clean the filter? There is black gunk coming out
Try running a cycle with citric acid from the canning section and the grocery store on the hottest cycle
Jan 02, 2016 | Maytag Dishwashers
How to clean the food trap
Usually hex head screws on impeller and the spray arm should have a hand screw in center. Loosen hand screw and spray arm comes off then remove screws on impeller and lift it up. Once off I like to clean it with 1/2 cup baking soda dumped into opening then add some vinegar. Reaction will bubble and it loosens any gunk that's there. Reassemble and run dishwasher on quick wash with two cups vinegar added to bottom of dishwasher
May 03, 2015 | Dishwashers
Samsung dishwasher sprays gunk all over my glasses. When the cycle is over they are coated with dried bits of gunk. Dishes are dirtier than when they went in.
I have the same problem with gunk and spots on dishes. I took apart the parts at bottom covering the heating element. There is all sorts of gunk on everything. I cleaned it all, even under gaskets and filter screen. I am neither sure what caused it nor how to prevent it. My thinking maybe the water source. Water in my town has gotten worse in quality and has bad smell. I use a major water filter system for drinking water. My thought is that the heating element is drying the water up and leaving sediment from water.
Sep 29, 2012 | Samsung DMR57LFS Stainless Steel Builtin...
Dirty dishes on Maytag 24 inch dishwasher, model no MDBH940AWS, Dishes have caked on gunk on the glasses after washing. The gunk is usually at the bottom of a glass (which is in the dishwasher upside...
This dishwasher has a circular filter path under the bottom plate - 6 screws - that can become filled inside with debris - you can remove it and wash it out with a garden hose.. Paul
Nov 20, 2010 | Maytag 24 in. MDBH940AWS Built-in...
A grainy grit remains on all my dishes. It's in the bottom of the dishwasher when the cycle is over. what is it and how can i fix it
I took everything apart in the bottom of the dishwasher, washed them and put them back together and now have clean dishes. I needed a star head to remove the screws, which I had. A Phillips screwdriver won't work. Food and gunk were clogging the drains and screens, even the spray wands. For the very bottom I used a shop vac to get all the dirty water out and then cleaned the small drain.
Jan 20, 2010 | Maytag Dishwashers
Dishwasher is leaking
Gasket probably became dislodged, replace door gaskets, at 4 years old I would replace the gaskets, they are not expensive.
Feb 17, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Only washing top rack
After observing the water just gushing out when the spray arm was removed, we determined there was still a bunch more calcification/soap in the ends of the spray arm. (We have very hard water in our area). Unfortunately, you cannot open up the spray arms to clean them out, so it took about 30 minutes of pounding and manipulating to get all the gunk out. Now my dishes are clean again. Hallelujeh! And the water cleaning the dishes is cleaner, as well.
Jan 11, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
There is gunk in the bottom of my dishwasher by the drain. Really sticky gunk. How do I get it out?
Depending on what that 'gunk' is, will determine your best course of action. If it is food byproducts from the wash process and you've not cleaned out the filter, you should remove as much of that gunk with a dishtowel and warm water, then use white vinegar to break down any other leftover material. Rinse with clean warm water. Check the filter and clean it after each wash process to make sure you aren't restricting drain water from being pumped out. Once you've removed th emajority of that material, you could run a dishless wash cycle on the sanitary setting to clean out anything that remained... Hope this helps...
Sep 09, 2008 | Dishwashers
How to clean residue ?
First step--pour a half cup of vegatable oil into the dishwasher and run a cycle,next use a cup of vinegar and run a cycle,third buy clr from home depot,lowes and run a cup through.clr is (calcium,lime,rust) remover.If the first 2 steps work your o.k.
Feb 23, 2008 | GE 24 in. GSD4020Z Built-in Dishwasher
Hotpoint 24 in. HDA3700G Built-in Dishwasher Logo
12 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
