Question about HP 17bII+ Calculator
Reset HP 17b11+
Reset calculator to original settings
    Habit-Forming:
  • 27 Answers
According to the manual:
To reset the calculator, hold down [CLR] while pressing the third menu key from the left. Repeat if necessary. The calculator displays
MACHINE RESET to confirm that reset has occurred.
The above sequence does not clear all memory and settings.
If you want to completely erase the continuous memory and return to default settings, press and hold down [CLR], the leftmost
menu key, and the rightmost menu key.(Press three keys simultaneously).
When the three keys are released, the calculator displays MEMORY LOST.
Posted on Jul 02, 2015
Need to change my display from a comma to decimal
I don't know which particular calculator model you have, but for an HP-12C, the manual says the following:
Digit Separators
As a number is keyed in, each group of three digits to the left of the decimal point is automatically separated in the display. When the calculator is first turned on after coming from the factory - or after Continuous Memory is reset - the decimal point in displayed numbers is a dot, and the separator between each group of three digits is a comma. If you wish, you can set the calculator to display
a comma for the decimal point and a dot for the three-digit separator. To do so, turn the calculator off, then press and hold down the [.] key while you press [ON]. Doing so again sets the calculator to use the original digit separators in the display.
Oct 25, 2013 | HP Office Equipment & Supplies
How to fix a none responsive button in hp 35s calculator
Resetting the Calculator
If the calculator doesn't respond to keystrokes or if it is otherwise behaving unusually, attempt to reset it. Resetting the calculator halts the current calculation and cancels program entry, digit entry, a running program, a SOLVE calculation, an ∫ FN calculation, a VIEW display, or an INPUT display. Stored data usually remain intact.
To reset the calculator, hold down the C key and press GTO . If you are unable to reset the calculator, try installing fresh batteries. If the calculator cannot be reset, or if it still fails to operate properly, you should attempt to clear memory using the special procedure described in the next section. If the calculator still does not respond to keystrokes, use a thin, pointed object to press the RESET hole.
The calculator can reset itself if it is dropped or if power is interrupted.
CLEARING the MEMORY
If the calculator fails to respond to keystrokes, and you are unable to restore operation by resetting it or changing the batteries, try the following MEMORY CLEAR procedure. These keystrokes clear all of memory, reset the calculator, and restore all format and modes to their original, default settings (shown below):
  1. Press and hold down the C key.
  2. Press and hold down the R/S key
  3. Press i (You will be holding three keys simultaneously)
  4. When you release all three keys, the display shows MEMORY CLEAR if the operation is successful.
Mar 02, 2010 | HP 35s Scientific Calculator
I just replaced the batteries in my HP 12C calculator and when I turned it back on the display looks like this 0,000. How do I get the display to show decimals instead of a comma?
Here is what the manual for the HP 12C Platimum financial calculator says on page 17 of 275
Digit Separators
As a number is keyed in, each group of three digits to the left of the decimal point is automatically separated in the display. When the calculator is first turned on after coming from the factory — or after Continuous Memory is reset — the decimal point in displayed numbers is a dot, and the separator between each group of three digits is a comma. If you wish, you can set the calculator to display a comma for the decimal point and a dot for the three-digit separator. To do so,
turn the calculator off, then press and hold down the [ . ] key while you press [ON] Doing so again sets the calculator to use the original digit separators in the display.
Hope it helps.
Oct 06, 2009 | HP 12c Calculator
How to reset to original settings?
1. To restore the default setting you have to reset the calculator:
- With the calculator switched ON press the [2nd][+] [ENTER] Move the cursor down to Reset or press the [7] key.
-Choose to reset [RAM] ( 1: all ram; 2: defaults) or [ALL] (1: all memory. Whatever choice you make needs to be confirmed in a subsequent screen.
To reinstall the applications you need a TI silver cable, and the TI Connect software. Install the software before connecting the calculator to the computer.
Then you go to the education.ti.com web site Unfold the DOWNLOADS menu, choose Apps,Software,Updates submenu. Click TI83Plus/TI84PLUS family link and download what ever you want on your computer.
When you are done, connect your calculator to the computer, execute the TIConnect software . You can then drag and drop on the TIconnect window the app you want to restore.
Hope it helps.
May 30, 2009 | Texas Instruments TI-84 Plus Calculator
I have a comma instead of a decimal point. How can I fix this?
Turn the calculator off, then press and hold down the . key while you press on.
Doing so, sets the calculator to the original digit separators in display.
Hope this helps.
Dec 28, 2008 | HP 12c Calculator
How to change comma into decimal point
Dec 23, 2008 | HP 12c Calculator
HP 12C
gtabblt.gif Description gtabblt.gif Resetting the calculator using the keyboard gtabblt.gif Resetting to drain the capacitor gtabblt.gif Other solutions gtabseps.gif Description Sometimes a calculator will lock up or will not respond correctly. The calculator may require a reset for a variety of reasons. These resets will erase the memory on the calculator and restore the calculator’s defaults. For this reason, it is important to back up any critical data. Resetting the calculator using the keyboard The easiest reset is done from the keyboard. To reset the calculator, follow the procedures below in the order presented.
  1. Press ON to turn off the calculator.
  2. Press and hold [ - ] .
  3. Press and release ON .
  4. Release [ - ] .
  5. The screen will display “ Pr Error
  6. The calculator will reset to the default settings, and the memory will be erased.
If the above reset did not restore the calculator to normal, continue to the next section.
Sep 04, 2008 | HP 12c Calculator
Replay Button
hit (shift) (clr) and Number (3)
your calculator will be reset to the original factory setting.
Naveen
Feb 06, 2008 | Casio FX-300MS Calculator
Display a decimal point
Turn the calculator off, then press and hold down the .(decimal key) while you press the on button. Doing so again sets the calculator to use the original digit separators in the display
May 10, 2007 | HP 12c Calculator
HP 17bII+ Calculator Logo
79 people viewed this question
Seeker5211
Seeker5211
