Question about Panasonic SA-HE200 Receiver
No speaker relay
No sound
Konzert amplifier has a problem with the audio, it goes on and off how to fix it?
if the relay keeps ticking it certainly means the relay senses an overload or a short circuit in the outputs(speakers). pls. check your speakers, tweeters connection. if you have another amplifier try your speakers if it will be working fine. be sure your speaker wires donot touch each other. try playing at low volumes settings.
May 30, 2013 | Audio Players & Recorders
Speakers getting power but not sound
check the speaker.. could be burned or open connection
May 17, 2010 | Logitech Z523 2 Speakers
I have aony receiver STR AV-880 serial # 803492 left side speaker snowy sound on A and B setting help please
Chances are really good that you need to replace the speaker relay for that side. I recommend replacing all speaker relays. The contacts are dirty. You can get parts from Sony. You will need the relay part number off the top of the relay to order from Digikey or similar parts places. You can try cleaning the relay contacts with a contact cleaner. Sometimes it works.
Apr 21, 2010 | Audio Players & Recorders
Poor sound quality with a infinity sound system.
Remember seing something under one of the seats ,but in my old age it could have been a cd autochanger
Nov 10, 2009 | 1990 Plymouth Voyager
I have a pioneer receiver..vs 812....and sound has ceased to come out of it. It comes on....and switches between sources...but there is no signal coming from ANY source
First make sure the speaker A/B switch is on.
If still no sound, dissconect ALL speakers from the rear of amp.
Now turn on amp and listen for the relays to click in.
One relay will click when you press power. A couple of seconds later, the speaker relay will click in.
If it does, you could have blown outputs, bad speaker wiring, faulty speakers.
If it does not, the speaker relay may be faulty.
Hope this helps.
Sep 12, 2009 | Pioneer VSX-D812 Receiver
No sound listening to music and audio stopped
Tape monitor is it on? Muting? How old is this unit? Does speaker relay click on secoinds after unit powers on? If relay does not click probably output problem. Try disconnecting speaker wires to see if relay will click. If it does click the suspect bad wire or speaker if not bad amp. The first step to diag is to diconnect everything and simplify the citems needed to get sound. 1 Known good signal source and cable, Minimum affects, check speaker switch, Known good wire and 1 speaker to front l or r terminal. iIf still know sound seek serv.
Aug 29, 2009 | Teac AG-V8060 Receiver
No sound from speakers?
This is likely to be th output relay having corroded contacts. The headphone output is taken directly from the sepaker output but fed through resistors. The output relay has failed.
Dan
Mar 09, 2009 | Pioneer Audio Players & Recorders
Marantz SR-940
Just finish repairing Marantz SR 940 with no sound output. Problem was a clamped speakers relay located behind the speakers lugs (red and black post connectors). To reach the relays you must remove the little circuit board behind those colored connectors et unsolder the posts. There is 2 relays, one for A set and one for B set of speakers. Very EASY when you know the solution!!
Nov 24, 2008 | Audio Players & Recorders
My Onkyo TX SV 535 Surround Sound wont work
Speaker relays have oxide on the contact points. Open up all the speaker, spk, relays and remove the oxide layer formed on the 12 contact points. Those 3 relays are on the spk terminal board. You can located it easily. It just mounted next to spk output, a horizontal board.
Aug 13, 2017 | Onkyo TX-SV535 Receiver
Panasonic SA-HE200 Receiver Logo
19 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
