Question about Gateway One ZX4300-41 (PWGAW02017) 20 in. PC Desktop
No power what so ever..... No led no fan....nothing
NO LED indicator for power, fan on, Lamp does not turn on, Lamp LED
The ballast board controls the lamp operation. Your problem lies there.
Nov 04, 2013 | Epson EMP 730 Multimedia Projector
Powerwill not power up
Has there been any damage? drop? You get nothing? No LED's? Charger LED? Fan spinning? Nothing? Has the AC jack been pulled by the cord, damaging the AC jack connection. If you try to reboot on battery power? nothing? Try reseating the Memory Mods. Replace the CMOS battery.
Jan 12, 2013 | Sony Vaio Vpceb33fm
Gateway laptop i push power button it wont boot up but leds in front flash 4 times
Try holding down the power button instead of just pushing it. I had this problem with my HP dv7 and holding the power button down for around 5 seconds worked for me. Also make sure that its plugged in to a power source.
Oct 23, 2012 | Gateway Computers & Internet
Have an asrock 939sata2 I hit the power to turn on the led lights up along with the floppy drive light all the fans come on but that's it nothing else any solution?All the fan motors come on but t
Power Supply with a weak voltage power rail.
[There are 3 voltage power rails. 3.3 Volts, 5 Volts, and 12 Volts. All are DC Voltage ]
Enough power to light LED's, and spin fans, but not enough power to turn the Processor on.
1) If ALL of the LED lights were on at once they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use 51 to 125 Watts of power.
Just depends on what Processor it is.
Suggest you check the three main voltages with a multimeter.
Since the Soft Power On circuit uses 5 Volts, I have a feeling the 5 Volt power rail may be the bad one.
An economical multimeter can be purchased for as little as $5 to $12.
Available in a multitude of stores. An auto parts store is but one example.
Need guidance in using it just post in a Comment.
Or you can borrow a KNOWN to be good, Compatible power supply, and use it for a test unit.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 06, 2012 | Sony ASROCK 939Dual-SATA2 / 939DUAL SATA2...
Motherboard won't boot: no noise, no nothing...
Shorting the two leads will work but don't keep the two wires together. They are not ment to stay connected. Consider replacing your cases ATX power switch. Take a look at the link provided for a new switch;
http://www.cables4computer.com/Cases_and_Enclosures/Mid-Tower_PC-Cases_ATX_Push_Button_Power_Switch.html
The green LED on the motherboard means the board is in "Stand by mode". This green LED uses 5V DC to light the LED. After replacing your PS back into your system it may function just fine.
Good luck.
Mike
Dec 03, 2009 | Intel Motherboard
Device powers on but will not boot
I have seen this happen when the amount of RAM installed in the computer is higher than what is allowed by the motherboard.
Jun 28, 2009 | Acer Aspire 5315-2153 Notebook
Wont power up
If you are getting absolutely nothing, and it seems you have checked all the obvious, then I guess its just the board given up
Dec 15, 2008 | Computers & Internet
A7V8X NOTHING HAPPENING,
When a power supply goes out the way yours did, it's going to fry the MB 99% of the time. So you're going to need a new MB. It's possible that you CPU is ok, but that could also go too. I would replace the MB first, then the CPU if that doesn't work.
Nov 07, 2007 | ASUS A7V8X Motherboard
Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
Jun 21, 2007 | Compaq (388746-001)...
Gateway One ZX4300-41 (PWGAW02017) 20 in. PC Desktop Logo
23 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
