Question about Chevrolet Vehicle Parts & Accessories
How to add oil to the compressor in 1999 chevy malibu
  • 114 Answers
Suction side of the system
Posted on Sep 02, 2014
1999 chevy malibu ran hot and would not crank. changed egr valve and not cranks but runs very rough and not sure oil is getting to head.
you overheated it and then it would not turn over?i would check for anti freeze mixing with the oil and then do a compression test on all of the cylinders in case you blew a head gasket
Sep 25, 2011 | 1999 Chevrolet Malibu
2000 Chevy Malibu...Working on my AC replacing the compressor...What is the fluid capacity of the compressor/AC system on this vehicle...If I've added more than enough, how do I drain excess fluid to...
NEW AC COMPRESSOR POUR OUT SHIPPING OIL COME WITH IT ADD THEM SAME AMOUNT.IF YOU NOT SURE AND OIL BEEN POURED OUT.ADD 2 OUNCE R 134A REFRIGERANT OIL TO NEW COMPRESSOR. YOUR AC SYSTEM HOLD 1.75 LBS R 134A REFRIGERANT.
Jun 22, 2011 | 2000 Chevrolet Malibu
1999 Chevy Malibu , lite coolant leaking from engine . When I add coolant , the reserve tank keeps going down to empty while i,m adding coolant . The intake gasket is in tact . I check to see if...
Check your cylinder cap where you add oil to the engine see what color of the oil if it's coffee with cream ,it started to mix your coolant to the oil
Nov 18, 2017 | 1999 Chevrolet Malibu
How much oil do u putin new ac compressor for a 1999 Chevy Blazer
The general amount in the instructions state to drain the old compressor and if under 2 ounces then add 2 ounces if there is more then 2 ounces then add what you took out of the old compressor.Hope this helps.Good luck.
Jul 12, 2010 | 1999 Chevrolet Blazer
No oil is getting to the motor of my 1999 chevy malibu, suggestions on problem? repair needed? cost?
Oil pump bad,oil pump strainer stopped up,rod,and main bearings worn out,cost,just depends on the actual problem.
Mar 09, 2010 | 1999 Chevrolet Malibu
My 99 chevy malibu Clean out lifters
add a litre of diesel and a 3 sec squirt of fairy washing up liquid ,use vehicle for a week and see how it sounds ,if its quietened down a bit ,change the oil and use a cheap diesel engine oil and then add some more diesel and fairy and leave another week ,if it still hasnt quiented down then strip and repair ,is has quietened down the change oil again for good measure and use the diesel engine oil as its a detergent oil and then change oil at approx 6000mile interval no longer and use the cheap oil .Change oil filter every third oil change and you will not get a repeat of the problem.Use an expensive long life oil and the problem will re appear ,because the additives and combustion residues will clog up and stick the hydraulic valve lifters
Nov 05, 2009 | 1999 Chevrolet Malibu
Power sttering loss
its possible this is electric, if you have an owners manual that will tell you, or call your local chevy dealership parts department, give them the vehicle identification number and they can answer it.
if its electric, most likely the fuse blew.
Oct 11, 2009 | 2004 Chevrolet Malibu
2004 MALIBU MAXX A/C BLOWS HOT AIR
Could be several things. The fuse relay to the AC compressor could be bad. The system may need to be recharged due to lack of refrigerant the compressor will not work unless it has enough.
Jul 19, 2009 | 2000 Dodge Neon
Low Oil pressure light in idle at stop
Depending on the amount of miles, maintenance records, or how hard the car has been driven either by a previous owner, or by yourself. The engine's main crankshaft bearings or the connecting-rod bearings could be excessively worn.
Also, it could very well be a wiring problem to the sensor and/or computer causing the problem.
May 16, 2008 | 1999 Chevrolet Malibu
Vehicle Parts & Accessories Logo
24 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
