Question about Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine
When the compressorshuts off it beeps once is this normal
  • Hoshizaki Master
  • 1,236 Answers
If you are turning off power, yes this is normal. If it beeps at the end of a cycle, this is not normal. One beeps means the evap is getting too hot. May have hot water entering the unit, or several other issues. May need a tech to check the unit out.
Posted on Feb 11, 2017
My frigidare freezer upright after moving beeps hit reseat quits after a few hours starts beeping again freezes great
Sounds like a GPS locator issue! JUST KIDDING!
This site may help. There are just too many electronic anomalies that can cause this issue. I got lucky once by asking if they just had their dog RFID tagged and spayed or neutered. Turns out they did that week. The ID tag was on the same frequency as their dryer buzzer. They put a gum wrapper on the front of buzzer and problem solved.
Dec 07, 2017 | Freezers
My frostfree Kenmore upright freezer has been beeping alarm since the power was off for three hours this morning and showing -3 as temperature. What do I do to reset?
On some models the beeping will not stop until it gets to normal temp. The -3 is more than likely the set temperature of the unit. you can try to change that with the control. The best thing to do is get a thermometer to check what the actual temperature is.
Aug 20, 2017 | Kenmore Freezers
Bosch Fridge Freezer (KAN62V40GB)suddenly started beeping and the temperature has increased. The normal alarm whent he door is not shut correctly is a continuous tone, however this is beeping like an
Check the condenser is clean and the fan running normally, Any excessive heat from under or behind is a sure sign the fan may need replacement.
Apr 28, 2014 | Freezers
Red light showing high tempature
cooling temperature of freezing is damaged and also damaged heater machine which keep in deep freeze but controller point keep in normal side,you must be repair that problem as soon as possible otherwise full freezing system get damaged.
Mar 22, 2013 | Frigidaire Freezers
How to reset hoshizaki ice machine
small white button on control board. press once to stop beeping. Very small but it is labeled and very hard to see.
Feb 09, 2012 | Hoshizaki Freezer Commercial Ice Machines...
I have got Hoshizaki Ice Machine which makes three beep sound every 2 second continuously. I turned off the machine. It looks it needs to be cleaned. Can anyone help me to resolve this problem so that it...
I am assuming that it has run two consecutive cycles. I would first clean the machine inside and out. it should drop ice once cleaned, if not then open up the control box and find out which lights are flashing. I am almost certain that once it is cleaned it will drop ice.
Jul 21, 2010 | Hoshizaki Commercial Freezer KM-500MAH
Beeping 3 times every 3 seconds
The 3 beeps indicates that the unit was in the freeze cycle for 60 minutes. Causes: 1.) Water valve leaking, allowing water to continually enter the system. 2.) Float switch stuck, sending false signal to board. This indicates ice not being produced. 3,.) Low freon level causing long freeze cycle. 4.) Hot gas valve leaking thru causing warmer than normal evap plates=low production. 5.) Expansion Valve not feeding freon properly to evap plates.
Items 1 and 2 are the most common. Number 3 possible due to freon leak in the system. Number 4 and 5 are usually a very rare occurance.
Hope this helps ya.
Sep 05, 2009 | Hoshizaki Freezer Commercial Ice Machines...
My freezer will not quit beeping
try unplugging the unit and waiting 2-3 minutes to allow the electronic ontrol to reset. I am assuming that the temps are normal. peyton
Jan 27, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Hoshizaki Ice Machine Model KM-500MAF
(Quated From Hoshizaki Technical Bulletin)
An alarm code of 3 beeps
every 3 seconds means that the control board has shut
down on the 60 minute freeze cycle back up timer.
The “E” control board has a 60 minute timer that starts at
the beginning of the freeze cycle. If the float switch fails
to open and start the next harvest within 60 minutes, the
board will automatically start the harvest cycle. If this
occurs in two consecutive cycles, the control board will
shut the unit down on the manual reset, freeze cycle
back- up timer. The yellow fault LED marked “60 min.”
will illuminate. This safety is designed to help prevent a
freeze up of the evaporator.
Once you have identified the 60 minute alarm, there are
several things to check. Reset the alarm by depressing
the white reset button to the right of the fault LED’s.
This must be done with the power “ON”. Now check the
float switch to see if it is stuck in the up position. A stuck
float can occur if scale is present on the reed switch
shaft inside the housing. To check it, drain the water
reservoir, unplug the black float switch connector (K5)
from the control board and check it with an ohm meter
for a closed switch (zero ohms). If the float switch is
sticking, clean it with ice machine cleaner or replace it as
An inlet water valve which is slowly leaking by during the
freeze cycle can cause a 60 minute alarm. If the inlet
water valve is stuck wide open, it is unlikely that any ice
will form on the evaporator. Check for a slow leak by
allowing the unit to cycle into the freeze cycle and
disconnecting the hose at the outlet of the water valve. If
water leaks by during the freeze cycle, the water valve
diaphragm is likely damaged or the small diaphragm bleed
port is clogged with scale. Clean the bleed port or replace
the diaphragm or entire water valve as necessary.
(I Recommend to get a refrigeration tech for this part).
Another possibility is a refrigeration system problem. You
should use normal refrigeration diagnosis procedures to
check for one of these problems. If the thermostatic
expansion valve is not feeding properly or the refrigerant
charge is low, the evaporator will not form ice as it should
and a long freeze cycle will occur. This could also be the
result of the hot gas valve not closing completely during
the freeze cycle or if the compressor valves are weak or
inefficient. An inefficient compressor however, will
usually show up first on the KM model through a longer
than normal harvest cycle. This is because of cooler
than normal discharge gas. Use proper refrigeration
practices to repair a refrigeration system problem.
While these are not the only reasons for a 60 minute
freeze cycle, they are the most common and should be
checked to resolve a 3 beep/yellow fault LED alarm.
Feb 27, 2008 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine Logo
Top Hoshizaki Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
