Question about Zebra TLP 3844-Z Thermal Label Printer
Zebra 3844 wont print barcode - Zebra TLP 3844-Z Thermal Label Printer
SOURCE: improper printing of barcodes
recalibrate the label length in the printer(hold feed and power up). from memory bar-one uses the label settings from windows, so go into printers and faxes under control panel and correct the label size
Posted on Nov 09, 2007
jigeo
  • 57 Answers
SOURCE: Zebra Thermal 2844 prints text poorly
Lizardlick,
I found this information in the user manual:
Let the print head to cool for one minute, then use a new
cleaning pen to swab the print elements (the thin gray
line on the print head) from end to end. NOTE: You do
not have to turn off the printer to do this.
If print quality remains poor after cleaning, try the
Save-a-Print Head cleaning film to remove buildup
without damaging the print head. Call your authorized
reseller for more information.
Posted on Apr 19, 2008
jigeo
  • 57 Answers
SOURCE: Zebra LP 2844
The printer is in line mode. Do the following to take it out of line mode:
Turn printer power off.
Hold the feed button while turning printer power on.
When the light starts flashing, release the feed button.
When the light starts flashing again, press and hold the feed button.
When the light turns steady amber, release the feed button.
When the light turns steady green, the mode is changed.
Verify the mode by printing and inspecting a status report.
This requires good timing and may take several tries. You'll know it worked if no labels are reeled out after you're done.
Posted on Apr 24, 2008
  • 45 Answers
SOURCE: Zebra TLP2844 does not print the barcode label
Turn off the printer, then hold down the feed button while you turn it on again. After the configuration label prints, turn the printer off and on again,then try to print your labels.
If the barcodes still don't print, make sure they don't extand past the top, bottom or side of the label. If you software allows you to "clear the label cache" or "re-image the enitre label", try that.
Posted on Sep 23, 2008
jcarlton214
  • 105 Answers
SOURCE: I have Thermal Zebra Printer TLP2824, I have installed it and
download.....http://www.barcodesinc.com/free-barcode-font/
free barcode font for programs. copy into c:/windows/fonts
it will install into that folder, and just select that font in VB6 application before printing
Posted on May 27, 2009
Barcode Print aliginment is not proper in windows7
Try a different print driver. Go to Zebra web site and download driver for Windows 7'
Apr 22, 2014 | Zebra Office Equipment & Supplies
My zebra printer TLP 3844-z prints one label only, then stops and flashes red. It doesn't print subsequent labels.
There are 2 possible causes for this
1. Printhead not closed - check it is closed properly.
2. Either the ribbon or media is out. This cold also be a sensor problem. But it is worthwhile checking everything is loaded correctly.
Aug 19, 2011 | Zebra TLP 3844-Z Printer
May 27, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Ladder orientation barcode printing bad resolution needs correcting
Try slowing down the speed of the printer. Faster speeds degrade the quality of your print. Try printing your serial (ladder) barcodes at 2-4 inches per sec. It should improve the quality of your format.
Apr 13, 2009 | Zebra Z6M Plus Thermal Barcode Label...
CAN'T PRINT USING A ZEBRA PORTABLE PT400 PRINTER
Verify that the zebra software is loaded. Depending on the type of zebra printer used, might need special software. Zebra printers use the "zebra printer language" (zpl), not a standardized print language.
Dec 16, 2008 | Zebra Symbol Technologies MC909X-G Series...
Can you print the barcode using the software that come with the printer. Zebra TLP2844 come with basic Designer software. Test whether it's printing the barcode or not.
IF it prints the barcode via its software, then you might be having barcode font problem between your application/os and the printer.
May 21, 2008 | Zebra Eltron TLP 2844 Thermal Label...
Barcodes print too long
This is defendant on the program you use to print labels with. The printer responds to either a print job sent to the driver (like a standard windows printer). Or you can send an EPL program to the printer in order to use internal barcode generating features of the printer. The dimensions of the barcode are controlled via the EPL script. See the EPL programming guide avaialble on Zebra's website for more info.
Feb 27, 2008 | Zebra Eltron LP 2824 Thermal Printer
Improper printing of barcodes
May 25, 2007 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 3844-Z Thermal Label Printer Logo
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
