Question about Mantis Tiller
MY mantis tiller will start and run for just a few seconds and then it stops. It has new gas and oil in it.it had old gas and oil mis in it but I dumped it all out and got new gas and oil mix. balhmang@mwt.net Thanks, Barb Manglos
  • Anonymous Mar 16, 2014
    Gas or oil gas mix
  • 97 Answers
You probably have gum or varnish built up inside the carb. take it apart and clean all the ports and jets with fresh gas. drain the float bowl and fill it with fresh gas as well. if you are not familiar with carbs, best not take it apart yourself, or pay VERY close attention to how it came apart.
Posted on Jun 18, 2009
Mantis tiller won't start
Flush out old gas. Check/clean spark plug. Oil filled? Try spraying starter fluid in carb. Carb should not have any oil in it. Change air filter.
Jun 04, 2015 | Mantis Tiller Honda 4 Cycle - No Kickstand...
Can not find my manual for the mantis tiller..forgot hot to start it up for the first time
You should be able to go to the Mantis web site and download the owners manual. To start, make sure the switch in turned on, push the fuel primer bulb several times (until you feel resistance), pull the choke out all the way and pull the starter rope until it fires. Then, push the choke half way in and it should start. Let it run a 30 seconds to 1 minute and then push the choke all the way in. Be sure you are using the currect fuel/oil mixture with fresh gas and oil. If you have not done so already clean the air filter and replace the spark plug at the recommended interval.
May 23, 2011 | Mantis 2-Cycle Tiller
I have a two cylinder Mantis tiller. It has locked up and the cord is locked. I am unable to pull the cord. Any suggestions? I was in the process of using the tiller when it felt as if it were running out...
check the oil, if not full fill it, take the shroud off, should be for bolts, fit a socket on it with a breaker bar or ratchet and turn it a few times, then reassemble and start. Hope this helped Tim
May 08, 2011 | Mantis 2-Cycle Tiller
How much gas to mix the oil in?
First check that your Mantis needs an oil/gas mixture, most of the newer Mantis tillers have four-stroke motors meaning they have oil in the crankcase and use straight gas. If your Mantis needs oil mixed in the gas use a 50:1 ratio. That's usually 2.6 ounces of two-cycle oil (it's sold in bottles that size) to one gallon of gas but read the oil bottle to get the proper mix ratio.
Sep 08, 2010 | Mantis 2-Cycle Tiller
Mantis tiller starts but will not stay running
Carburetor problem. Two stroke engines use oil mixed with gas. Old fuel or setting over the winter will cause varnish and sludge in the Carburetor. Start by buying a can of carburetor cleaner and mixing a new can of fuel.
1) Dump the old fuel and check replace it with new.
2) Remove the air cleaner.
3) Pump the prime bulb 3 or 4 times, set the choke, spray the insides of the carb with the cleaner and then try and start it . It should sputter and run for a few second but chances are it will take a few sprays to clean the jets
Jun 06, 2010 | Mantis 2-Cycle Tiller
Difficulty starting Mantis tiller & keeping it running
dirty carb or old gas or plugged air filter or combination of all three. give it a good clean up and some fresh gas.If you are not up to cleaning up your carb you can buy a cleaner lube additive that will work pretty well if you can get the machine running. You just add it to the gas and it helps clean things up internally as its running.
as a tiller has to work in the dirt you always have to spend a few minutes cleaning things up to avoid the bigger problems.
Aug 23, 2009 | Mantis 2-Cycle Tiller
Mantis 4 cycle (brand new): oil leaking out, smoking soaking air cleaner, quits running..
Sounds like your gas tank is not breathing properly. try this: the next time you run the tiller and it begins to stall out, try loosening the gas cap. It should start running again. This means that the gas cap is clogged. Unclog it or purchase another one.
Jim
May 30, 2009 | Mantis 4-Cycle Tiller
Mantis 2-stroke tiller won't start
This could be one of several problems...
• Last year's fuel. Get some fresh gas.
• Every 2-stroke needs a new spark plug each year... you know what that means.
• Clogged carb jets due to storing the tiller over the winter with fuel in the system. Never, ever do that. Now you'll need to pull the carb apart and clean it. Most of the orifices are so tiny you can't see them. Good luck.
• Engine is so old the crankshaft seals have hardened with age. This is one reason no 2-stroke lasts longer than about 8 years. If the seals are shot, then it will cost more to fix than a new one costs. Time to toss it.
Mar 21, 2009 | Mantis 2-Cycle Tiller
Mantis Tiller Logo
732 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
