Question about JVC Audio Players & Recorders
Shuts down after being turned - JVC Audio Players & Recorders
Which parts should be changed to solve the problem not to automatically shuts down
It depends on why it is shutting down. Is it overheating? Is it full of dust or pet hair? Does it shut down normally showing you a shut down screen or does it merely turn off. If it turns off, then I would check fans and heat pipes. IF it shuts down with a shut down screen you would want to check your windows install.
Oct 16, 2016 | Computers & Internet
I have a Gateway Solo Pro 9300 laptop. Whenever I shut it down, the power light turns orange, and the backlight is still lit. Other than that, the hard drive and fans turn off. What does this mean. How can...
That means the computer is in 'Sleep' mode. To completely shut down the laptop, you can press the power button once and it will do a normal shut down.
May 08, 2011 | Computers & Internet
PC shuts down. When you turn on the pc it shuts
try to change the source, that should solve the problem. But before try reset CMOS. (if you don`t know how to do it by jumper simple remove the battery from the mainboard for 5 minutes and then plug it back on..and after that turn on your computer and press F1 for default settings)
Oct 27, 2009 | E-Machines eMachines Desktop PC
How do i shut down my think pad? it will not cut off
In your case,
the most simplest way to shut down your laptop is to override your processing by simply holding down the shutdown button until your computer turns off (do this when all your work is saved and the "Windows is shutting down" mode is on your screen).
This idea is not recommended but will always work.
Hope I helped
- donman92
Jun 03, 2009 | IBM ThinkPad T30 2366 Notebook
Shuts down during warm up
the fuser unit is not warming up, so the machine shut down
Mar 21, 2009 | Xerox Office Equipment & Supplies
Rear lights will nt shut down when I turn my vehicle off
try pullin up on the brake pedal with someone behind to see if they go out it maybe your brake ligts and the switch for the pedal is out of adjustment
Dec 09, 2008 | 2005 Chevrolet Impala
On shutting down my laptop it gave the message, "installing 1 of 1" do not turn off your computer. It did not turn off all night. I turned it off by using the on/off button then shut it down...
When you start your laptop, press F8. You will get a menu (Normal boot, Reboot...). Choose Last good known configuration (something like that).
Aug 20, 2008 | Acer Computers & Internet
Tv shuts down
does the main board have the flyback on it? if so the yokes or CRTs can be intermittently shorting which in turn triggers your shut-down.
turning it off or unplugging just resets the shut down circuit.
Sep 04, 2007 | Samsung HL-R4266W 42" HDTV-Ready...
NP9890 shut down
If it is an overheating problem try turning the laptop off, turning it over and placing a vacum on the fan grill on the bottom. Many laptops get a dirt buildup internally and this will sometimes suck out the dirt.
Jul 29, 2007 | Sager NP9890 Notebook
41 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
