Question about Conair Health & Beauty
Fb12s foot spa
I broke one of the feet and I am looking for a replacement part. Any idea where I could get one?
What foot do I use to use the letters?
sorry but no idea , as I do not know what feet you have.
Nov 17, 2015 | Bernina Virtuosa 160
How many gallons of water in 3172 cubic feet of water?
There are 7 1/2 gallons of water in a cubic foot.
3172 x 7.5 = 23,790
To calculate how much water in a swimming pool, in 'US Feet':
Length x Width = Surface Feet
Surface Feet x Average Depth = Cubic Feet
Cubic Feet x 7.5 = Total Gallons
Mar 07, 2015 | Pool & Spa
How do I sanitize a foot spa
run a bleach solution thru it. be sure to rinse it well after wards.
Feb 15, 2015 | Conair Relaxing Foot Spa
How to replace wings and foot pads on pool vac
Bend wings to fit onto pins. Pry off old feet with screwdriver and press new feet into place. They only fit on in one way
Sep 30, 2014 | Hayward Industrial Products Pool Vac XL...
How to fix sunbeam foot spa
if it has an air switch check to see if air hose isnt broke or kinked if it has a motor to produce bubbles make sure it works
Aug 23, 2014 | Pool & Spa
Looking for an S foot.
http://www.sewingpartsonline.com/husqvarna-viking-sewing-machine-presser-feet.aspx?gclid=CK-tn6_Y1r0CFa_m7AodMjYAdw
Apr 10, 2014 | Husqvarna Huskylock Computerized 936
How do i take the case off my brother xr-65 to replace my spool pin and spool cap
I don't have that particular Brother but I have on that is similar.
Start by taking all of the screws out of the back that you can find (they're in deep holes, so look carefully). Then look at the bobbin area and you'll probably find one more. Finally, take the feet off of the bottom of the machine (not the presser foot, the feet that sit on the table), you'll likely find that there is a screw through the middle of the foot that also holds the case in place.
Best of luck
Sep 10, 2012 | Brother Sewing Machines
Can i ask what is the basic meaning of foot spa
foot spa helps to relieve the hot itchiness in your feet, remove the dry flaky skin and yes it does make it softer. if you are using sterioid cream or any gel like creams,always put this on after a luke warm foot spa, do not dry the skin completely, shake your feet then apply the ointment, use a small amount, wrap your feet in glad wrap for 1/2 hour, your skin will feel soft, pain free and pampered, glad wrap helps the ointment absorb into the skin. I suffer from some type of skin cirrhosis
recommended by my dermatologist: Lovey Harrison
Aug 17, 2011 | Health & Beauty
Holmes HABF20 floor/box fan: broke one of the plastic feet that steadies the fan on the floor. Super glue no help. Are there replacement pieces available?
If you can't find a replacement plastic foot. You should be able to find rubber feet at a local Radio Shack. Replace the plastic feet with rubber feet. It will do the same. You may be able to find self-adhesive feet.
Jul 15, 2011 | Holmes Products HABF-20 Floor / Box Fan
The small bar that holds the zipper foot on broke. How can I get a new zipper foot?
There will be several zipper feet available at any of the sewing machine stores. You can either take the broken foot with you (or another foot for the machine) or note the shank length and the bar length on the foot. I believe the White uses a low shank foot. In that case, you would get a foot that is designed as a low shank foot (assuming the bar isn't narrower than your current foot), and it will work.
The common Foot styles are low, high and slant.
I hope this helps.
(you can also order sewing machine feet online but you need to know the style of how the foot connects to the machine. The easiest way to do that is to compare it to similar feet in a local store. Most of the online vendors will list the machine brands that are compatible with a given foot. However, I know that Husqvarna low shank feet have changed width over the past 30 years and thus not all of the feet from a new machine are mutually compatible with those for an older machine. So I wouldn't guarantee the match without seeing the feet side by side.)
Mar 31, 2011 | White Sewing 1740 Mechanical Sewing...
Health & Beauty Logo
18 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Julia Tatspaugh
Level 1 Expert
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
