Question about Dewalt Dc012 Cordless / Corded Worksite Battery Charger Radio With 3 Power
Battery won't charge in the radio - Dewalt Dc012 Cordless / Corded Worksite Battery Charger Radio With 3 Power
Dewalt radio dc 010 will not charge
Check the voltage from the charger, check the socket which it plugs into for fractures and dry joints on the circuit board. Those are the most likely failure points. Have you tried moving the plug around to see if it's a bad connection?
May 12, 2014 | Audio Players & Recorders
2012 VW Jetta TDI battery won't hold charge and car only clicks and won't start
You need to charge your battery up more. Either get a battery charger or leave the jumper cables hooked up for a longer period of time.
Your battery was probably completely dead. You might even need a new battery...they really don't like to be completely drained.
Oct 09, 2012 | 2012 Volkswagen Jetta TDI Sedan 2.0L...
battery has gone .. u may need to buy new one ..or interchange the battery wid other set
Jun 14, 2012 | Midland Radio MIDLAND XT28 Two-Way Radio
The low battery light remains on after I changed the battery,
Hello
There are two possibilities for this fault. The first one is with its battery itself. If the battery did not hold current, in otherwords, it has weak, proper charge both in volts and amperes won't hold on it, and when the device draw current from it while it works, voltage drop will occur, and low voltage indication will be displayed.
The second chance is due to the charger circuit inside the radio. If charger circuit do not give proper voltage and current to battery, the battery won't charge to its full capacity.
Check it by replacing it with a new battery [batteries] first. If it helps you it's OK. If not, your radio need service, and its charger circuit must be checked well. OK.
Nov 15, 2011 | Emerson CKS2237 Clock Radio
My Cobra micro talk two-way radios have lithium batteries. They will not charge in the charger, the light won't come on. If I take the batteries out and put them in the charger alone the light lights...
Check your battery contacts to see if they have a film of dirt or debris. If so, clean them with a pencil eraser. Check to see they are making good alignment with the contacts in the charger. If these suggestions do not solve your issue, you may have a bad solder on a battery contact in the radio. (Be certain the radio is shut off when charging.)
Best regards.
Sep 24, 2011 | Cobra Microtalk 100 FRS Walkie Talkie...
Cobra pr 3850wx bought new NiMh 800mAh 1.2v rechargable batteries now the base charger lights won't come on when i put the radios in it
  • A Cobra 3850wx Radio requires 4x600mAh NiMH 1.2V AAA Part # GA-3ANH rechargeable batteries.
  • Not just any AAA rechargeable battery will charge in the unit.
  • All will work in the radio but not all will charge inside the radio. It has to be a specific battery.
  • This is an example of what you need. GA-3ANH batteries which will charge inside your radio. http://www.tomsawyer2wayradios.com/catalog/item/3823249/5076887.htm
Regards, Tony
May 22, 2011 | Cobra Microtalk 100 FRS Walkie Talkie...
I have a problem with radio gxt1050, it was functioning correctly, but now I turn on it and the keys not response, no PTT button, but I can hear calls from other radios... tanks
  • It takes a lot more power to transmit than it does to receive. So it is possible to listen but not be able to talk. Make sure that the batteries are charged and that the batteries are holding a charge. When batteries begin to fail they won't hold a charge for long at all.
Regard, Tony
May 06, 2011 | Midland Two Way Radio
My dewalt radio wont turn on
i have put 2 new batteries but cant get radio 2 work
Mar 28, 2011 | Dewalt DC011 AM/FM Radio
Ntn7143cr battery won,t charge. put in charger flashes red then green.
Clean your battery contacts on the battery and charger with a pencil eraser to assure good contact. Flashing red or flashing in general usually is the sign of a too low to charge battery, a shorted battery or a bad connection. In some instances, a battery will begin to charge once left on the flashing charger for an hour or so. Try this and see if the light becomes constant. If so, it is charging. If it still flashes, replace the battery.
Best regards.
Apr 04, 2010 | Motorola MT1000 Compatible 2 Way Radio...
Dewalt Dc012 Cordless / Corded Worksite Battery Charger Radio With 3 Power Logo
16 people viewed this question
Top Dewalt Electrical Supplies Experts
JOHN LAPIER
Joseph Mueller
Joseph Mueller
Are you a Dewalt Electrical Supply Expert? Answer questions, earn points and help others
