Question about GE GSF25XGRBB 36" 25.4 Cu. Ft. Side-by-Side Refrigerator w/ Tall LightTouch Dispenser, FrostGuard T...
Repair manuel for RS2530bbp - GE GSF25XGRBB 36" 25.4 Cu. Ft. Side-by-Side Refrigerator w/ Tall LightTouch Dispenser, FrostGuard T...
Hooking up a supco 3n1 in a samsung rs2530bbp?
I would avoid even using this device. there is a good possibility it will burn out your compressor. Most compressors have a run capacitor tat improves the power use and if it is not in the circuit the compressor can be damaged. I advise using the correct start device for this unit.
Jun 04, 2014 | Samsung RS2530BBP (25 cu ft) Side by Side...
Unit is not cooling
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 20, 2010 | Samsung RS2530BBP (25 cu ft) Side by Side...
We have a Samsung RS2530BBP. The ice maker works ok... water stop coming out... What do I need to do to fix the problem?
My Samsung RS 2530BBP frige Ice maker stop tp make ice.
The water tray stays verticly after pushing the reset button and the water pours in the container instead in the tray. I purchased a new ice maker but it did the same. Any idea how to fix it
Aug 12, 2010 | Samsung RS2530BBP (25 cu ft) Side by Side...
Noise coming from the back of my Samsung RS2530bbp refrigerator, fan like noise
if it is a squeeking noise it could be that the bearing on the fan motor is going out, if it is a tapping noise or a fluttering or maybe even a thuding the fan blade is hitting something like papper,mouse,insulation that was taped to the fridge for either sound barrier or temp. control.You will need to pull refrigerator out and use 1/4 or 5/16 nut driver and pull back cover off to determine the cause, be sure to er-install cover for if you do not it will not keep compressor cool there fore temp. in fridg. will not be consistant.
Aug 05, 2010 | Samsung RS2530BBP (25 cu ft) Side by Side...
Freeze works fine but ref side won't get cold samsung rs2530bbp anybody know what to do?
Remove the rear panel of the freezer, and also remove the vent in the fridge side. There is likely ice build-up in between the two that has to be thawed or scraped out so the air can flow.
Jul 25, 2010 | Samsung RS2530BBP (25 cu ft) Side by Side...
Samsung RS2530 Series Model RS2530BBP Twin Flow 25 cubic ft. I just bought a house. This is the refrigerator. It is making annoying motor noise at night. I need a manual for this frig.
Click Here=> RS2530BBP User Manual and if you need Product Support Click Here=> Samsung Appliance Support and if you need Technical Support or out of warranty feel free to ask me. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Mar 22, 2010 | Samsung Refrigerators
Samsung rs2530bbp... Not cooling... Compressor
my frigerator RS2530BSH has the EXACT same problem! can anyone help??
Jan 13, 2010 | LG LFX25971ST Bottom Freezer French Door...
GE GSF25XGRBB 36" 25.4 Cu. Ft. Side-by-Side Refrigerator w/ Tall LightTouch Dispenser, FrostGuard T... Logo
11 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
