Question about Motorola Cell Phones
Change to caps - Motorola Cell Phones
  • Official Brand Answer
  • 3,100 Answers
Depends on model. We need more info.
Mark
Motorola Support
Posted on Jan 10, 2015
1959 chevy apache truck wont start turns over but wont start not getting spark after rotor and cap change
possible bad coil and or points and capacitor. this has breaker point ignition under that cap you changed.
May 24, 2017 | Cars & Trucks
I have 2006 chevy equinox code po455 I change the fuel cap and the purge evap valve but my code comes back what else could it be?
As you know one of the problems can be the Fuel Cap. I make this suggestion. If you changed your Fuel Cap before the Purge Valve double check that the cap used was an OEM (Original) Chevy Part for that specific vehicle, not just any cap from another Chevy.
Feb 28, 2015 | 2006 Chevrolet Equinox
Cylinder 5 misfire
If you have a distributor cap on this engine and I presume you have by changing the wire. There is in all probability a crack in the cap at this cylinder or a track line down the outside of the cap from dirt etc allowing moisture to divert the spark from the plug. Spray crc or wd40 around the cap or remove cap and look for cracks at this point
Feb 17, 2013 | Cars & Trucks
I have a problem with my car loosing heat when im driving, but it will reach temp when idling. i changed my thermostat and still having the same issue. any ideas?
CHANGE RADIATOR CAP WITH A HIGHER PRESSURE CAP LIKE YOURS MAYBE 9-10LBS CAP PUT 12-14LBS CAP ON IT WHAT IT DOING IS NOT HOLDING PRESSURE .
Dec 12, 2010 | 1999 Chevrolet Cavalier
The service shop left my oil cap off after an oil change. So far they have brought in 3 different caps, and none of them fit! Two came from parts stores and one from Mazda. I have a 2004 Mazda 6i 2.3L 4...
I had the same problem finding a replacement oil cap after my husband left the cap off. The usual auto parts stores didn't have one that fit. I had to order the cap through the dealership. The problem was that Mazda changed the oil cap midway through the production year. Try oil caps from the years on either side of yours: if you have a 2004 vehicle, try getting a 2003 and 2005 oil cap.
Feb 11, 2010 | 2004 Mazda 6
Changed plugs and plug wires and now it wont start? i checked for spark off the distributer all 6 were good?
if your engine run before you changed anything,and you are talking about a 3.0 engine,
you have to be careful changing wires on this engine,
you need toonly change one wire at a time,the distributor cap on this engine is just stupid.
if you look under the cap you'll see that a wire on the one side of the cap actually has a contact that leads to the other side of the cap.
cly 5 cyl 6
cyl 3 cyl 4
cyl 1 cyl 2
front of engine
if your looking at distributor cap from front of engine,
two screws hold down cap.
look at the screw closest to the front,from that screw second hole to the left is #1.
firing order is 123456
#2 wire will be at that front screw on cap,keep installing wires counter clockwise.
Dec 07, 2009 | 1996 Chrysler LHS
I have a samsung 740N, and the f301 is brocken. There are three cap 820mf/25v capXon bad too. I have two questions: 1. I need change the fuse, but I don't know if it will broken. 2. I need change the caps...
desolder the caps remove them and replace them with exact parts. why do you want to change the value of the cap? you can increase the voltage value. the fuse value will be on the metal or plastic. use green stick or tweezers to remove fuse body. i hope i answered your question. reply if u need something else. bama46
be sure to rate me
Aug 10, 2009 | Computers & Internet
My air conditioner fan motor runs in reverse thus, none or very little air is coming out
The fan motor can be wired correctly for up flow and still run backwards for downward flow or reverse when you put the wrong value capacitor or connect a hard start capacitor to an already bad start dual cap. Case in point: I come across a condenser where the fan motor is running (in the right direction, up) but the compressor is not. I put a hard start cap on the dual cap. The compressor comes on but now the fan motor runs reverse. No other wiring was changed. The hard start cap connected to the defective compressor start cap shifted the current, voltage phase 180 degrees to make the fan motor run backwards. I removed the hard start cap, removed the defective dual cap and replaced the dual cap with a known good one and everything worked correctly.
Jul 09, 2009 | Heating & Cooling
My 1990 chevy pickup just stopped running.
there should be 2 clips on from the rotor housing to the cap, pull the clips off and lift the cap, you will want to change the rotor inside as well. do not remove the spark plug wires from the old cap yet...replace the rotor, it will only go on one way, and put new cap on, it too should only go one way. now, one at a time, pull the plug wires and put them on the new cap that is mounted. this will ensure that you have them in the right order.
Jun 20, 2009 | 1990 Chevrolet K1500
T-49F
To change out your cap tube you will have to do the following.
Purchase cap tube replacement from supplier.
Recover your refrigerant.
Use your torch to remove the cap tube.
Weld in new cap tube (make sure you have it cut to the proper
length)
Pull a vacuum on the system.
Charge unit with recovered refrigerant.
Feb 03, 2009 | True T-49 Side by Side Refrigerator...
Cell Phones Logo
13 people viewed this question
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
