Question about Washburn Music
D-100M/TWR Specifications
I need to find service manual for peavey pr15 please..
Operating manual and specifications, but you would have to go to Peavey direct for service info.
service manual for peavey pr15 Google Search
Apr 08, 2017 | Peavey Music
No5022670 when made
The serial decoder is on this page part way down-
Washburn Frequently Asked Questions
Mar 01, 2016 | Music
What is the value of guitar
Maybe is you should provide the make and model of your guitar and a good photo someone could provide you some info, thought I doubt. It's more probable to Get some insormation if you take your guitar to a good instrumentS store or to an antiquary.
Jun 24, 2015 | Music
I have a Fender Squier Stratocaster Standard HSS. Serial number: ic071104059. i am trying to determine the year and specifications
It was made in 2007. If you call Fender directly they can sometimes id the exact model version from the serial number. The records they keep on Squier guitars is a bit sketchy, but sometimes they can help.
Oct 11, 2014 | Music
Have a 100M entertainer. Need a cross for O/p transistor on amp ***
Go to Newark's web site. They will have it
Oct 01, 2014 | Music
Speakers specifications
ES 315 is 200W RMS
60-15KHz but not sure if this is -10db or -3db as it doesn't say
15in heavy duty bass driver, 8in specially designed mid range and 4in tweeter.
34.5Kg 730mm x 620mm x 375mm
These are a very old design and not very efficient and you probably would get better value from a cheap new pair.
Feb 04, 2014 | Behringer Music
I need lamp fuse protector replacement for the pv2m horn driver and dont know the specifications for the replacement lamp used
Take a look at these:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=F2006-ND
This is a polyfuse that trips at 1 amp and resets itself. It holds off 60 voltss which should be adequate.
Search for "polyfuse" and use "radial" and the trip current to filter, then view the pageat DigiKey.com.
Dec 06, 2010 | Peavey Pv12m 12' Floor Monitor
What is the yamaha keyboard electric consumption
That varies depending on the model of the keyboard.
Download the user manual and look in the "Specifications"... You will find the power consumption listed there. Most will be UNDER 50 Watts.
Sep 28, 2010 | Yamaha Music
I got he Marshall MG100FX amp with 2x 12inch speakers. The potmeter of the master volume doesn't work anymore. Do you know the specifications of this potmeter? Armin, delta.design@usa.net
That should be a 320K pot. <br /> <br /> Here's a link to the schematic. <br /> <a href="http://www.ampix.org/albums/userpics/10003/MArshall_MG100DFX.pdf">http://www.ampix.org/albums/userpics/10003/MArshall_MG100DFX.pdf</a> <br />
Aug 26, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
Music Logo
27 people viewed this question
Top Washburn Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Sock Puppet
Are you a Washburn Music Expert? Answer questions, earn points and help others
