Question about Maytag MSD2656G Side by Side Refrigerator
Our maytag side by side refrigerator is leaking from the freezer
Water piles up on the floor from under the freezer. We have turned off our ice maker and disconnected it on the back. but it still leaks.
  • Maytag Master
  • 4,655 Answers
Your defrost drain is blocked with ice or another object. You will need to unplug and remove the rear panel inside the back of the freezer to examine what is happening. The defrost normally follows a pipe to the bottom of your refrigerator and flows into a condensate tray near the condenser fan that carries the water back into the air inside your home. If you run into problems make sure your model is the MSD2656G listed above your post and let me know if the number is different. Thanks,Sea Breeze
Posted on Jun 18, 2009
Check the filter. See if its connected right. Sometimes the old (BAD-need replacement) filter back pressure the water and if the seal or gasket is not good enough, you will have water leak. But in this case you will notice the water path inside the fridge too.
Ice maker drips water into freezer.Makes ice but doesn't shut off when full.
How to Repair a Refrigerator Ice Maker ' HomeTips
www.hometips.com/repair-fix/freezer-ice-maker.html
Aug 6, 2015 - If the ice maker doesn't make ice but you can see the arm swing intomotion and you hear a ... 4Check the water line that enters the back of the freezer for a blockage. Find the water shut-off valve behind the refrigerator or under the sink, turn it off, ... If your ice maker keeps making ice, even when it is full:.
Refrigerator's Ice Maker Leaking Water ' ThriftyFun
www.thriftyfun.com/tf37813274.tip.html
If your refrigerator ice maker is leaking water, the first step is to locate the source. ... Its not the ice maker - in the floor of the freezer is a small drain that lets the ... I shutthe water supply off but water dispenser still leaks even though no ... My side by side refrigerator leaks water into the ice bin when filling the ice tray with water .
Dec 26, 2015 | Refrigerators
I have water leaking under freezer side of door. I turned the ice maker off, turned off the water to the fridge, cleaned out the ice behind the panels, and put it all back together. Every couple of days I...
Hi, The drain hole is plugged with debris or ice...
Just had to thaw my own out tonight, it was doing the same thing... Take the bottom draw out and maybe the bottom shelf and then you will see the ice buidup in the back and on the floor... Thaw it out and make sure the drain hole is open... then you will be okay again...
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 25, 2011 | Maytag MSD2651 HE Side by Side...
Ice maker leaking
Are you sure it's the ice maker that's leaking? We have this model & ours accumulates a HUGE iceberg in the bottom of the freezer, but the water seems to be coming out of the back, at the bottom of the back panel, where the vents are.
Jun 29, 2010 | Maytag MSD2732GR Side by Side Refrigerator
My Maytag side-by-side refrigerator/freezer Leak
There is a pan and drain hose under the freezer coil that is there to catch any water when the freezer goes into defrost. I feel strongly that is where you will find your leak.
I hope this helps.
Apr 19, 2010 | Maytag MSD2756G Side by Side Refrigerator
My Maytag wide by side is leaking water from the
Yes. Your defrost drain hole in the lower rear of the freezer is frozen over with ice. Turn off the fridge. Remove the shelves and bins from the freezer side. Break up any ice on the floor of the freezer and dispose of it. Use a hair dryer to melt the ice over the drain hole in the rear portion of the freezer. Once it is clear pour a 1/4 cup of bleach into the drain hole.
Dec 20, 2009 | Refrigerators
Freezer is leaking and also makea buzzing noice
Hissing and popping is normal, it is the defrost heater.
Check that the freezer is level
Check the drain pan
Check the condenser fan
Check the evaporator fan
Inspect the compressor mounts
Water on floor outside of freezer?
* Check the drain pan
* If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve
Water inside the freezer?
* Check for a clogged drain tube
* If you have an ice-maker, check freezer and ice-maker for level
Aug 08, 2009 | Maytag MZD2766GES Side by Side...
Refrigerator leak
the water fill tube for i/m is on the back of ref. the tube you have is to the water dispenser. look in freezer floor, is it full of ice? if so, remove all ice and clear drain hole for evap. if not, reassemble what you took apart and inspect tube under ref. while someone runs water dispenser. find leak and repair.
May 20, 2008 | Maytag MZD2766GES Side by Side...
Magic chef water running on floor, from under risper, i removed crisper did not see drain hole ice maker not hooked up
leaking from frig side or freezer side? If its freezer side the drain hole is behind back wall. Get you trusty blow dryer out...
Oct 16, 2007 | Maytag MZD2766GES Side by Side...
Maytag MSD2656G Side by Side Refrigerator Logo
250 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
