Question about Radio Communications
Maxon frs 114
ANTENAS//?
How do i increase the modulation on my maxon mcb-45w
RV 101 SQ RANGE--RV 201 AMC ---RV 202 TX MTR ---- RV401 RX MTR --- Q7 AMC DEFEAT
Sep 19, 2014 | Cinema 4d Maxon MCB 45W CB Radio 120...
CAN THE MAXON BE RE-PROGRAMMED TO COMPLY WITH THE NEW FCC REGULATION OF NARROWBANDING?
It depends on the model and when it was produced. You might try googling the model number of the radio. Or you could call Maxon at 800-821-7848.
Best regards.
Sep 12, 2012 | Maxon Radio Communications
How do I change channels on my Maxon 49-sx
  • The "Maxon 49-SX" is a single channel transceiver that only operates on 49 MHz FM. The Maxon "49-FX" and "49-HX" operate on 5 adjustable adjustable frequencies. That radio has no channel/frequency options.
  • Hope this helps.
Nov 18, 2011 | Maxon 49-SX (1 Channel) 2-Way Radio
Is my maxon mcb-30 pa capible
According to the page below, it does not have PA capabilities.
http://www3.dealtime.com/xPF-Maxon-MCB-30
Aug 22, 2009 | Maxon MCB-30 40-Channels Base CB Radio
Replacement Mike for a Maxon SM 4450.sd
Mike the only suggestion I can giv you is to contact Maxon or a local dealer asn ask for replacement parts. The radio shop I work for does not carry maxon or Altronics parts. I only have Motorola and Kenwood commercial radio parts.
Pat N5SLI
Aug 26, 2008 | Maxon 49-HX 2-Way Radio
Maxon sl70
You may want to search this site for a manual.
http://mods.dk/
Jun 20, 2008 | Maxon GMRS50 (16 Channels) 2-Way Radio
Reprogramming a Maxon SP 100G?
Hello codeencrypt,
THE SP100G is essentially the same radio as the SP100U UHF business band unit that Maxon made at the same time, just pre-programmed for GMRS. I believe there is a programming kit for this radio (Model number: SPK400C) which may still be available for purchase from Maxon directly. Otherwise, your best bet is going to be contacting your local Maxon dealer to see if they have the capability to program he radio.
Best regards,
Ken
"Go Ahead. Use Us."
Jun 04, 2008 | Maxon SP-100G (4 Channels) 2-Way Radio
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
